    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
    • jiminy-billy-bobJ
      jiminy-billy-bob
      pibuz > It's indeend broken with Indigogo for some reason. I'll fix it.
      amis > You're not the first to tell me this. I forgot, thanks to remind me, I'll take a loot at it.
      So if I understand right, it works fine on winXP with SU2014, what is yout windows version now, and SU version?
      • C
        ckho1985
        the update work great on Mac now. thanks!!
        I am sure you are award of it… many have request a 'sort by name' function on the table. so we could navigate layers easily.
        thanks once more
        • U
          unclex
          sorry jiminy
          I know it's not your fault
          but I was so regretful for cannot using your wonderful plugins
          • jiminy-billy-bobJ
            jiminy-billy-bob
            @unclex said:
            sorry jiminy
            Don't worry, no hard feelings.
            While waiting for a fix, you can start Sketchup and then open your file from SU. It should work fine.
            • SolarwiseLLCS
              SolarwiseLLC
              Jiminy-Billy-Bob,
              First off let me say I love this plugin.
              Recently, my layer's panel has become unresponsive in one of my drawings. (This is true for SU13 and SU14) Unresponsive in that the layers do not toggle on or off anymore. This one file was working. I saved multiple copies of it and now none of them work properly. Other files/drawings work. I even created a new drawing. Created a new layers list and pasted the original drawing in layer by layer. This worked until I closed the drawing and restarted my computer. Is there a a easy fix? I could have moved or removed a file when I was trying out SU 14.
              Layers Panel 1.03
              I'm using SU 13, but have 14 installed
              Windows 8
              I have other layer managing plugin installed (Conflict?) They aren't interfering with my other files.
              • jiminy-billy-bobJ
                jiminy-billy-bob
                Could you send me the file by PM?
                What are the other layer managing plugins?
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  @solarwisellc said:
                  So something strange has happen since I posted. I continued to work on the drawing "DD1", but stopped using the Layer Panel plugin. I was just using the Layers Window. After a while I checked the Layers Panel and it had started working again. I noticed all the folders had been removed and it was now just a list of layers.
                  Drawing DD1.1 still shows the folders and is still unresponsive.
                  Addition layer plugins:
                  Layers Manager (I think that is it)
                  I'm not sure what caused the issue, but here is how to solve it:
                  • Install Aerilius' AttributeInspector
                  • Open it
                  • Click on "jbb_layerspanel"
                  • Delete all the " group[22]=null&group[23]=22&layer...." stuff (Just select and delete)
                  • Reopen Layers Panel, you should loose all the sorting and groups, but it should work fine.
                  http://i.imgur.com/xqYYqWb.png
                  • SolarwiseLLCS
                    SolarwiseLLC
                    • Open it
                    Thanks. I will try this. Will I be able to regroup afterwards?
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      Of course, LP should behave normally after this. It's a fresh start.
                      • sadyoS
                        sadyo
                        Hi mr.Bob
                        Seem like the LP 1.0.3 have problems when I updated TT_Lib 2.9.9 ❓
                        http://s30.postimg.org/mgwf0y5fl/hh2.jpg
                        I'm using Sketchup 2014 pro_Win8.1-64bit
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          sadyo > Please see:
                          @tt_su said:
                          @vremennyi said:
                          Or is this SU bug and about this should think SU developers?
                          Yes - it's our fault. 😞 We're working on a fix.
                          • tt_suT
                            tt_su
                            That's a co-incidence. When you launch SketchUp via a SKP file that is located on a drive different from where SketchUp is installed something gets messed up in SketchUp Ruby. Launch SketchUp first, then open your file - that's the workaround until we release a fix.
                            • SolarwiseLLCS
                              SolarwiseLLC
                              After resetting the folders as you outlined. I was able to regroup and work in the file successfully. After closing SU and restarting my computer, the layers panel stop being responsive in that file. After working in the same file, using just the layers window, the layers panel reset the folders/grouping by itself. Once it reset itself, the layers panel worked, but the folders/grouping were deleted. Wondering if it's the plugin or my file.
                              • jiminy-billy-bobJ
                                jiminy-billy-bob
                                I'm investigating with the file you gave me. This is weird.
                                Do you actively use Didier's Layers Manager, or is it just installed?
                                To you import geometry, or copy/paste between instances?
                                • SolarwiseLLCS
                                  SolarwiseLLC
                                  I do actively use the Didler's Layer Manager. When transferring geometry, I usually copy and paste.
                                    amis
                                    Hi, Jiminy! There's a problem when I use cyrillic font to rename new layer - some codes appear instead of cyrillic letters. Although it didn't happen before (win XP, SU 2013) Got any ideas?
                                      amis
                                      we didn't understand each other properly) Win XP, SU 2013 that's for now
                                      • jiminy-billy-bobJ
                                        jiminy-billy-bob
                                        New version 1.0.4 !
                                        Changelog :
                                        • Added better feedback when sorting multiple layers/groups at once
                                        • Added support for Podium V2+
                                        • Fixed support for Indigo
                                        Download in the plugin store !
                                        • kenK
                                          ken
                                          I open Sketchup files on my travel USB HD from XnView all the time. So are you telling me, the safest way to open Sketchup files is from Sketchup and not a viewer?
                                          IF so, this could explain a lot.
                                          Thanks for your reply.
                                          Ken
                                          • tt_suT
                                            tt_su
                                            Yes, if you use plugins then until we get the fix released you're better of starting SketchUp first, then open the files from SketchUp. Apologies for the inconvenience.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 33
                                            • 34
                                            • 24 / 34
