[Plugin] GOSU v1.1.1
GOSU v1.0.8 Released!
[highlight=#bfff00:2kvzuda1]1.0.8:: 4/30/2013[/highlight:2kvzuda1]
- Set:: Proxy(instances) - Added this to context menu
- Set:: Proxy(box and cline) now use the same action to turn on & off (this is useful to set shortcut key)
Edit/Item/GOSU/Set::Proxy(Box) - Uses same action for turning proxy on & off now
Edit/Item/GOSU/Set::Proxy(Cline) - Uses same action for turning proxy on & off now
Edit/Item/GOSU/Set::Proxy(Instances) - Performs same action as double clicking component to trurn everu instance to proxyCheers!
GOSU v1.0.9 Released!
Made compatible with Extension Warehouse is rules.
Thanks Rafa for your effort. I am extremely busy at work now, but I'll test it for sure.
[pre:300fuwkg]Authors:: Renderiza
Plugin Name:: GOSU
Version:: 1.1.0
Date:: 9/26/2013
Cost:: Free[/pre:300fuwkg]
GOSU v1.1.0 is now available for download.
%(#909090)[What is new:- Smaller web-dialog
- Cursor will start white and if hovers over component that has an action ready it will turn green but if it has nothing then it will turn red.
- Fixed tons of bugs]
Rafa, thanks for the update. I truly appreciate the plugin, especially for proxy features!
I have problems with assigning shortcuts. When I go to "window-preferences-shortcuts" I cannot find "edit/item/GOSU...". There is no such function displayed.
Please help Rafa.
smicha
Please help Rafa.
smicha
I will add that option back soon.
[pre:18kfhjcw]Authors:: Renderiza
Plugin Name:: GOSU
Version:: 1.1.1
Date:: 10/21/2013
Cost:: Free[/pre:18kfhjcw]
GOSU v1.1.1 is now available for download.
%(#909090)[What is new:- Each function will be displayed in "window-preferences-shortcuts"
- There is right click menu as well.]
Works like a charm!
Help Rafa! - please make it work under 2014.
What makes you think it doesn't already work in v2014 ?
I just installed it from the PluginStore and it seems fine -
TIG,
my fault. I tested it on a group instead of a component. It works like a charm. -
It's a pity that it doesn't work on Mac.
Is it not possible to use GOSU in Sketchup Viewer or am I doing something wrong? I am setting components with a URL which works great with Sketchup Pro but doesn't in Viewer.
Mike
Thanks for this, its a great tool! I use it on construction projects to link in structural drawings that are related to the item you are viewing. This works great when we keep our models on one computer, but if I transfer the model and files to another computer it won't stay linked to the files I selected before. Is there a way to go in a quickly change the file location maps? or a way to keep it linked when it gets loaded up to another computer? I hand over models to our guys building, so they can get a deeper understanding of the building.
Good afternoon Renderiza
Thanks for you beautiful program
I would like to share my drawing with linked photos with other persons. But the photos have an absolute link to my hard-drive so when transferring the drawing and photos to another PC the links will no longer work. Is there a way that the location for the photos can be made relative to the location where the drawing is stored ?
Thanks in advance,
Rene
This is a great tool! is there anyway the information saved to a component be retained when saving out to a component library? I have loads of technical components that my team use to build with and if would be great if the GOSU info was there when a component was pulled in?
