    [Plugin] SketchUcation Tools 2.6
    212 Posts 58 Posters 138.9k Views 58 Watching
    • pyrolunaP Offline
      pyroluna
      I was wondering about the update system; it's not working as I would expect.
      I have some plugins by Fredo installed; these come with its own update checker. However, I don't really like the way it pops up every so many days. It's a bit intrusive - especially if I have to teach. Pupils are easily spooked by an extra toolbar or window.
      All that aside, however, I still leave it on, since it regularly shows updates that do not show in the SketchUcation Plugin store. I can see that my installed Fredo-plugins have different version numbers from the ones in the list, but still there is no update button, and it doesn't show up in the updates list.
      So eventually I clicked on through until a button 'install extension' became visible. This is a bit counter-intuitive though.
        Did you install them from the PluginStore initially?
        We can only track your activity in the PluginStore since it's launch. Anything you do outside that environment is outta our control.
        We could add the ability to track your every movement. #youarebeingwatched
        • mitcorbM Offline
          mitcorb
          Hi, pyroluna:
          I don't know if this works, or if you really want to do this, but Fredo's Check for updates has an interval box ordinarily set at 15 days.
          Window>Libfredo Settings>Check plugins for update: the interface appears, and at the bottom of the frame is the input box for the interval. Maybe set to zero, or 99?
          I could not find in the information manual anything, nor any setting in Program file subfolders Plugins, but I have seen registry titles relating to this during routine security scans on my system.
          I do not advocate messing in the registry, just to say.
            GĂĄbor
            The update system in 2.5.1 compares your user's latest downloaded plugin version to the curent available version in the store. If there is any difference the plugin will show up in the update list.
            So:
            1. The plugin won't show up in the update list if you haven't downloaded the prevous version from the PluginStore.
            2. The plugin won't show up in the update list if you have updated it on an other device. (As in this case the latest download by you is up-to date)
            We will refine this in the next (2.6) version by adding your device ID to the comparasion.
              Updated to 2.6.0
              4x times faster downloads
              New Bundles features in My SetUp
              Tons of tweaks and bugfixes
              Anyone on 2.5 has until the end of the week to upgrade before we shut it down.
              • cottyC Offline
                cotty
                Love the new bundle feature!
                my SketchUp gallery
                • mitcorbM Offline
                  mitcorb
                  I have downloaded for SU2014. This would also be appropriate for SU8, correct?
                    @Tim
                    Yes, v8, v2013 and v2014
                    Install in all versions to get the full benefit of the bundles going forward
                    • F Offline
                      function
                      not sure if this has been brought up -
                      is there a way to have it so that when you disable an extension - it will also disable the plugin? Sometimes they names are different and its difficult to find an extension and its corresponding plugin... or anyway it can be frustrating.
                      • Dan RathbunD Offline
                        Dan Rathbun
                        Whilst autoinstalling v2.6 in SU2013, my Comodo Security popped up twice wanting to partially sandbox a VBS script with a numerical name.
                        The two files are no longer in the "Temp/SCF" folder.
                        Is this normal ?
                        I'm not here much anymore.
                          Perfectly
                            Dan Rathbun
                            v 2.6.0
                            On SketchUp v8 upon starting I get in the console:
                            %(#004000)[(eval):3119: warning: parenthesize argument(s) for future version (eval):3142: warning: parenthesize argument(s) for future version]
                            On ALL versions 8 .. 14 upon starting I have do deal with multiple VBS sandbox popups, and new entries into my Comodo sandbox file list (which don't exist.)
                            (1) It is a major PITA.
                            (2) The VBS file names could have been something to indicate they belong to the SCF Plugin Store extension (instead of some meaningless number.)
                              I'm not familiar with the VBS additions in this release except that they are necessary for older SU versions.
                              I think TIG will be able to shed more light on your alerts.
                              We're they occurring on 2.5.2 beta?
                                Dan Rathbun
                                No I did not see them occurring before.
                                I will have to turn the extension off, and only use it "on demand".
                                  Cool
                                  Sent from my iPad
                                    @Dan
                                    We had some reports about vbs warnings in earlier beta tests but code adjustments were made and there were no further reports.
                                    I am surprised about the 'parenthesize' warning in v8 - I can't think of any arguments passed in this code-set without () ?
                                    Can't you set up an 'exception' for your over zealous 'Commodo' security - to skip vbs files, 'by folder' [.../Temp/SCF] ?
                                    http://help.comodo.com/topic-72-1-451-4758-.html
                                    shows examples using will-cards etc.
                                    So a pattern something like *\Temp\SCF\*.vbs should work ?
                                    These vbs will always run in v8/2013...
                                    The SCFapi in v2014 can use Ruby2 [open-uri etc] for most of it 'communications', but earlier versions rely on vbs scripts using 'XMLHTTP' etc on PC [and .command using 'curl' for MAC].
                                    These tiny vbs scripts are written to the .../Temp/SCF folder to ping data-packets to the SCF server and sometimes receive a response.
                                    These scripts are named "f_nnnnnnn.vbs" where the "nnnnnnn|" is a random integer.
                                    This is to ensure separation between several such pings that might run all but contemporaneously.
                                    Any txt file they might make to hold any received data has a matching name.
                                    On the creation of the txt file the data is read and the two files are deleted a few ms later.
                                    That is why they no longer exist when you look for them.
                                    In case of a rare 'left over' file remaining, on load the SCFapi also purges the ...Temp/SCF folder.
                                    Other vbs files are used by other modules to extract the plugin files etc from RBZ archives [renamed ZIP] where the destination folder is not the default Plugins folder [i.e. a custom-plugins folder has been added to the $:]
                                    So even if you disable the SCFapi from loading you will get continuing vbs nags when installing into custom=plugins folders...
                                      Dan Rathbun
                                      No tried 6 ways to Sunday to setup exclusions. Does not work as advertised.
                                      Like I say... I only heed SCF Tools when manipulating plugins or extensions.
                                      I'll turn it off.
                                        @Dan
                                        You are the only user to report these issues...
                                        I cannot believe it is insoluble 😕
                                        • kuponoK Offline
                                          kupono
                                          I'm getting load errors after installing sketchucation tools 2.6. Could be a coincidence. This occurs when I open an .skp by double clicking it. It does not occur when I load SU by double-clicking the .exe or shortcut, then opening the model. (Win8, SU Pro 2014)
                                          Thx
                                          Error: #<LoadError: cannot load such file -- open-uri>
                                          c:/users/drew/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:76:in require' c:/users/drew/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:76:in module:SCFapi'
                                          c:/users/drew/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:22:in <main>' C:/Users/Drew/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in eval'
                                          C:/Users/Drew/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in load' C:/Users/Drew/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in block in <top (required)>'
                                          C:/Users/Drew/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:14:in each' C:/Users/Drew/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:14:in <top (required)>'
                                          D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' D:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                                          C:/Users/Drew/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:189:in register_extension' C:/Users/Drew/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:189:in module:SCF'
                                          C:/Users/Drew/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:16:in `<top (required)>'
                                          • BoxB Offline
                                            This thread looks similar.
                                            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57121
                                            • 11
                                            • 6 / 11
