    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
      amis
      Hi, Jiminy! There's a problem when I use cyrillic font to rename new layer - some codes appear instead of cyrillic letters. Although it didn't happen before (win XP, SU 2013) Got any ideas?
        amis
        @jiminy-billy-bob said:
        amis > You're not the first to tell me this. I forgot, thanks to remind me, I'll take a loot at it.
        So if I understand right, it works fine on winXP with SU2014, what is yout windows version now, and SU version?
        we didn't understand each other properly) Win XP, SU 2013 that's for now
        • jiminy-billy-bobJ
          jiminy-billy-bob
          New version 1.0.4 !
          Changelog :
          • Added better feedback when sorting multiple layers/groups at once
          • Added support for Podium V2+
          • Fixed support for Indigo
          Download in the plugin store !
          • kenK
            ken
            @tt_su said:
            @sadyo said:
            Seem like the LP 1.0.3 have problems when I updated TT_Lib 2.9.9 ❓
            That's a co-incidence. When you launch SketchUp via a SKP file that is located on a drive different from where SketchUp is installed something gets messed up in SketchUp Ruby. Launch SketchUp first, then open your file - that's the workaround until we release a fix.
            I open Sketchup files on my travel USB HD from XnView all the time. So are you telling me, the safest way to open Sketchup files is from Sketchup and not a viewer?
            IF so, this could explain a lot.
            Thanks for your reply.
            Ken
            • tt_suT
              tt_su
              Yes, if you use plugins then until we get the fix released you're better of starting SketchUp first, then open the files from SketchUp. Apologies for the inconvenience.
              • jiminy-billy-bobJ
                jiminy-billy-bob
                Do you have an ETA for the fixed release?
                • tt_suT
                  tt_su
                  Afraid not. WIP.
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    Layers Panel reached 300 unique daily users
                    (as far as I can see, there are probably more if there are multiple users on a single IP adress)
                    A big thanks to all of you to motivate me pushing this plugin further and further! πŸ˜„
                    It wouldn't be what it is today if not thanks to all your feedback and ideas.
                    http://i.imgur.com/55yXgRP.png
                    • Bob JamesB
                      Bob James
                      I still cannot undo without this appearing keeping the undo from happening:
                      Undo Layers Panel ID
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        Every time you undo?
                        • SolarwiseLLCS
                          SolarwiseLLC
                          I installed v1.0.4. and I am getting the same results of unresponsiveness. I went through and organised everything and after saving, closing the file and restarting it, it became unresponsive. I have reorganized my layers so many times without them staying active and/or organised that I am about to give up on your layers panel for this drawing.
                          • Bob JamesB
                            Bob James
                            Ctrl-z or Alt-backspace
                            Have to repeat many times before undo happens: most times undo never happens.
                            What's more, sometimes undo does work. πŸ˜’
                            • jiminy-billy-bobJ
                              jiminy-billy-bob
                              I may have found what's causing this issue. Not 100% sure, though.
                              I'll release the fix soon.
                              Hmm, so not every time? Do you know in which case it doesn't happen? Or in which case it happens?
                              Does it happen in every file?
                              • jiminy-billy-bobJ
                                jiminy-billy-bob
                                New version 1.0.5 !
                                Changelog :
                                • Fixed major issues that would freeze Layers Panel, or delete every groups
                                • Added API for rendering
                                • Bob JamesB
                                  Bob James
                                  For large files (e.g., >100MB): Yes, but not on every attempt to undo!!
                                  • jiminy-billy-bobJ
                                    jiminy-billy-bob
                                    Could you send me one of those files? (Maybe delete the geometry, if this doesn't affect the behaviour)
                                    • gullfoG
                                      gullfo
                                      also noted: when i first loaded the latest version, i got an error about id being incorrect and used the "fix" link provided. that seemed ok, but then i noticed that the name-order of the layers is wrong - about 1/2 are ok, and 1/2 are not - i was assuming the order of the layers follows the regular layer when first initialized? an ability to sort the layers by name or groups would be handy β˜€
                                      otherwise it seems like i would manually need to re-order them...
                                      Glenn
                                      http://www.runnel.com
                                      • JQLJ
                                        JQL
                                        Hi Jiminy,
                                        I have a minor issue for you here. Win 7 SU 2014.
                                        www.casca.pt
                                        Visit us on facebook!
                                          mrdcon
                                          Love the plugin but I keep getting this error message!
                                          • jiminy-billy-bobJ
                                            jiminy-billy-bob
                                            Yes, this is normal. Previous versions were causing an issue, so this new version is fixing it. But this should happen only once.
                                            Whow, this is weird. Does this happen in the same file that was previously causing you issues? Do you know how to reproduce this?
                                            Does this happen in every file? Are you running the last version of Layers Panel? (v1.0.5)
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 33
                                            • 34
                                            • 25 / 34
