    [Plugin] GOSU v1.1.1
    69 Posts 16 Posters 74.5k Views 16 Watching
      smicha
      I'll test it ASAP Rafa and let you know. Thank for such fast correction.
      • renderizaR
        renderiza
        GOSU v1.0.8 Released!
        [highlight=#bfff00:2kvzuda1]1.0.8:: 4/30/2013[/highlight:2kvzuda1]
        • Set:: Proxy(instances) - Added this to context menu
        • Set:: Proxy(box and cline) now use the same action to turn on & off (this is useful to set shortcut key)
        Edit/Item/GOSU/Set::Proxy(Box) - Uses same action for turning proxy on & off now
        Edit/Item/GOSU/Set::Proxy(Cline) - Uses same action for turning proxy on & off now
        Edit/Item/GOSU/Set::Proxy(Instances) - Performs same action as double clicking component to trurn everu instance to proxy
        Cheers!
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • renderizaR
          renderiza
          GOSU v1.0.9 Released!
          Made compatible with Extension Warehouse is rules.
            smicha
            Thanks Rafa for your effort. I am extremely busy at work now, but I'll test it for sure.
            • renderizaR
              renderiza
              [pre:300fuwkg]Authors:: Renderiza
              Plugin Name:: GOSU
              Version:: 1.1.0
              Date:: 9/26/2013
              Cost:: Free[/pre:300fuwkg]
              GOSU v1.1.0 is now available for download.
              %(#909090)[What is new:
              • Smaller web-dialog
              • Cursor will start white and if hovers over component that has an action ready it will turn green but if it has nothing then it will turn red.
              • Fixed tons of bugs]
                smicha
                Rafa, thanks for the update. I truly appreciate the plugin, especially for proxy features!
                  smicha
                  I have problems with assigning shortcuts. When I go to "window-preferences-shortcuts" I cannot find "edit/item/GOSU...". There is no such function displayed.
                  Please help Rafa.
                  smicha
                  • renderizaR
                    renderiza
                    Please help Rafa.
                    smicha
                    I will add that option back soon. πŸ‘
                    • renderizaR
                      renderiza
                      [pre:18kfhjcw]Authors:: Renderiza
                      Plugin Name:: GOSU
                      Version:: 1.1.1
                      Date:: 10/21/2013
                      Cost:: Free[/pre:18kfhjcw]
                      GOSU v1.1.1 is now available for download.
                      • Each function will be displayed in "window-preferences-shortcuts"
                      • There is right click menu as well.]
                        smicha
                        Works like a charm! 😍
                          smicha
                          Help Rafa! - please make it work under 2014.
                            What makes you think it doesn't already work in v2014 ?
                            I just installed it from the PluginStore and it seems fine πŸ˜•
                              smicha
                              TIG,
                              my fault. I tested it on a group instead of a component. It works like a charm.
                                mxd1970
                                It's a pity that it doesn't work on Mac.
                                • C
                                  cleavermike
                                  Is it not possible to use GOSU in Sketchup Viewer or am I doing something wrong? I am setting components with a URL which works great with Sketchup Pro but doesn't in Viewer.
                                  Mike
                                    Mr Timberdude
                                    Thanks for this, its a great tool! I use it on construction projects to link in structural drawings that are related to the item you are viewing. This works great when we keep our models on one computer, but if I transfer the model and files to another computer it won't stay linked to the files I selected before. Is there a way to go in a quickly change the file location maps? or a way to keep it linked when it gets loaded up to another computer? I hand over models to our guys building, so they can get a deeper understanding of the building.
                                      reneschepers
                                      Good afternoon Renderiza
                                      Thanks for you beautiful program
                                      I would like to share my drawing with linked photos with other persons. But the photos have an absolute link to my hard-drive so when transferring the drawing and photos to another PC the links will no longer work. Is there a way that the location for the photos can be made relative to the location where the drawing is stored ?
                                      Thanks in advance,
                                      Rene
                                      • O
                                        Oly80
                                        This is a great tool! is there anyway the information saved to a component be retained when saving out to a component library? I have loads of technical components that my team use to build with and if would be great if the GOSU info was there when a component was pulled in?
                                        • 4 / 4
