    What is the Best UV mapping Plugins for Sketchup?
    13 Posts 5 Posters 5.3k Views 5 Watching
      sketchuh
      k .Externally!!! sounds a lot of learning...4ffd32sf32d...mind exploding...
      what if i just need to uv map a curtain. i can just use any uv plugin to get it done rite? coz i need to have a specific flower pattern curtain for my interior scene.
      btw, thanks for your answers. i owe you guys alot.
        Learning is a good thing.
        If you make the curtain using quad face convention then mapping within SU is easy using ThruPaint.
        If the curtain is some type of imported file then mapping get trickier depending on your skill level.
        Click the link in my signature I think there's a tutorial there using blender to unwrap and bake ao into mesh.
          sketchuh
          im using imported file, i will take a look at your tutorial of blender unwrap and bake. thanks again. really appreciate your help.
            sketchuh
            just a side note: i want to donate some money to sketchucation or to you sir rich obrien. it won't be much. i learned many important things from sketchucation. is there a paypal way to donate or how can i contribute financially? thanks
              Donate it to some plugin authors. they run the place. we just monitor
                sketchuh
                will do! anyway thanks for answer a lot of my question though. you still deserve my thanks!
                • jeff hammondJ
                  you should be able to do this very easily with fredo's thruPaint..
                  maybe upload a .skp of the curtain so we can see what you're up against..
                  if it's drawn ok, you'll be able to get this in one click.
                  • pbacotP
                    [attachment=0:26relahx]<!-- ia0 -->thrupaint.jpg<!-- ia0 -->[/attachment:26relahx]
                    So far in my various attempts--the word seems to be "if it's drawn OK". Obviously ThruPaint will not be able to apply quadmesh texture if you don't have a quad mesh.
                    • jeff hammondJ
                      true.. but it's very possible that natural UV will work out in other scenarios.. here's a curtain which was made with subdivide&smooth (no 'quads')
                      hidden geometry only faintly visible.. even at full size.. should of made that more obvious.. oh well. ;)
                      ..then thruPaint's naturalUV mode.
                      i don't know, it's hard to advise without seeing sketchuh's model of the curtain.
                        sketchuh
                        thanks i will try thrupaint, if it doesn't work i will use blender unwrap tool following rich obrien's tutorial.
