    [Plugin] SectionCutFace
    569 Posts 171 Posters 506.0k Views 170 Watching
      It works on my Mac just fine.
      • TIGT Online
        You must have ONE section-plane selected - no more and nothing else selected either.
        You only get the context-menu when that one section-plane is highlighted [selected]...
        Works fine on PC and MAC for me - provided that simple rule is followed...
        • takesh hT Offline
          takesh h
          I did follow that simple rule, however, I made a stupid mistake elsewhere. 😳
          I installed the plugin to the reservoir folder (mysteriously named "Plugins" just by chance! πŸ˜‰ ) that I made especially to keep and archive all the plugins… so it wasn't installed properly to begin with.
          Now it's installed to "plugins" under Sketchup folder, and working fine.
          Sorry to waste your time, guys.
            Garyshaw
            Has this plugin been updated to work with 2014?
            I can't seem to bring it into the application
            thanks
            Gary
              thanks
              Gary
              It works just for me in Su2014 on both PC and Mac. How did you try to install it?
              • TIGT Online
                It is an Extension named 'SectionCutFace': you might need to activate it from Preferences > Extensions - BUT when first loaded it ought to be auto-activated πŸ˜•
                Please note that it only appears in the context-menu if there is just one Section-Plane selected.
                There are NO menu entries or toolbars... if that is what you expected.
                Please read the brief [and I think quite clear] Usage instructions...
                http://sketchucation.com/pluginstore?pln=SectionCutFace
                πŸ˜’
                • sokokyuS Offline
                  sokokyu
                  @TIG,
                  Thank you SO much for your awesome plug-in. I love using it and it saves me a great deal of time.
                  However, since upgrading to SketchUp 2014 (I'm on a Mac), I have noticed some instability at times. Have you encountered any such problems?
                  Thanks again!
                  • TIGT Online
                    @sokokyu said:
                    @TIG,
                    Thanks again!
                    Please advise what issues, I see none, but you might have something I can replicate...
                    I have seen a minor occasional issue with v2014 where a newly made group's contents are not visible until you select it and edit, then everything adjust OK.
                    I have trapped for this in some other tools, but not SCFace - perhaps that's it ??
                    • sokokyuS Offline
                      sokokyu
                      It doesn't seem to do with newly made groups and what you were referring to. To be more specific, it seems to crash when I open an existing file (with SectionCutFace items), or have a file already open and open an additional file. I noticed you're using Windows so perhaps it's a Mac issue?
                      • TIGT Online
                        Thia has been reported in another thread a few days agao.
                        It has been traced to SCFace [and probably other plugins adding/removing observers], it is a known issue with v2014 on some MACs - in PMs yesterday I was assured that Trimble are looking to address this.
                        Oddly I can't get it to happen on my MAC πŸ˜’
                        Meanwhile I am looking to recast SCFace to side-step the issue.
                        Hopefully I will issue a glitch-proofed updated version sometime today...
                        πŸ€“
                        • TIGT Online
                          Here is v4.5 http://sketchucation.com/pluginstore?pln=SectionCutFace
                          Its observers have now been adjusted to prevent the splats reported by a very few MAC+Mavericks users...
                          A known issue with v2014MR0 that will hopefully be addressed in a future MR...
                          Please test and report any further issues in this thread...
                            garyshaw3
                            When will this be updated to work with 2014???
                            • cottyC Offline
                              cotty
                              Some hours BEFORE your post, see TIGs announcement directly above your post?! πŸ˜’
                              my SketchUp gallery
                              • TIGT Online
                                It was actually updated to work with v2014 some MONTHS ago.
                                Since then it has worked fine on all versions for ALL PCs and most MACs - but unfortunately a recently reported occasional splat issue with its observers for some v2014 MACs+Mavericks has required a rewrite - hence the latest version issued yesterday πŸ˜’
                                • sokokyuS Offline
                                  sokokyu
                                  Thanks so much TIG! Will give it a whirl (can't live without this plug-in anyways...) and let you know if I experience any issues!
                                  • OxerO Offline
                                    Oxer
                                    Thanks TIG for the update!!
                                    I have made the Spanish Language translation. Here the file:
                                    Spanish Language File
                                    • TIGT Online
                                      Thanks Oxer. πŸ‘
                                      I'll include your ES strings file in future updates... meanwhile users can simply put your strings file into the ../SectionCutFace/Strings folder πŸ˜„
                                        albertjees
                                        I have just downloaded the plugin but it doesn't appear on my windows sketchup.
                                        Someone please help.
                                          rv1974
                                          TIG, is technically possible to make SectionCutFace ruby tool by polyline? revit-like void tool?
                                          or, it's far beyond?
                                          • TIGT Online
                                            Let us assume you have installed it properly - either by installing it from its RBZ archive or by using the SCF AutoInstall button - [i.e. in the Plugins folder there is now a .rb file and a folder of the same name - 'SectionCutFace']...
                                            AND that its Extension is activated...
                                            Please read the Plugins usage notes accessed under More Info, where it is clearly detailed...
                                            It only ever appears in the context-menu, AND it only appears there IF you have just one Section-Plane Selected...
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 28
                                            • 29
                                            • 16 / 29
