    Need advice how to model this
    17 Posts 6 Posters 972 Views 6 Watching
      derei
      I have this:
      I need to extrude the lines from Start to Mid to End, but also to keep the rail's shape.
      What plugin would help me for this and how?
      I can't make half and mirror, because the rail is catenary (maybe in this example is hard to see, but I have several similar shapes to make).
      SU file attached.
      need2extrude.skp
        TIG EEbyR would do it.....after some 'thinking' time as it's quite heavy at 300 segments per curve.
          derei
          And how to select them? Should I make a group with the 3 profiles and another group with the rail?
          I have TIG's extruding plugin, but I'm pretty confused about how to use it, especially the more complex extruding tools.
            Start Shape
            Rail x 2
            Mid Shape
            to generate one side. Repeat for other side
            • N Offline
              numerobis
              curviloft works too with two separated sides. But the problem with both solutions is the transition between the two sides... it is not possible to get a smooth transition. I had this problem several times. It would be great if curviloft would work with multiple shapes and could generate a smooth transition.
              • F Offline
                Curviloft "Loft along Path" ca n handle all contours in one shape.
                Select first the 2 parts of the Rail contour.
                Then select the 3 contours "Start", "Mid" and "End" in order.
                need2extrude _ Curviloft - v8.skp
                  Lol, even Toposhaper does the trick.
                    andybot
                    lol, except it doesn't... what's that about Pete? πŸ˜•
                    I run into situations too where the extruded shapes are not continuous, so this is helpful to know that curviloft works for this kind of thing. Many thanks to Fredo for his wonderful plugins πŸ‘
                      All the logical methods were taken, I thought I'd play with something else. πŸ˜„
                      • F Offline
                        Oooops!
                        To get continuity along the Rail, you need to select the Offset option
                        Then the two sides are joined in continuity.
                        • N Offline
                          numerobis
                          But the result is the same - there is still no smooth transition possible.
                          Btw. i accidently closed the status bar... how can i get it back?!? 😲
                          • N Offline
                            numerobis
                            @fredo6 said:
                            Oooops!
                            πŸ‘ great! thanks!!! 😍
                            ...now i only need to get the status/options bar back to be able to change the method πŸ˜†
                            • F Offline
                              I just realized that the 2 straight line contours were overly divided.
                              This is not necessary. Just make them a single edge each.
                              Then it will be the wavelet contour which will drive the mesh.
                              • F Offline
                                There should be a small red rectangle in the upper left corner. just click on it to expand the button palette.
                                • N Offline
                                  numerobis
                                  i will look for it next time when it happens... thanks!
                                  After the second or third reopening of sketchup it was there again.
                                    derei
                                    Thanks fredo for the input, but as you can see in the image, there are some strange effects. The model seems to "grow" where the wavy line is. Maybe I should add on each side a second wave, smaller? To make the transition more controllable ?
                                    • F Offline
                                      Derei,
                                      By the way, you could remove the up and downs by duplicating the wave profile at 1/4 and 3/4 distance, and then use Curviloft, Loft by Spline, as shown below:
                                      Derei - need2extrude.skp
