    [Plugin] TextureTools
    106 Posts 34 Posters 112.7k Views 34 Watching
      Mafalda_Melo_Oliveira
      How do I install?
      • TIGT Online
        @mafalda_melo_oliveira said:
        How do I install?
        Find the tool in the SCF PluginStore [Resources menu first item], get the RBZ and install it with Preferences > Extensions > Install... button in v2013 or v8...
        OR get the SketchUcation Plugin Store toolset [second item in that menu or in the first item - under most popular...] - that lets you AutoInstall Plugins from within SketchUp itself...
        You need to ensure you have FULL security permissions to your Plugins folder - there are several post covering that...
        • TIGT Online
          New version available at the PluginStore http://sketchucation.com/forums/viewtopic.php?p=329765#p329765
            anesalesayi
            thanx man
            • CadFatherC Offline
              CadFather
              great plugin - would be fantastic if it worked on back faces too
              • TIGT Online
                @cadfather said:
                great plugin - would be fantastic if it worked on back-faces too
                But why is any textured material applied to back-faces ?
                They should never be seen !
                However, I have PM'd you a version to test called TextureTools_BACK ! which works like TextureTools but only on back-faces... It's a separate toolset and toolbar [it has similar icons but with a blue-gray background]
                Please test and see it it's what you expected...
                  CadFather
                  Thank you TIG, that works great! πŸ˜„ πŸ‘
                  basically since often i don't photo-render my drawings, the front-back issue doesn't arise.
                  should i change my mind later i could always swap and even reverse faces with the su4you materials plugin: http://sketchucation.com/pluginstore?pln=S4U_Material
                  • TIGT Online
                    If anyone else wants to try the 'TextureTools_BACK', please ask and I'm PM it to you...
                      CadFather
                      btw TIG, i tried unifying the 2 plugins, but i might as well work out the quantum/relativity problem first....... πŸ€“
                      if you do join both scripts into one, PM me first please!
                      • O Offline
                        oip
                        • Y Offline
                          YuriNikolai
                          Will you ever release a 2016-compatible version of TextureBaker?
                          • 6 / 6
