    Line Color Editor?
    14 Posts 9 Posters 17.9k Views 9 Watching
      @donovanweberdesign said:
      Is there any way around this without going through and making all the lines in all the other groups black again?
      Have a look at the CleanUp Plugin. (Please, carefully read the installing instructions as other plugins are also needed).
      First run the plugin. Unless you also applied materials to whole groups/components, all will turn into the default black. Then paint your edges selectively.
        DonovanWeberDesign
        Beautiful. Notice the grey lines! Thanks!
        http://donovanweberdesign.com/personal files/lines.jpg
          Now you can easily colour edges "en mass" if you simply colour the group/component they are in. If the faces have a different material, the group colour will only display on the edges.
          • gillesG Offline
            gilles
            In an another way, if you set style to color by material then set view/faces style/wireframe.
            Select all desired edges, right click, entity info, click the color window then choose your color.
            Uncheck wireframe.
            • brookefoxB Offline
              brookefox
              Thanks for the tips. For unfaced edges (in my case naked edges componentized and used for 'grass'), only Alan's method seems to work:
              Model > Edges tab of the styles dialog and change the style from All the Same to Color by Material in the drop-down at the bottom
              ~ Brooke
              • masterpaulM Offline
                masterpaul
                Is there a plugin that could turn all selected components and there edges to black? Wireframe doesnt do the job. And when you have many components and sub components things get messy.
                  Why in the world do you need a plugin when the Paint Bucket tool would handle it?
                    masterpaul
                    In more complex model, the wireframe also selects faces. Also it gets more complicated with subcomponents. Lets say you want this component with many lines to be red (its complex and has many subcomponents). There isnt really a way to colour all the lines without opening each individual component and selected the line?
                    • jeff hammondJ Offline
                      ThruPaint by Fredo will help you.. (it's part of his FredoTools plugin suite)
                      i don't think you can select all the components then have them automatically update to all black edges but if you set up thruPaint as shown in the image, you'll be able to click on any edge and all connecting edges will be painted the chosen color.. the selection works through groups/components so you don't have to open each one individually.
                      click-> bigger
                        You certainly don't have to select faces when selecting the edges in Wireframe. It's up to you and depends on how you use the Select tool.
                        Jeff's pointed you in the right direction, though.
                        • BoxB Offline
                          Something like this Dave?
