    Fishing net modeling
    131 Posts 12 Posters 24.1k Views 12 Watching
    • W Offline
      willipop
      Is there a way to transform wireframes to edges ?
        How about posting your SKP file so we can actually see what you've got?
        • BoxB Offline
          Just as a start, this is a lattice made quickly with tigs tool.
          • W Offline
            willipop
            Very nice Box !
            Can you set the thickness of the lattice ?
            I added a quick test (sketchup v8) but I'm using 2014.
            fishnettest.skp
            • BoxB Offline
              Yes you can change the thickness.
              But you need to think about the complexity of the geometry you want to create. A huge complex net made in one piece will bring any computer to it's knees.
              If you want to do it make it in repeatable sections as components.
              Or consider using a nice net texture. The image below is one of the default fencing textures.
              • W Offline
                willipop
                I see ! The problem with the textrure is it won't cast the shadows !?
                • cottyC Offline
                  cotty
                  Example how to use Artisan to create the basic shape for texturing...
                  my SketchUp gallery
                  • W Offline
                    willipop
                    Super cool cotty ! how did you pass from the middle shape to 3rd shape at the very right ? Is this actual edges ?
                    • W Offline
                      willipop
                      @ Cotty, can you upload your file ?
                      • cottyC Offline
                        cotty
                        I followed Boxs suggestion with the simple fence texture...
                        The model is attached.
                        netartisan_cotty.skp
                        my SketchUp gallery
                        • W Offline
                          willipop
                          I'm wondering if there is a way to turn hidden geometry lines into edges !?
                          • olisheaO Offline
                            olishea
                            Yes, unsoften them. Select all and slide the soften edges slider. Uncheck both the boxes too.
                            oli
                            • W Offline
                              willipop
                              Thx Oli ! I noticed we can change the weight of the edges in the style option but it is just for the display and it do not affect the weight of the shadows casted. Is there any other way too make the edges solid ?
                              • W Offline
                                willipop
                                Here is a try I did today.
                                1- Sarted with a rectangle
                                2- Applyed several time the subdivide selection tool from artisan
                                3- Applyed the subdivide and smooth tool from artisan
                                4- Turned on hidden line and selected style wireframe
                                5- Selected the lines and get rid of the smoothing edges to get edges
                                6- copied those edges
                                7- Finally I used tube to cylinder plugin and It took 10 min approx of working progress
                                I'll have no choice to go with this kind of work flow if I don't find anything better than this. End of semester is coming fast πŸ˜›
                                • olisheaO Offline
                                  olishea
                                  there is also latticemaker and windowizer.
                                  oli
                                  • BoxB Offline
                                    I think you are going the wrong way and making life hard for yourself.
                                    This took no time at all using tig's tool.
                                    A bit of thought and a few lines and you can make something very complex.
                                    Make a few pieces that fit together, scale some, array some......
                                    Quick Net.skp
                                    • olisheaO Offline
                                      olishea
                                      nice
                                      oli
                                        DOD3R
                                        you should check Ferrari sketch plugin
                                        its actually special program fro tensile structures
                                        D.
                                        • BoxB Offline
                                          Ferrari is a good tool for tensile, but you can spend a lot of time getting it to the shape you want and then you need to separate out the profiles to make your ropes.
                                          This was done with 3 beziers curves on a square, then tig's Extrude edges to lattice to produce the web, then lines to tubes.
                                          All in all it almost took longer to write this than to make it.
                                          • W Offline
                                            willipop
                                            Very nice ! The shape of it looks more square than round. It will play with this method tonight to see what I can do. Many thanks !
                                            • 1 / 7
