    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 251.6k Views 123 Watching
      SketchyPhysics and some other 'rogue' plugins are know to cause issues, because they mess with native classes/methods ill-advisedly... sometimes messing with the way some Group methods work, others have Observers that can cause issues too...
      Then an innocent third-party plugin can fail or even cause SketchUp to BugSplat [it's usually a 'rogue' observer that splats!].
      There's a rogue / quarantine list...
        So make some special Plugins folders with only sketchyphisics, Windowizer,... inside! πŸ˜‰
        Just careful to not lost the original Plugins folder! πŸ€“
        • kmlkrkK Offline
          kmlkrk
          Hi, does your extension work in SketchUp 2014? I have successfully installed it, added buttons to my toolbar but I can't use it in any way. I tried making my objects to be groups and components, I tried selecting them first and tried clicking on plugin's button first. Nothing ever happens.
          What am I doing wrong?
          I would greatly appreciate your help!
          • kmlkrkK Offline
            kmlkrk
            In addition to my previous comment: in case that this plugin does not work with SketchUp 2014, does anybody know where can I download SketchUp 2013? It is no longer hosted on official downloads page
            • BoxB Offline
              All versions are available to download http://www.sketchup.com/download/all
                If you PM the author with some useful data, then he might be able to easily update his plugin to be v2014 compatible.
                Unfortunately you decided to give none of us any clue at all as to the errors you encountered.
                Naturally these might be helpful when formulating a fix...
                This particular plugin is encrypted as rbs, so we can't see what it's doing internally...
                But most Plugins can be easily updated and re-encrypted to suit all SketchUp versions...
                • kmlkrkK Offline
                  kmlkrk
                  Unfortunately that page does not have a link for SketchUp Make 2013. Only the pro version. However I already found a way to download 2013 version and I will be using it for now.
                  However, it would be amazing if this great plugin worked for 2014 version. Many thanks to developer for his hard work!
                  EDIT: Looks like I can't open model built in SketchUp 2014 in 2013 version 😞 I will wait and hope that the developer releases update to his plugin soon. Thanks
                  • kmlkrkK Offline
                    kmlkrk
                    Hey Tig, sorry for not including any errors. I am newbie in SketchUp and I did not see any error messages. The tool just does nothing 😞 Is there a way to generate a log of errors? I will be more than happy to help get this working for 2014 version!
                    EDIT: Nothing shows up in ruby console. No errors there. Not sure where else to look
                    • BoxB Offline
                      You can save as back to earlier versions.
                      Open the file in 2014, go save as and select the earlier version in the drop down.
                      • kmlkrkK Offline
                        kmlkrk
                        Thanks Box, this worked like a charm!
                        • BoxB Offline
                          A quick video just to confirm that it isn't working correctly in 2014, what it does and that it's not throwing errors.
                          [screenr:1u3xtnlw]unUN[/screenr:1u3xtnlw]
                            I got in touch with Oscar last December to warn him that this tool would be incompatible with a future version of SketchUp - his encrypted RBS is based on an ANSI encoded file rather than a UTF8-without-BOM one - there might also be some other masked syntax issues !
                            But he knows how to fix it, although he replied and said that he wouldn't do it until the new version of SketchUp [v2014] appeared this spring - as he was busy with other things...
                            Why not PM him - he needs a nudge...
                            I don't think it'd be that hard to make cross-version compatible - mainly changing the encoding of his RB version and re-encrypting it for the RBS πŸ˜•
                            • kmlkrkK Offline
                              kmlkrk
                              I sent him a PM yesterday politely asking if he would be able to update his plugin to work with SketchUp 2014.
                                CemStar
                                I'm also using 2014 and would love this tool to work with it.
                                kmlkrk - Have you heard any reply from him yet?
                                  plemaitre48
                                  very good plugin but it's not compatible with sketchy physic.
                                  • Y Offline
                                    YuconCarneleous
                                    Hey Oscar, we all love your plugin but are dying to get an update to the new 2014 sketchup. Thanks again for a wonderful plugin πŸ‘ πŸ‘
                                    • E Offline
                                      enhydra
                                      I just stumbled over this great plugin. πŸ˜„ A version for SketchUp 2014 would be very handy.
                                      Thanks in advance!
                                        leo11
                                        Hi, been enjoying this great plug quiet a while, worked perfectly till lately is being interrupted by the error massage: "error of the intersect with..No.1, 2, 54 etc." - and no Boolean is functioning... what am i doing wrong ??... πŸ˜•
                                        leo11
                                        • OscarLokO Offline
                                          OscarLok
                                          hi,
                                          Thanks for your support!
                                          at the moment, OSCoolean is not compatible with SketchUp 2014.
                                          And I will refine it after September this year. πŸ˜„
                                          Oscar
                                          • I am sorry for the late reply.
                                          [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
                                            miniellipse
                                            I installed this on Sketchup 2014 but it does not seem to work. Has anyone got it to work with SKP 2014?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 13 / 16
