    [Plugin] TextureTools
    106 Posts 34 Posters 114.6k Views 34 Watching
      marco62118
      good evening
      Β  I do not understand the plugin does not respond
      dialog boxes are displayed correctly, but nothing happens
      Can you help me?
      • CadFatherC
        CadFather
        the plugin only works on front faces (not sure why) - so, check that your texture is painted facing front and then try again. perhaps TIG can make it work on back face as well in the future.
          These tools only works on front-faces... because that's where textured-material ought to be applied.
          Applying a material onto a back-face is just bad practice.
          Back-faces should never be visible.
          Modeling with reversed faces can lead to many problems when pushpulling, applying cutting components etc, and when the SKP is exported, used in many rendering applications etc, etc...
          The native context-menu Texture tool will adjust front/back-face textures, depending on which side of the face you are seeing... use that if you insist on sloppy modeling.
          BUT I deliberately discourage the application of materials on back-faces.
          So these tools will only ever adjust textured-materials applied onto front-faces.
          Use Monochrome mode, with a contrasting back-face default-material in the Style, to check that you are not modeling 'inside out' πŸ˜•
          The context-menu items Reverse and Orient are useful to fix reversed faces as you model - shortcut keys is highly recommended. Also use Monochrome as you model to check the correctness of the faces' orientation. Only start applying materials and texturing once the geometry is pretty much resolved... πŸ˜’
          • CadFatherC
            CadFather
            yes, i understand, though i guess that's only if you are using a rendering package, if you use SU for render, than back faces are just as good - and of course when you paint both you don't get those pesky flickering edges.
            • ArcA
              Arc
              Eneroth Texture Positioning Tools
              http://extensions.sketchup.com/en/content/eneroth-texture-positioning-tools
              Is this same plugin?
                No, mine is the original one...
                  Mafalda_Melo_Oliveira
                  How do I install?
                    @mafalda_melo_oliveira said:
                    How do I install?
                    Find the tool in the SCF PluginStore [Resources menu first item], get the RBZ and install it with Preferences > Extensions > Install... button in v2013 or v8...
                    OR get the SketchUcation Plugin Store toolset [second item in that menu or in the first item - under most popular...] - that lets you AutoInstall Plugins from within SketchUp itself...
                    You need to ensure you have FULL security permissions to your Plugins folder - there are several post covering that...
                      New version available at the PluginStore http://sketchucation.com/forums/viewtopic.php?p=329765#p329765
                        anesalesayi
                        thanx man
                        • CadFatherC
                          CadFather
                          great plugin - would be fantastic if it worked on back faces too
                            @cadfather said:
                            great plugin - would be fantastic if it worked on back-faces too
                            But why is any textured material applied to back-faces ?
                            They should never be seen !
                            However, I have PM'd you a version to test called TextureTools_BACK ! which works like TextureTools but only on back-faces... It's a separate toolset and toolbar [it has similar icons but with a blue-gray background]
                            Please test and see it it's what you expected...
                            • CadFatherC
                              CadFather
                              Thank you TIG, that works great! πŸ˜„ πŸ‘
                              basically since often i don't photo-render my drawings, the front-back issue doesn't arise.
                              should i change my mind later i could always swap and even reverse faces with the su4you materials plugin: http://sketchucation.com/pluginstore?pln=S4U_Material
                                If anyone else wants to try the 'TextureTools_BACK', please ask and I'm PM it to you...
                                • CadFatherC
                                  CadFather
                                  btw TIG, i tried unifying the 2 plugins, but i might as well work out the quantum/relativity problem first....... πŸ€“
                                  if you do join both scripts into one, PM me first please!
                                  • O
                                    oip
                                    • Y
                                      YuriNikolai
                                      Will you ever release a 2016-compatible version of TextureBaker?
                                      • 5 / 6
