    Fishing net modeling
    131 Posts 12 Posters 20.5k Views 12 Watching
    • cottyC Offline
      cotty
      Do you habe an example picture of the desired net?
      my SketchUp gallery
      • W Offline
        willipop
        Not as precise as this but here is the big picture :
        • BoxB Offline
          Have a look at Tig's extrusion tools, particularly Extrude Edges by Rails to Lattice.
          • W Offline
            willipop
            I have this plugin, I'll try it right away ! Could tell me what is a lattice ?
            Thanks for the help guys !
            • W Offline
              willipop
              I'm having trouble with selecting the profile curve ... should I still work in wireframe style while using this tool ?
              • W Offline
                willipop
                Is there a way to transform wireframes to edges ?
                  How about posting your SKP file so we can actually see what you've got?
                  • BoxB Offline
                    Just as a start, this is a lattice made quickly with tigs tool.
                    • W Offline
                      willipop
                      Very nice Box !
                      Can you set the thickness of the lattice ?
                      I added a quick test (sketchup v8) but I'm using 2014.
                      fishnettest.skp
                      • BoxB Offline
                        Yes you can change the thickness.
                        But you need to think about the complexity of the geometry you want to create. A huge complex net made in one piece will bring any computer to it's knees.
                        If you want to do it make it in repeatable sections as components.
                        Or consider using a nice net texture. The image below is one of the default fencing textures.
                        • W Offline
                          willipop
                          I see ! The problem with the textrure is it won't cast the shadows !?
                          • cottyC Offline
                            cotty
                            Example how to use Artisan to create the basic shape for texturing...
                            my SketchUp gallery
                            • W Offline
                              willipop
                              Super cool cotty ! how did you pass from the middle shape to 3rd shape at the very right ? Is this actual edges ?
                              • W Offline
                                willipop
                                @ Cotty, can you upload your file ?
                                • cottyC Offline
                                  cotty
                                  I followed Boxs suggestion with the simple fence texture...
                                  The model is attached.
                                  netartisan_cotty.skp
                                  my SketchUp gallery
                                  • W Offline
                                    willipop
                                    I'm wondering if there is a way to turn hidden geometry lines into edges !?
                                    • olisheaO Offline
                                      olishea
                                      Yes, unsoften them. Select all and slide the soften edges slider. Uncheck both the boxes too.
                                      oli
                                      • W Offline
                                        willipop
                                        Thx Oli ! I noticed we can change the weight of the edges in the style option but it is just for the display and it do not affect the weight of the shadows casted. Is there any other way too make the edges solid ?
                                        • W Offline
                                          willipop
                                          Here is a try I did today.
                                          1- Sarted with a rectangle
                                          2- Applyed several time the subdivide selection tool from artisan
                                          3- Applyed the subdivide and smooth tool from artisan
                                          4- Turned on hidden line and selected style wireframe
                                          5- Selected the lines and get rid of the smoothing edges to get edges
                                          6- copied those edges
                                          7- Finally I used tube to cylinder plugin and It took 10 min approx of working progress
                                          I'll have no choice to go with this kind of work flow if I don't find anything better than this. End of semester is coming fast πŸ˜›
                                          • olisheaO Offline
                                            olishea
                                            there is also latticemaker and windowizer.
                                            oli
                                            • 1 / 7
