    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 863.1k Views 155 Watching
      The [clunky] way to delete a layer through the API is...
      First iterate model.entities and all of the definition.entities, and if they are are assigned the layer we want to delete - say ' tlayer' - then you erase! them.
      Then you iterate through model.layers.to_a - [tlayer], and make a temp_group, and inside that a nested group with a cpoint in it, assign the layer to the nested group, repeat adding a copy of the group and and assigning the next layer to it etc.
      Eventually all layers are 'used', except for the ' tlayer' [even previously unused layers].
      Use model.layers.purge_unused to now purge ' tlayer'.
      Finally use temp_group.erase! to tidy up.
      It will work but as I said it's clunky...
      • fredo6F Offline
        Yes, terribly clunky!
        By the way, I guess that purge_unused has also some other side effects (pure materials, ....).
        • KrisidiousK Offline
          Krisidious
          Yeah I see the layer sometimes. It's never active when I notice it and If I care I delete it. It in no way undermines the massive amount of time JPP has saved me.
          By: Kristoff Rand
            dedmin
            SketchUP 2014 Pro, Win7 64 bit Ultimate Sp1
            This happens when starting to drag and typing offset distance. No error when just drag and drop.
            Video_2014-03-26_081748.wmv
            • fredo6F Offline
              @dedmin
              It seems that this is related to the fact you pick the corner of the face and the API picker does not detect the face.
              I'll see what I can do.
              • pbacotP Offline
                I find that I cannot select with this tool. I activate the tool, (Normal JPP) and go to a smoothed surface (set to surface select), individual faces turn green beneath the cursor. I click and nothing changes. The face under the cursor continues to turn green but nothing stays selected.
                • cottyC Offline
                  cotty
                  @pbacot: did you try it like in the following screencast?
                  @Fredo: is it intended that the middle line gets smoothed in this case?
                  [screenr:2kd1qqny]iDdN[/screenr:2kd1qqny]
                  my SketchUp gallery
                  • pbacotP Offline
                    yeah. I just get the green highlight and green note "click to select faces" I click and nothing changes. On any sort of face in current context.
                    • fredo6F Offline
                      I don't know if I can do anything as it may be a problem with the Mac and SU8.
                      Is it for any model?
                      Is it since an upgrade?
                      Does it work when you stat JPP on a Preselection?
                      • pbacotP Offline
                        Works like that on any model.
                        No particular upgrade.
                        JPP acts as if there is no selection (selection disappears and faces respond to cursor by turning green). After exiting the selection of face appears again.
                        Manana I will reload (I loaded automatically from SUcation Plugin Store.)
                        • jeff hammondJ Offline
                          nope, not that
                          although i don't have what i'm assuming pb's exact configuration is (mavericks + su8 ?)
                          i've tested it on osx10.7.5 with su8 & 2014 --as well as mavericks with 2014
                          i can select just fine on those (as in- i can do the same thing cotty did in the video above with no problems)
                            tidusxx
                            thank you very much Fredo 😉
                            • N Offline
                              ngeier89
                              My office has been using the joint/push pull tool for several months and it has worked flawlessly. Recently my firm upgraded to SketchUp 2014 and downloaded the most recent Joint/Push Pull tool but we have not been able to type in an exact dimension offset when using it. I try to type in a number to offset it but nothing happens. We end up just guessing at the dimension. There are several of us that are SU savvy so I don't believe it's just us because none of us can figure it out. It use to be that you just type in the number you want. Can anyone help? I've watched the youtube videos but it doesn't seem like they have the same issue I have. Thanks.
                              Nathan
                              • fredo6F Offline
                                Nathan
                                Well, a few questions:
                                • do you see the value appear in the VCB?
                                • Do you get an error (in red under the palette button)
                                • does it work manually (by push-pulling with the mouse)?
                                Could you open the Ruby console while doing the tests so that you see potential errors.
                                  StamatisPsarras
                                  I am experiencing similar problems with Jeff.
                                  I am on windows 64but Sketchup 2014
                                  this is what writes in the console
                                  Error: #<NoMethodError: undefined method entityID' for #<Sketchup::Model:0xad00970>> C:/Users/spsarras/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6FacePicker.rb:791:in selection_add_remove_faces'
                                  C:/Users/spsarras/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6FacePicker.rb:744:in selection_validate' C:/Users/spsarras/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6FacePicker.rb:622:in selection_validate_if_add'
                                  C:/Users/spsarras/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:670:in selection_freeze_positions' C:/Users/spsarras/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:1270:in onLButtonDown'
                                  and yes it does that on a fresh/simple model. With all tools in joint push and pull. I also briefly noticed problems on other Fredo tools.
                                  Thank you in advance
                                  • tt_suT Offline
                                    tt_su
                                    Have you disabled Dynamic Components by any chance?
                                    • fredo6F Offline
                                      Yes. weird. It is strange that a Model object has no entityID method defined (which is normally "Model").
                                      This may explain why some users cannot select faces in JPP if this problem occurs.
                                      • tt_suT Offline
                                        tt_su
                                        Yea, Model doesn't inherit from Entity and some methods are not mirrored. It's an annoying inconsistency.
                                          StamatisPsarras
                                          @tt_su
                                          You were right dynamic components was disabled! Now it works, thanks!
                                            StamatisPsarras
                                            I am also getting this error in a complex model.
                                            Any ideas what I should avoid when modeling, so it wont happen again?
                                            Date; 29-Apr-14 18;16;21
                                            An error occured in Joint Push Pull
                                            Error in generation of the geometry
                                            undefined method `smooth?' for nil;NilClass
                                            JointPushPullGeometry.rb; 1107 -- block in geometry_coplanar_edges_overhang
                                            JointPushPullGeometry.rb; 1105 -- each
                                            JointPushPullGeometry.rb; 1105 -- each_with_index
                                            JointPushPullGeometry.rb; 1105 -- geometry_coplanar_edges_overhang
                                            JointPushPullGeometry.rb; 354 -- block in geometry_robot_erase_coplanar_edges
                                            JointPushPullGeometry.rb; 352 -- each
                                            JointPushPullGeometry.rb; 352 -- geometry_robot_erase_coplanar_edges
                                            JointPushPullGeometry.rb; 214 -- robot_call_action
                                            JointPushPullGeometry.rb; 177 -- geometry_robot_exec
                                            JointPushPullGeometry.rb; 160 -- geometry_robot
                                            JointPushPullGeometry.rb; 75 -- block in geometry_execute
                                            Lib6Operation.rb; 317 -- call
                                            Lib6Operation.rb; 317 -- step_geometry
                                            Lib6Operation.rb; 278 -- block in yield?
                                            -e; 1 -- call
                                            • 30
                                            • 31
                                            • 6 / 31
