    Need advice how to model this
    17 Posts 6 Posters 1.1k Views 6 Watching
      Start Shape
      Rail x 2
      Mid Shape
      to generate one side. Repeat for other side
      • N
        numerobis
        curviloft works too with two separated sides. But the problem with both solutions is the transition between the two sides... it is not possible to get a smooth transition. I had this problem several times. It would be great if curviloft would work with multiple shapes and could generate a smooth transition.
        • fredo6F
          Curviloft "Loft along Path" ca n handle all contours in one shape.
          Select first the 2 parts of the Rail contour.
          Then select the 3 contours "Start", "Mid" and "End" in order.
          need2extrude _ Curviloft - v8.skp
          • soloS
            Lol, even Toposhaper does the trick.
            • andybotA
              andybot
              lol, except it doesn't... what's that about Pete? πŸ˜•
              I run into situations too where the extruded shapes are not continuous, so this is helpful to know that curviloft works for this kind of thing. Many thanks to Fredo for his wonderful plugins πŸ‘
              • soloS
                All the logical methods were taken, I thought I'd play with something else. πŸ˜„
                • fredo6F
                  Oooops!
                  To get continuity along the Rail, you need to select the Offset option
                  Then the two sides are joined in continuity.
                  • N
                    numerobis
                    But the result is the same - there is still no smooth transition possible.
                    Btw. i accidently closed the status bar... how can i get it back?!? 😲
                    • N
                      numerobis
                      @fredo6 said:
                      Oooops!
                      πŸ‘ great! thanks!!! 😍
                      ...now i only need to get the status/options bar back to be able to change the method πŸ˜†
                      • fredo6F
                        I just realized that the 2 straight line contours were overly divided.
                        This is not necessary. Just make them a single edge each.
                        Then it will be the wavelet contour which will drive the mesh.
                        • fredo6F
                          There should be a small red rectangle in the upper left corner. just click on it to expand the button palette.
                          • N
                            numerobis
                            i will look for it next time when it happens... thanks!
                            After the second or third reopening of sketchup it was there again.
                            • dereiD
                              derei
                              Thanks fredo for the input, but as you can see in the image, there are some strange effects. The model seems to "grow" where the wavy line is. Maybe I should add on each side a second wave, smaller? To make the transition more controllable ?
                              DESIGNER AND ARTIST DEREI.UK
                              • fredo6F
                                Derei,
                                By the way, you could remove the up and downs by duplicating the wave profile at 1/4 and 3/4 distance, and then use Curviloft, Loft by Spline, as shown below:
                                Derei - need2extrude.skp
