    Fishing net modeling
    131 Posts 12 Posters 26.2k Views 12 Watching
    • W
      willipop
      I'm having trouble with selecting the profile curve ... should I still work in wireframe style while using this tool ?
      • W
        willipop
        Is there a way to transform wireframes to edges ?
          How about posting your SKP file so we can actually see what you've got?
          • BoxB
            Just as a start, this is a lattice made quickly with tigs tool.
            • W
              willipop
              Very nice Box !
              Can you set the thickness of the lattice ?
              I added a quick test (sketchup v8) but I'm using 2014.
              fishnettest.skp
              • BoxB
                Yes you can change the thickness.
                But you need to think about the complexity of the geometry you want to create. A huge complex net made in one piece will bring any computer to it's knees.
                If you want to do it make it in repeatable sections as components.
                Or consider using a nice net texture. The image below is one of the default fencing textures.
                • W
                  willipop
                  I see ! The problem with the textrure is it won't cast the shadows !?
                  • cottyC
                    cotty
                    Example how to use Artisan to create the basic shape for texturing...
                    my SketchUp gallery
                    • W
                      willipop
                      Super cool cotty ! how did you pass from the middle shape to 3rd shape at the very right ? Is this actual edges ?
                      • W
                        willipop
                        @ Cotty, can you upload your file ?
                        • cottyC
                          cotty
                          I followed Boxs suggestion with the simple fence texture...
                          The model is attached.
                          netartisan_cotty.skp
                          my SketchUp gallery
                          • W
                            willipop
                            I'm wondering if there is a way to turn hidden geometry lines into edges !?
                            • olisheaO
                              olishea
                              Yes, unsoften them. Select all and slide the soften edges slider. Uncheck both the boxes too.
                              oli
                              • W
                                willipop
                                Thx Oli ! I noticed we can change the weight of the edges in the style option but it is just for the display and it do not affect the weight of the shadows casted. Is there any other way too make the edges solid ?
                                • W
                                  willipop
                                  Here is a try I did today.
                                  1- Sarted with a rectangle
                                  2- Applyed several time the subdivide selection tool from artisan
                                  3- Applyed the subdivide and smooth tool from artisan
                                  4- Turned on hidden line and selected style wireframe
                                  5- Selected the lines and get rid of the smoothing edges to get edges
                                  6- copied those edges
                                  7- Finally I used tube to cylinder plugin and It took 10 min approx of working progress
                                  I'll have no choice to go with this kind of work flow if I don't find anything better than this. End of semester is coming fast πŸ˜›
                                  • olisheaO
                                    olishea
                                    there is also latticemaker and windowizer.
                                    oli
                                    • BoxB
                                      I think you are going the wrong way and making life hard for yourself.
                                      This took no time at all using tig's tool.
                                      A bit of thought and a few lines and you can make something very complex.
                                      Make a few pieces that fit together, scale some, array some......
                                      Quick Net.skp
                                      • olisheaO
                                        olishea
                                        nice
                                        oli
                                          DOD3R
                                          you should check Ferrari sketch plugin
                                          its actually special program fro tensile structures
                                          D.
                                          • BoxB
                                            Ferrari is a good tool for tensile, but you can spend a lot of time getting it to the shape you want and then you need to separate out the profiles to make your ropes.
                                            This was done with 3 beziers curves on a square, then tig's Extrude edges to lattice to produce the web, then lines to tubes.
                                            All in all it almost took longer to write this than to make it.
                                            • 1 / 7
