    Who said SketchUp doesn't need to be 64 bit?
    204 Posts 39 Posters 58.6k Views 39 Watching
    • AndrewSA
      AndrewS
      @jdagen said:
      @andrews said:
      I very much doubt that anywhere near even 5% of world-wide Pro users would see tangible gains from adding 64-bit support
      while the active users from here may be 'a drop in the bucket' consider that many in the rest of the ocean are people who have the free version installed and are modeling things for fun from their basements.
      Agreed, many free users are such. That's why I wrote "world-wide Pro users". I'm talking about Pro users only--those who pay for the product. And yes, I'm sticking to my assertion that at this specific moment in time, there are lots of other issues that are important to a greater number of those users than the 64-bit thing. 64-bit is a false prophet.
      @jdagen said:
      The type of users represented here are your biggest evangelists, scripters, salesman, and customers - though small by percentage. By ignoring them for the vast ocean, you may slowly loose some of your greatest assets.
      As detailed in some of my other recent follow-ups, we're definitely not ignoring the users here or anywhere else. Everything we hear as feedback is valuable. We just can't do absolutely everything people ask of us. That means we have to make decisions that don't please everyone.
      @jdagen said:
      Furthermore, if you really are aspiring to compete with the 'big boys' as it relates to BIM and IFC, you simply cannot ignore the 64X issue.
      As with any other issue, "not available" does not equal "ignored".
      @jdagen said:
      Not going to 64X may also be tipping the hand as to who the intended user base is, and it seems that may not be many of us here.
      That has nothing to do with it. In fact, Google favored expansion of the free user base; Trimble is quite the opposite. They spent a lot of money on us and you can be sure they expect to see a return on their investment.
      @jdagen said:
      Second, I seriously doubt only 5% of users would realize the performance improvement. Anyone working on a large architectural model is familiar with the perfromance issues especially with terrain. If this isn't an issue, why does almost every Basecamp have sessions on working with large complex models?
      Take a look at pretty much every other 64-bit thread on this site and you'll see we've talked through this one until we ran out of air. 64-bit memory addressing has absolutely nothing, nada, zip, to do with models bogging down with complex geometry.
      The basic fact is that as soon as we raise the performance ceiling, use of the product will grow to match it. That's how it's always worked. Guidelines for high-complexity modeling exist to try to extend that ceiling as far as possible, for as long as possible. There will always be limits.
      A 32-bit memory space is more than adequate to address many times more geometry than SketchUp could ever reasonably handle today. The memory limitations come into play when dealing with insanely large textures, data imports/exports of massive files, trying to implement seriously complicated computation extensions within the SketchUp process instead of spinning off a separate process, and other stuff like that.
      Andrew
      Andrew S.
      SketchUp Release Engineer
      • AndrewSA
        AndrewS
        @driven said:
        Maybe you can purge the 'carbon' that's still floating around...
        24/04/2014 21:59:24.756 SketchUp[22606: *** WARNING: -[NSImage compositeToPoint:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.]
        John, I can't think of a single one of our Mac developers here who would disagree with that sentiment. Carbon has well overstayed its welcome. It's all just a matter of time and priorities.
        Andrew
        Andrew S.
        • AndrewSA
          AndrewS
          @solo said:
          I do not know the technicality of what is needed or what is going to work better however I do know what I'd like to be able to achieve with Sketchup.
          Maybe we can start a new thread and have a real discussion of what can be done to help us with higher poly models, not how to model leaner but rather how SU can be "fixed" to handle more complex scenes.
          Many folks believe going 64 bit or multi thread would help, maybe even having a way to turn off the inference engine, I do not know so maybe we can all discuss and perhaps even find a direction y'all may be willing to investigate.
          Solo,
          This is exactly the kind of thing we've done with our surveys in the past, with only varying levels of success.
          What we need to know before we begin investigating performance problems is that people are doing everything they can to follow our previous guidelines about making SketchUp work as well as possible with high-poly models, etc.. Only then can we fairly evaluate the feedback about what kinds of operations are getting people stuck. We need to see consistently and repeatably that under the controlled circumstances we've suggested, the bottlenecks exist <wherever-they-are>. We need to get a really good idea for not just the fact that some operation is a problem, but more importantly, to know the frequencies with which those problems occur. That's what allows us to put together a comprehensive plan to deal with those things that will make the most difference--those items on the critical path, in order of severity, as dictated by overall impact.
          In fact, that's exactly what we do with BugSplat. All of the crashes are prioritized by number and frequency of occurrence. When we address them, we do so in that order. That's why you've heard so many people talk about SketchUp crashing less often than ever before.
          The problem we've had to this point is that generally, we get a lot of people who cruise the forums and the internet and pick up on buzzwords like "multi-core" and "64-bit" and then instead of following our suggestions for how to use the software and working to give us good feedback on where their limitations are like I've described above, they just come back at us and throw the buzzwords around without doing anything helpful.
          For instance, just at this last basecamp, when I asked someone for what I just wrote above, he responded by trying to dictate his own process. He said, "No, it's not my job to do that; I'm paying for Pro and it doesn't work like I want, so that's your job to fix." He said, "Implement 64-bit and multi-core and xyz and then once you're done, you'll see all my problems are solved."
          I see that all the time and it does us absolutely no good.
          What we need is more people being really cooperative and forthcoming about helping us figure out exactly "what", and fewer people concerned about the "how." Our job is to figure out the "how" after we have a clear idea of "what," not the other way around.
          Always asking for "how" is just a recipe for disaster: Either we give you nothing but the "how" because that's what you insisted we do, though it doesn't actually do anything to satisfy, or we do our damnedest to figure out the "what" on our own and implement an appropriate "how", only to find that the "what" we did isn't the as important as the "what" we didn't.
          And believe me when I say that at least half of the time people think they're giving us a "what", they're actually giving a "how"; not necessarily to be obstinate, but because they don't actually realize their proposed improvement actually dictates a particular implementation.
          I think the issue for the immediate moment though is that we've done a reasonable job of collecting quite a bit of "what" and are in various stages of working through that stuff. The progress just never seems fast enough to satisfy. Plus all the while, we continue to have to try to quell the storms of people demanding their own "how".
          One of the ideas we've kicked around in the past is trying to create a sort of monitoring utility inside of SketchUp that we could use under some circumstances to try to collect really good data of the sort we need to figure out exactly where the problems are coming from. The problem is that it's a bit too much like Schrodinger's box, where the impact of running tools to observe the problems actually masks what's really happening by changing the timing and overall speed. Whatever the case may be, please trust me when I say we're always interested in trying to improve performance, although we simply can't sacrifice everything else to get it.
          Andrew
          Andrew S.
          • AndrewSA
            AndrewS
            @jeff hammond said:
            i'm pretty sure if there were a magic button which the suTeam could press and sketchup were suddenly 64bit, they'd all push it.. without hesitation.
            Winner, winner, chicken dinner. You're 100% right; we'd have hit it a while ago, no hesitation. Look, there's no ideological argument here that's causing us to say, "no, never!" There are just real technical hurdles and other priorities competing with each other all the time. We have to do our best to work it all out.
            @jeff hammond said:
            so if that is in fact true, everything which comes afterwards "benefits are minimal" and/or "performance may actually suffer" etc.. it just comes off as excusey sounding ...
            Exactly. There's an inverse relationship between the length of time someone wants something and their ability to be satisfied by the reasons why they can't have it. After a while, anger and pessimism win over, no matter how accurate, true, or reasonable the explanations may be.
            Andrew
            Andrew S.
            • AndrewSA
              AndrewS
              Hey everybody,
              This is my last response to this thread. The discussion of 64-bit has once again completely exhausted me. Don't expect any more updates on this topic from me.
              After reading back through the whole thread though--and actually, not as much this thread as several others--there's something I think is very important to get off my chest.
              While not directing this at any one poster, I want to make it clear how fed up I am with the finger-pointing and brow-beating that's been allowed to happen way too much on some of these threads. Sure, I'm a fan of free speech. I'm also a big fan of grace and civility in a professional setting.
              In particular, I'm just tired of how often people post negative, derogatory, or otherwise inappropriate messages about the people involved in the engineering or decision-making processes of the SketchUp team. I don't think users have taken to doing this to each other, but trust me I'd be just as disgusted about that if it were the case.
              Just like all of you, those of us on the SketchUp team who participate in these forums do so on our own time and don't find it motivating, fulfilling or helpful to put up with child-like outbursts or general incivility, particularly in what I'd consider to be a community that was created for the express purpose of professional exchange, and especially not in a context where people behave that way while simultaneously trying to get me or my team to listen to or help them in some way.
              If you've ever wondered why so many of us continue to work on the SketchUp team through transitions from @Last to Google and now to Trimble, the reason is because of the people. I'd trust my teammates with my life, let alone with guiding and nurturing a software product. Can you say the same abut your coworkers?
              Regardless of whether you believe me--and if you don't have coworkers like this, then you probably don't believe me--please hear this.
              Levying personal criticisms--those that are aimed at people instead of the product--is a sure-fire way to make me and the rest of my team ignore anything else you have to say.
              Those of us on the SketchUp team want to make the best product we can. We also want our users to have the best experiences they can, and to have a fair bit to do with guiding the future direction of the product, within the realistic constraints of us needing to balance the desires of a great many different stakeholders in this endeavor.
              Concerns, suggestions, bugs, problems, and questions about SketchUp? Keep them coming all day long. That's how we get better.
              Implications, complaints, criticisms and commentary about the character of the individual people on the other end of your keyboard? Keep them to yourself.
              If you wonder why so few of us still actively post on SketchUcation, look no further than this. Too many of my friends got tired of having to sort through character assassinations and tirades questioning the motivations of their coworkers, which they took as a sign that their participation was no longer desired. If it keeps up, I'll assume the same.
              Let's all be better to each other. Thanks for your consideration.
              Andrew
              Andrew S.
              • tt_suT
                tt_su
                @pixero said:
                Why is it that if I have some heavy geometry in SU all of a sudden some soft edges become hard edges?
                Yea, that one - that's one of my pet peevs and I looked into it. It's a very bizarre bug. I would like to see that fixed myself.
                @pixero said:
                Why is loading and saving big scenes take forever?
                In Photoshop you can press save and immediately continue to work. All saving is in the background.
                Our file handling routings could do with improvements - it's well known. As to why? The initial implementation hasn't scaled along with the complexity of the models 14 years later. It's certainly on our radar - one of the nth number of things to address.
                @pixero said:
                I could go on ...
                These are good things to report and have discussions around.
                • tt_suT
                  tt_su
                  @pixero said:
                  It's like he doesn't care for our needs. I feel I was a fool to believe that quads was one of the reasons he hired Thomthom.
                  For whatever reasons I ended up here, do remember that I've only been at SketchUp for a little over half a year...
                  • PixeroP
                    Pixero
                    @andrew
                    Thanks for your posts. Very informative. See, doesn't it feel great to "open up" a bit? πŸ˜‰
                    I think these posts are some of the best from the SketchUp team ever. πŸ‘
                    I'm still worried and confused by some things John B says and the way he's saying it though.
                    I believe getting the users on the train is important for our understanding.
                    That's why a more open dialog is so important.
                    I wouldn't ask you to reveal every secret with us but a better understanding comes from knowing where we're heading.
                    Not saying anything because of all "unfriendly ears" just seems ridiculous when no ground breaking things is released.
                    There are many different ways other companies are communicating this with their users, with labs or technology previews.
                    If they can do it, surely you can too?
                    • tt_suT
                      tt_su
                      @numerobis said:
                      @jason_maranto said:
                      The idea that 64-bit is relevant to why SketchUp high poly performance is so poor is just misdirection. The real culprit there is primarily the video card and openGL...
                      Processes like import, explode, copy, save/autosave(!), etc. are not opengl related. And this is what really annoys me - simple operations that can take forever.
                      Yes, explode is dead slow. It's the SketchUp stickyness in works. It's one of them things where when it was first made it was fast enough, but as models have grown due to other improvements this one hasn't been able to keep up. This is one of them algorithms-solutions. But it's deep into the core of SketchUp so any modification is risky and need extensive testing and research.
                      You mention import, of which file types? SKP or other formats?
                      @numerobis said:
                      And things like beveling should work in realtime (maybe not for 1 million polys, but for normal models) - watching this process bar is really laughable.
                      Beveling? We're talking about a plugin here, right? Performance for the Ruby API is high up there on my personal list. I've been spending a great deal of time poking into the performance of Ruby extensions and it's clear we need to improve this area as well. We have some ideas that we are exploring. On top of improving the API we also need to improve how we provide guidelines back to the developers of our API so they can utilize best practices that we've discovered over the year.
                      @numerobis said:
                      But... if SU would be able to deal with bigger models, then 64bit would be needed very quickly. I'm currently working in Max on models with 20-30 million polys that need 10-15GB RAM. Applying a turbosmooth i can easily max out my 32 gigs...
                      Sure, but to get there we need to fix a bunch of other things before the memory cap is an issue. When faces with a long list of things to do one need to pick the most imminent ones.
                      • tt_suT
                        tt_su
                        Consider that third party developers are also part of this train - and their vision for what they want to make with SketchUp also greatly affect the possibilities of SketchUp. The direction of Trimble isn't the only concern in play here. With more professional developers using the platform the directions would be endless. A good ecosystem of third party developers is in total capable of responding to a much larger range of users than each individually.
                        • KrisidiousK
                          Krisidious
                          Yeah, that's all kool and everything but, we can haz 64bit?
                          By: Kristoff Rand
                          • PixeroP
                            Pixero
                            • cottyC
                              cotty
                              I am using al lot of different software packages, but SketchUp is the only one for which I know severals persons in the developer team by name. So, thank you for beeing here and listening. I think the (sometimes frustrating?) discussion is a great way to put together a well prioritized "what"-list... (sorry, no how from me) πŸ‘
                              my SketchUp gallery
                              • jeff hammondJ
                                Andrew
                                well, to be honest andrew, what you're saying in this thread is pretty much opposite of the jab i was taking in that post..
                                generally speaking- when these conversations would come up in the past, i've always been left with the feeling that good communication never occurred.. there's way too much of an us_VS_them type of vibe which seems unnecessary and unproductive.
                                people would say "we want to see sketchup go 64bit" but the responses were of a tone of "you're wrong" or "your idea is bad because..."
                                (-or- team A was 'we want 64' -- team B was 'we want 32' ...the disagreements happened right from the very beginning)
                                so the rest of the conversation is the user's trying to convince why their idea isn't bad.. then the developers or those defending the developers get more annoyed etc.. then someone says something overboard mean and the 'conversation' ends until the next go-a-round 4 months later.
                                but really, this is the first time someone from the team is so openly saying "hey, we want sketchup to be 64bit too.. sketchup will be better off down the line if we can get it to 64bit.. if it were super easy to do, we'd be thrilled to release a 64bit version tomorrow.. your want isn't stupid" etc.
                                and if it really is true that the devs (in magic button land) would really like to see sketchup go 64bit then it gives the us_VS_them somewhat of a common ground to stand on.. which in turn should lessen the battle mentality of people simply defending their ideas to more of a listening/understanding mentality..
                                i don't necessarily think this type of shift speeds up any development processes or leads to a user working in a more fluid manner (or whatever) but at least the communication can be better with less of a battle vibe.
                                • jeff hammondJ
                                  πŸ˜†
                                  • AndrewSA
                                    AndrewS
                                    @pixero said:
                                    it seems they haven't even started converting to 64 bit to future proof SU. ... I would have thought that this process would be ongoing at some low level at least.
                                    We're doing tons of work to try to shore-up and future-proof SketchUp. I just can't confirm or deny any specifics. See my previous point re: lawyers and Wall St.
                                    @pixero said:
                                    The first thing that I thought about when I heard Trimble had bought it was that they really have to ...
                                    Good, more of that kind of thinking. Certain members of our team have been made into whipping boys because of the decisions people think they've made. Not all of the decisions come from the bottom like we sometimes wish. And luckily, not all of them come down to us from the top, either.
                                    @pixero said:
                                    I know J. Bacus have said that: "Access to memory is not the bottleneck in SketchUp where 'more geometry' is concerned."
                                    If it isn't then please tell us what the bottleneck is and fix it.
                                    OK, I'll tell you what it is. Ready?
                                    Surprise, it's not just one thing. Certainly, not even a whole set of things we could very easily explain to our user community.
                                    The biggest problem SketchUp faces is that it's an incredibly complex, legacy codebase. Having spent the last 13 years of my career working on legacy code, I can tell you that it's a whole lot harder and less glamorous than the preceding several years I spent working on brand-new code before that. Legacy code suffers from all sorts of problems you might expect with anything that ages. Sometimes you're dealing with cleaning up short-sighted decisions that should have never been made. Other times you're putting out fires caused by essentially random and unpredictable problems that no one can foresee at the time the offending elements are created.
                                    As far as performance is concerned, just as with the 64-bit transition itself, you'll just have to trust me when I say, if there were a magic button, we'd have pushed it already.
                                    Those who have used SketchUp a long time will remember the big performance boost we gave SketchUp with version 7.1. Well I'll tell you it wasn't for nothing. The gains we got there came from exchanging the entirety of our rendering engine for what we still use today--Intrinsic Alchemy. It was a massive, time-consuming insanely complicated integration to make that happen.
                                    Some number of the big performance improvements will require really big investments like Alchemy did. As I think Thomthom mentioned, some other number of improvements, such as the increased zoom capacity of LayOut, faster vector rendering in LayOut, and 10x faster shadow rendering in SketchUp, will be realized by improved algorithms--getting something done in a new way that is fundamentally superior to the old method, which either wasn't available, or wasn't thought of, at the time the original element was written.
                                    We continue to invest in both of those things. Unfortunately, they take time just like everything else, plus we just don't always get to predict the amount of improvement we'll be able to achieve before we begin. πŸ˜„
                                    @pixero said:
                                    By the way, how many developers are they? Does anyone know?
                                    I'm not sure if we're formally allowed to talk about this or not. At Google we were prohibited from revealing these details. I'll ask and see what our management says.
                                    In the meantime, please consider something perhaps nobody on our team has stated clearly before: that there's a lot more going on in the "SketchUp Team" than just the SketchUp client app. I'm not listing everything or going into detail, but I think our resources are spread out across a lot more areas than people might have previously expected. Here are some examples:
                                    • SketchUp desktop app
                                    • LayOut desktop app
                                    • Core platform
                                    • Import/Export/Interoperability
                                    • 3rd Party Dev: API/SDK/Ruby/EW Reviews
                                    • Infrastructure/Tools/Build/Release/Installers
                                    • Internationalization/Localization
                                    • 3D Warehouse
                                    • Extension Warehouse
                                    • Mobile Viewer
                                    • Intra-company Collaborations
                                    • Trimble's DBO Platform
                                    • Skunkworks/Secret Badassery/Mind Control
                                    • QA for all of the above
                                    @pixero said:
                                    Is there anyway to run some diagnostics in the background that if SU runs out of memory makes a dump of all running processes and memory used at that point?
                                    When these crashes appeared I didn't get a bugsplat I simply got that popup and another with "The application has unexpectedly closed". And it was gone.
                                    This has a bit to do with the way BugSplat is integrated with SketchUp and also how the memory became exhausted. Lots of unpredictable behavior results when memory is severely fragmented or exhausted, whether just within a single process, or on a larger scale. I've opened a bug about your observation.
                                    Andrew
                                    Andrew S.
                                    • AndrewSA
                                      AndrewS
                                      @airwindsolar said:
                                      But you'll never need more than 640k, applications will never be too big for a handful of 720k floppies, or manage to fill up a 40MB hard drive, or...
                                      πŸ˜„
                                      Obviously these sorts of statements seem ridiculous in retrospect, but the thing is that one never really knows which assumptions will hold true and which ones won't back when the original decisions are made.
                                      The people who wrote computer BIOSes 30 years ago assumed somebody would come along and eliminate their use of two-digit years before 1999, but then nobody showed up to do it.
                                      A lot of people saw the explosion of CPU clock speed from 1990 to 2000 and thought it would continue forever, but then one day we suddenly hit a barrier.
                                      I once got to speak in-person with Vint Cerf when he came to Boulder for a lecture. He told me a funny story about the use of IPv4 addressing on the internet, essentially saying that at the time the original specs were drawn up, although there were a few folks on the engineering team who wanted 64 or 128 bits of address space, when push came to shove, since not a single device had been built yet and the whole thing was experimental anyway, he decided there had been enough arguing and just put his foot down, saying 32 bits were plenty--especially since he didn't think anybody would take his research seriously if the proposals asked for anything greater. Of course, just like with Y2K, nobody came along to fix the shortcoming it until the last minute.
                                      Like I've alluded to throughout this discussion, the squeaky wheel gets the grease. πŸ˜„
                                      Andrew
                                      Andrew S.
                                      • FrederikF
                                        Frederik
                                        😲 My God...
                                        This is early Saturday morning here in Europe and I'm completely blown away... (in a very positive sense)
                                        I've only had a quick cup of coffee... Perhaps I need a few more to digest all the post and information written here within the past 24 hours... (keeping Pixero's note in mind about this thread having taken off 5 days ago - it seem that it gained momentum and reached warp speed during the past 24 hours... πŸ˜† )
                                        @andrews said:
                                        I'm responding to Frederick's message directly, but I'd like to be clear about the fact that in no way should anyone perceive the following message as pointing fingers at him.
                                        Don't worry, I don't perceive any of your answers like that you are pointing fingers directly at me... On the contrary... I really appreciate that you've taken all this time to post all these comments...
                                        I only have a huge respect for that...!
                                        http://www.kerkythea.net/users/Frederik/Anim-Icons/praise.gif
                                        @andrews said:
                                        Believe it or not, trust me or not, WE DO LISTEN! We love SketchUp and want to put out the very best product we can.
                                        I've never questioned this, but it's comfortable to have the confirmation... πŸ˜„
                                        @andrews said:
                                        Something I think a lot of people need to be reminded is, "you are not our only customer." While we work diligently to make everyone as happy as possible, the simple fact is that we have too much going on to pursue every single thing requested of us, and many times, keeping one set of users happy means consciously making choices that dissatisfy another group. We do the best we can.
                                        Great point, Andrew...
                                        http://www.kerkythea.net/users/Frederik/Anim-Icons/applause.gif
                                        This is the nature within software development - and in many cases other kinds of development as well - for sure...
                                        It's impossible to please everybody... That's a fact, it's understandable and pretty straight forward...
                                        @andrews said:
                                        Also, I know it's easy to forget or not to notice, but if you take a look back over the years and years of SketchUp development, there are plenty of examples of huge things we have done in response to user feedback.
                                        I know this isn't aimed at me, but I just want to let you know that I DO acknowledge and if you take a look at some of the posts I've made previously (not in this thread but on the board in general) you'll also notice that I continue to be very positive about the development of SU in general...
                                        I don't want to point my finger at anyone in particular (it's kind of obvious who they are and I still don't understand why they bother posting anything here... IMO they should leave SketchUp and play somewhere else...), but I completely disagree with those claiming that development have come to a halt within the past 5 years...
                                        It's simply not true and I do acknowledge the progress...
                                        Having said that... Whenever this 64 bit discussion arise, I do feel partly uncertain about the future of SU...
                                        @andrews said:
                                        We're also in agreement that SketchUp will have to go 64-bit someday.
                                        I certainly appreciate this statement...
                                        If you hadn't written anything else but this, I'd still be very happy...
                                        http://www.kerkythea.net/users/Frederik/Anim-Icons/thumbup.gif
                                        @andrews said:
                                        We've never said otherwise.
                                        Sorry to say, but it's the first time I (personally) have seen such a clear statement... Perhaps I haven't paid enough attention previously, but it's the first time I see such a clear statement...
                                        I'm sure I'm not the only one feeling like this, cause why would we have this discussion in first place otherwise...!?!
                                        Personally I feel that you (not you in personal, Andrew, but the SU Team in general, with John Bacus leading the crusade) have done an incredible job for not being particular clear in this matter...
                                        Perhaps it's obvious that SketchUp eventually would need to port to 64 bit, but I have to admit that the smokescreen have worked and hidden a lot of the "obvious" parts - at least for me...
                                        @andrews said:
                                        The reason a 64-bit version has not yet been released is a business decision that stems from careful consideration of the the costs of the endeavor and the true benefits to be had, in light of our other priorities. Those other priorities come from several sources, including not just customer suggestions and wish lists, but those tasks which are found to be of critical importance to growing our customer base and the promotion of Trimble's strategic vision for our product and the company.
                                        I fully understand all of this... πŸ˜„
                                        Once again, THANK YOU SO MUCH for taking the time to write these comprehensive answers, Andrew...
                                        Much appreciated...!! πŸ‘
                                        Cheers
                                        Kim Frederik
                                          What a positive outcome.
                                          @Andrew
                                          The thoughts and comments posted on SketchUcation by some members don't reflect the common thought process of the community in general.
                                          Trolls float in with negativity and both the mods and admin are desensitised to their negativity.
                                          Policing such comments is fruitless.
                                          I think what is evident here is that their seems to be 'situation' regards SketchUcation and SU staff that is entirely false. Or at least misunderstood.
                                          I think it is fair to say all SU staff are very welcome here and anything negative said personally about SU staff by members doesn't reflect the true feelings of the community.
                                          Thanks for taking time out of your day to address members concerns and suggestions.
                                          • HieruH
                                            Hieru
                                            Is it just me or has a huge chunk of yesterday's discussion disappeared from this thread?
                                            www.davidhier.co.uk
                                            • 11
                                            • 7 / 11
