    [Plugin] SectionCutFace
    569 Posts 171 Posters 506.0k Views 170 Watching
      srknytgn
      it is not about using the plugin. the installation of it is enough to make it slow.
      • TIGT Online
        That is odd...
        It has an observer that looks for tool changes.
        I am looking at ways of minimizing its impact - perhaps that's it when you have zillions of objects to consider... I'll see if I can get its activities minimized πŸ˜•
          srknytgn
          well, we upgraded our sketchups from 8 to Make and the plugin set was the same in all of our 40 pcs. tested that by deleting plugins one by one, close&open SU and found this result. by the way thank you for developing these plugins so responsively.
          • TIGT Online
            A new version is now available from the PluginStore.
            http://sketchucation.com/resources/pluginstore?pln=SectionCutFace
            It renames 'Glue' as 'Auto-Update'.
            The observers used for 'Auto-Update' SectionCutFaces are re-honed and optimized to minimize 'lag' during regenerations.
            If there are no 'Auto-Update' SectionCutFaces in the model then any lag should be imperceptible.
            • takesh hT Offline
              takesh h
              Does SectionCutFace work with Macs (OSX10.7, Mountain Lion)?
              No SectionCutFace context menus available when section planes are right-clicked... ❓
                It works on my Mac just fine.
                • TIGT Online
                  You must have ONE section-plane selected - no more and nothing else selected either.
                  You only get the context-menu when that one section-plane is highlighted [selected]...
                  Works fine on PC and MAC for me - provided that simple rule is followed...
                  • takesh hT Offline
                    takesh h
                    I did follow that simple rule, however, I made a stupid mistake elsewhere. 😳
                    I installed the plugin to the reservoir folder (mysteriously named "Plugins" just by chance! πŸ˜‰ ) that I made especially to keep and archive all the plugins… so it wasn't installed properly to begin with.
                    Now it's installed to "plugins" under Sketchup folder, and working fine.
                    Sorry to waste your time, guys.
                      Garyshaw
                      Has this plugin been updated to work with 2014?
                      I can't seem to bring it into the application
                      thanks
                      Gary
                        thanks
                        Gary
                        It works just for me in Su2014 on both PC and Mac. How did you try to install it?
                        • TIGT Online
                          It is an Extension named 'SectionCutFace': you might need to activate it from Preferences > Extensions - BUT when first loaded it ought to be auto-activated πŸ˜•
                          Please note that it only appears in the context-menu if there is just one Section-Plane selected.
                          There are NO menu entries or toolbars... if that is what you expected.
                          Please read the brief [and I think quite clear] Usage instructions...
                          http://sketchucation.com/pluginstore?pln=SectionCutFace
                          πŸ˜’
                          • sokokyuS Offline
                            sokokyu
                            @TIG,
                            Thank you SO much for your awesome plug-in. I love using it and it saves me a great deal of time.
                            However, since upgrading to SketchUp 2014 (I'm on a Mac), I have noticed some instability at times. Have you encountered any such problems?
                            Thanks again!
                            • TIGT Online
                              @sokokyu said:
                              @TIG,
                              Thanks again!
                              Please advise what issues, I see none, but you might have something I can replicate...
                              I have seen a minor occasional issue with v2014 where a newly made group's contents are not visible until you select it and edit, then everything adjust OK.
                              I have trapped for this in some other tools, but not SCFace - perhaps that's it ??
                              • sokokyuS Offline
                                sokokyu
                                It doesn't seem to do with newly made groups and what you were referring to. To be more specific, it seems to crash when I open an existing file (with SectionCutFace items), or have a file already open and open an additional file. I noticed you're using Windows so perhaps it's a Mac issue?
                                • TIGT Online
                                  Thia has been reported in another thread a few days agao.
                                  It has been traced to SCFace [and probably other plugins adding/removing observers], it is a known issue with v2014 on some MACs - in PMs yesterday I was assured that Trimble are looking to address this.
                                  Oddly I can't get it to happen on my MAC πŸ˜’
                                  Meanwhile I am looking to recast SCFace to side-step the issue.
                                  Hopefully I will issue a glitch-proofed updated version sometime today...
                                  πŸ€“
                                  • TIGT Online
                                    Here is v4.5 http://sketchucation.com/pluginstore?pln=SectionCutFace
                                    Its observers have now been adjusted to prevent the splats reported by a very few MAC+Mavericks users...
                                    A known issue with v2014MR0 that will hopefully be addressed in a future MR...
                                    Please test and report any further issues in this thread...
                                      garyshaw3
                                      When will this be updated to work with 2014???
                                      • cottyC Offline
                                        cotty
                                        Some hours BEFORE your post, see TIGs announcement directly above your post?! πŸ˜’
                                        my SketchUp gallery
                                        • TIGT Online
                                          It was actually updated to work with v2014 some MONTHS ago.
                                          Since then it has worked fine on all versions for ALL PCs and most MACs - but unfortunately a recently reported occasional splat issue with its observers for some v2014 MACs+Mavericks has required a rewrite - hence the latest version issued yesterday πŸ˜’
                                          • sokokyuS Offline
                                            sokokyu
                                            Thanks so much TIG! Will give it a whirl (can't live without this plug-in anyways...) and let you know if I experience any issues!
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 28
                                            • 29
                                            • 16 / 29
