    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 938.1k Views 155 Watching
      dedmin
      SketchUP 2014 Pro, Win7 64 bit Ultimate Sp1
      This happens when starting to drag and typing offset distance. No error when just drag and drop.
      Video_2014-03-26_081748.wmv
      • fredo6F
        @dedmin
        It seems that this is related to the fact you pick the corner of the face and the API picker does not detect the face.
        I'll see what I can do.
        • pbacotP
          I find that I cannot select with this tool. I activate the tool, (Normal JPP) and go to a smoothed surface (set to surface select), individual faces turn green beneath the cursor. I click and nothing changes. The face under the cursor continues to turn green but nothing stays selected.
          • cottyC
            cotty
            @pbacot: did you try it like in the following screencast?
            @Fredo: is it intended that the middle line gets smoothed in this case?
            [screenr:2kd1qqny]iDdN[/screenr:2kd1qqny]
            my SketchUp gallery
            • pbacotP
              yeah. I just get the green highlight and green note "click to select faces" I click and nothing changes. On any sort of face in current context.
              • fredo6F
                I don't know if I can do anything as it may be a problem with the Mac and SU8.
                Is it for any model?
                Is it since an upgrade?
                Does it work when you stat JPP on a Preselection?
                • pbacotP
                  Works like that on any model.
                  No particular upgrade.
                  JPP acts as if there is no selection (selection disappears and faces respond to cursor by turning green). After exiting the selection of face appears again.
                  Manana I will reload (I loaded automatically from SUcation Plugin Store.)
                  • jeff hammondJ
                    nope, not that
                    although i don't have what i'm assuming pb's exact configuration is (mavericks + su8 ?)
                    i've tested it on osx10.7.5 with su8 & 2014 --as well as mavericks with 2014
                    i can select just fine on those (as in- i can do the same thing cotty did in the video above with no problems)
                    • T
                      tidusxx
                      thank you very much Fredo 😉
                      • N
                        ngeier89
                        My office has been using the joint/push pull tool for several months and it has worked flawlessly. Recently my firm upgraded to SketchUp 2014 and downloaded the most recent Joint/Push Pull tool but we have not been able to type in an exact dimension offset when using it. I try to type in a number to offset it but nothing happens. We end up just guessing at the dimension. There are several of us that are SU savvy so I don't believe it's just us because none of us can figure it out. It use to be that you just type in the number you want. Can anyone help? I've watched the youtube videos but it doesn't seem like they have the same issue I have. Thanks.
                        Nathan
                        • fredo6F
                          Nathan
                          Well, a few questions:
                          • do you see the value appear in the VCB?
                          • Do you get an error (in red under the palette button)
                          • does it work manually (by push-pulling with the mouse)?
                          Could you open the Ruby console while doing the tests so that you see potential errors.
                            StamatisPsarras
                            I am experiencing similar problems with Jeff.
                            I am on windows 64but Sketchup 2014
                            this is what writes in the console
                            Error: #<NoMethodError: undefined method entityID' for #<Sketchup::Model:0xad00970>> C:/Users/spsarras/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6FacePicker.rb:791:in selection_add_remove_faces'
                            C:/Users/spsarras/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6FacePicker.rb:744:in selection_validate' C:/Users/spsarras/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6FacePicker.rb:622:in selection_validate_if_add'
                            C:/Users/spsarras/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:670:in selection_freeze_positions' C:/Users/spsarras/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:1270:in onLButtonDown'
                            and yes it does that on a fresh/simple model. With all tools in joint push and pull. I also briefly noticed problems on other Fredo tools.
                            Thank you in advance
                            • tt_suT
                              tt_su
                              Have you disabled Dynamic Components by any chance?
                              • fredo6F
                                Yes. weird. It is strange that a Model object has no entityID method defined (which is normally "Model").
                                This may explain why some users cannot select faces in JPP if this problem occurs.
                                • tt_suT
                                  tt_su
                                  Yea, Model doesn't inherit from Entity and some methods are not mirrored. It's an annoying inconsistency.
                                    StamatisPsarras
                                    @tt_su
                                    You were right dynamic components was disabled! Now it works, thanks!
                                      StamatisPsarras
                                      I am also getting this error in a complex model.
                                      Any ideas what I should avoid when modeling, so it wont happen again?
                                      Date; 29-Apr-14 18;16;21
                                      An error occured in Joint Push Pull
                                      Error in generation of the geometry
                                      undefined method `smooth?' for nil;NilClass
                                      JointPushPullGeometry.rb; 1107 -- block in geometry_coplanar_edges_overhang
                                      JointPushPullGeometry.rb; 1105 -- each
                                      JointPushPullGeometry.rb; 1105 -- each_with_index
                                      JointPushPullGeometry.rb; 1105 -- geometry_coplanar_edges_overhang
                                      JointPushPullGeometry.rb; 354 -- block in geometry_robot_erase_coplanar_edges
                                      JointPushPullGeometry.rb; 352 -- each
                                      JointPushPullGeometry.rb; 352 -- geometry_robot_erase_coplanar_edges
                                      JointPushPullGeometry.rb; 214 -- robot_call_action
                                      JointPushPullGeometry.rb; 177 -- geometry_robot_exec
                                      JointPushPullGeometry.rb; 160 -- geometry_robot
                                      JointPushPullGeometry.rb; 75 -- block in geometry_execute
                                      Lib6Operation.rb; 317 -- call
                                      Lib6Operation.rb; 317 -- step_geometry
                                      Lib6Operation.rb; 278 -- block in yield?
                                      -e; 1 -- call
                                      • fredo6F
                                        Unfortunately, these kind of errors may happen with complex models where the generated offset surface contains overlaps. This is due to the fast method of generation. I have the plan to have a default safe generation method to takeover when there are such errors. Should go in a next release.
                                          martccs
                                          Good afternoon everyone. I am Brazilian and I have read all this post and already tried almost everything here was suggestible. my problem is this: I have windows 8.1 64bit and working with sketchup pro 2014 beixei all files and procedures as indicated and it worked for about 20 minutes and then the Joint push pull bar disappeared.. since then redo all the steps as before to have it installed and do not get any results. Nothing happens. I no longer need to install it and use this to my architectural projects. I'm getting disappointed and frustrated with this and am about to give this application which is great but does not work.
                                          OBS:. I have other plugins in sketchup and whenever I open the program pops up a list of read error indicating several or all plugins.
                                          Thanks in advance,
                                          Marcelo Cordeiro.
                                          • cottyC
                                            cotty
                                            Have you upgraded from a previous version of SU and copied older plugins from there?
                                            my SketchUp gallery
                                            • 30
                                            • 31
                                            • 6 / 31
