    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 322.0k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      @solarwisellc said:
      I installed v1.0.4. and I am getting the same results of unresponsiveness. I went through and organised everything and after saving, closing the file and restarting it, it became unresponsive. I have reorganized my layers so many times without them staying active and/or organised that I am about to give up on your layers panel for this drawing.
      I may have found what's causing this issue. Not 100% sure, though.
      I'll release the fix soon.
      @bob james said:
      What's more, sometimes undo does work. 😒
      Hmm, so not every time? Do you know in which case it doesn't happen? Or in which case it happens?
      Does it happen in every file?
        jiminy-billy-bob
        New version 1.0.5 !
        Changelog :
        • Fixed major issues that would freeze Layers Panel, or delete every groups
        • Added API for rendering
        Download in the plugin store !
        • Bob JamesB Offline
          Bob James
          For large files (e.g., >100MB): Yes, but not on every attempt to undo!!
            jiminy-billy-bob
            Could you send me one of those files? (Maybe delete the geometry, if this doesn't affect the behaviour)
            • gullfoG Offline
              gullfo
              also noted: when i first loaded the latest version, i got an error about id being incorrect and used the "fix" link provided. that seemed ok, but then i noticed that the name-order of the layers is wrong - about 1/2 are ok, and 1/2 are not - i was assuming the order of the layers follows the regular layer when first initialized? an ability to sort the layers by name or groups would be handy ☀
              otherwise it seems like i would manually need to re-order them...
              Glenn
              http://www.runnel.com
              • JQLJ Offline
                JQL
                Hi Jiminy,
                I have a minor issue for you here. Win 7 SU 2014.
                www.casca.pt
                Visit us on facebook!
                  mrdcon
                  Love the plugin but I keep getting this error message!
                    jiminy-billy-bob
                    Yes, this is normal. Previous versions were causing an issue, so this new version is fixing it. But this should happen only once.
                    Whow, this is weird. Does this happen in the same file that was previously causing you issues? Do you know how to reproduce this?
                    Does this happen in every file? Are you running the last version of Layers Panel? (v1.0.5)
                    • SolarwiseLLCS Offline
                      SolarwiseLLC
                      Jiminy, Thank you for the 1.0.5 release. The Layer Panel is working much better now. I appreciate your willingness to keep at in order to provide a great plugin.
                      • icedkaszI Offline
                        icedkasz
                        I'm hoping to add this extension to my toolset, but I'm having some issues (see attached image). It's very strange.
                        If I open up Sketchup2014 first, then click File > Open and find my model, it works just fine.
                        If I open the file directly from my windows explorer (locating sketchup\models\model.skp and double clicking it), I get the error shown.
                        For some reason, opening the file directly causes problems.
                        I found a way around it, though: if I open up Sketchup2014, then IMPORT my model.skp, it works fine. I can save it as model-2.skp, close sketchhup, then open model-2.skp directly, and it continues to work just fine. Very strange. This is SORT of a workaround, but if I try to open any of my other dozens of sketchup files directly, I get the error message. I've tried deleting the files from my Roaming folder, then reinstalling. No luck. Any advise?
                        Also as a secondary question, I'll have multiple people using this extension (if I can get it working). We'll be accessing the file from a shared server. If person A adds a Layers Panel group to the model, then saves and quits, can person B open up the model and find that group? Is Layers Panel adding metadata to the model or something?
                          jiminy-billy-bob
                          icedkasz > Your first issue has been discussed many times on this thread. It's a Sketchup issue, I can't do anything about it. We need to wait for Trimble to fix it.
                          As for your second question: Yes, all the data is stored within the file, so you can give it to whoever you want, and they'll see all you groups etc.
                            bimbachi
                            I have a problem :
                            • when adding keyshortcut to LayerPanel tool palet it adds shortcut to SketchucationPluginStore tool palet this same shortcut
                            • and as result to use of shortcut, command opens SketchucationPluginStore tool palet!
                              bimbachi
                              question:
                              is it possibul that LayerPanel window position would be kept as last open location on the screen? ❓
                                jiminy-billy-bob
                                @bimbachi said:
                                I have a problem :
                                Weird, it works fine for me on windows. Can another mac user confirm this?
                                What happens if you disable SCtools?
                                @bimbachi said:
                                question:
                                I haven't figured how to do that on Mac, it works fine on windows...
                                  jiminy-billy-bob
                                  New version 1.0.6 !
                                  Changelog :
                                  • Improved "add layer" menu (Hold-down the add layer button), based on Jim's great "Add layer" plugin
                                  • Fixed "Win32api" error when opening a file from a different drive than sketchup's. (Thanks to Dan Rathbun and TIG)
                                  • Fixed layer colors vanishing when switching scenes
                                  Credit goes to Jim for the original "Add layer" UI idea : http://sketchucation.com/plugin/832-jf_add_layer
                                  Thanks to him for allowing me to embed it in Layers Panel
                                    Jim
                                    Seems like you un-published it because it does not show up in the Plugin Store.
                                    • TIGT Online
                                      With the new authors' area once you start editing your entry it becomes 'unpublished'.
                                      After updating anything you must click the big button near the top to [re]publish it...
                                      Go back in and do that, and it should reappear in the listings again...
                                        jiminy-billy-bob
                                        Uh, I did, but I guess I modified something else afterward.
                                        It should be fine now.
                                        • wind-borneW Offline
                                          wind-borne
                                          @bimbachi said:
                                          I have a problem :
                                          @bimbachi said:
                                          question:
                                          I am assuming what you really want is a shortcut to the layers panel itself and not the toolbar(Palette) icon.
                                          Within SU shortcuts you can open layer panel window in Window menu but it won't toggle.
                                          The most functional setup is in System Preferences as you can toggle window with shortcut. You do need to restart after setting or else merely toggles icon.
                                          "To read between the lines was easier than to follow the text."OSX 10.11.6
                                          %(#BF80BF)[SU 8 pro
                                          • JQLJ Offline
                                            JQL
                                            It happened in the same file, I don't know how to reproduce it but it happened more than once. I will work on that same file this week so I'll let you know if anything strange happens.
                                            Thanks again and best regards,
                                            JQL
                                            www.casca.pt
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 33
                                            • 34
                                            • 25 / 34
