    2014 Make edit material MAC
    36 Posts 8 Posters 4.7k Views 8 Watching
      mwm5053
      When I try to edit a material as I've done many times with no problem in SU 8 i get a dialog box that says Failed to save file so I save file still get error message. Any ideas maybe a bug.
      PS pref/ open app set to my photo editor
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        Walt, where's it trying to save the image? In the Materials folder? Check to see if that one needs to have permissions set to Read & Write.
          mwm5053
          I don't know where or what it's trying yo save never seen this before now. I have full permissions as administrator.
          2011 iMac
          V2 Twilight
            Just being the administrator doesn't necessarily give you Read and Write permissions to all folders. Can you sort out the location from the save as... in the image editor? On my Mac SU writes the image file to com.sketchup.SketchUp 2014.my_user. PhotoShop Elephants opens it from there and then saves it back again so SketchUp can update from that file.
              mwm5053
              I don't know Dave I looked for that location com.sketcheup.SketchUp 2014.my_user but couldn't find such a file, maybe give me more info?
              2011 iMac
              V2 Twilight
                mwm5053
                @dave r said:
                Just being the administrator doesn't necessarily give you Read and Write permissions to all folders. Can you sort out the location from the save as... in the image editor? On my Mac SU writes the image file to com.sketcheup.SketchUp 2014.my_user. PhotoShop Elephants opens it from there and then saves it back again so SketchUp can update from that file.
                Really PS elephants 🤣
                2011 iMac
                V2 Twilight
                • BoxB
                  The great thing with PS Elephants is the unlimited undos, it never forgets.
                    Sorry, Walt. I found the location name by opening the image in PSE and then did a File>Save as... there. You might try it in SU8 (do you still have SU8 installed?) and see what you get. The path should be similar. Of course 'my_user' is the user name you have set up on your computer.
                    Did you try searching for com.sketchup/SketchUp 2014 in Finder?
                    The problem with PS Elephants is it is big and slow. 😉
                      Thank you for that.
                      Should that be = ENV["TMPDIR"] + "com.sketchup.SketchUp 2014." + ENV["USER"] UI.openpanel(path, path)?
                      the folder that is being created is a temporary one but I wonder if the problem, Walt, is that one of the container folders needs Read and Write permission granted.
                        I guess I do get the same thing with or without the '.' in SketchUp 2014.
                        So I see this:
                        The top file in the list is the material image I've opened from SketchUp in PSE.
                          mwm5053
                          Mine's in MacHD / Private /var /folders /and screen shot better to explain
                          2011 iMac
                          V2 Twilight
                            mwm5053
                            Using Pixelmator in pref image editor
                            2011 iMac
                            V2 Twilight
                              So check all of the folder levels and make sure they all have Read & Write permissions set.
                              Have you tried editing more than one texture image? Do you get the error message with any texture?
                                driven
                                Odd thing re the dot... mine has it and needs it, it's very uncommon and bad practice to have spaces in TMP path names...
                                  mwm5053
                                  @ john how do I show hidden folders in Lion 10.7 I used some terminal command suggested on internet but didn't work
                                  defaults write com.apple.finder AppleShowAllFiles
                                  2011 iMac
                                  V2 Twilight
                                    driven
                                    tested 'Pixen' as well but don't have 'Pixelmator'.
                                    does it work with any other editor on your mac?
                                    re. hidden files
                                    in 'Ruby Console'
                                    `defaults write com.apple.finder AppleShowAllFiles TRUE`
                                      driven
                                      re. hidden files
                                      in 'Ruby Console'
                                      killall Finder`
                                      ADDED the killall that makes it run, FALSE will turn them off again...
                                        mwm5053
                                        Ok works now must have been a permission thing like Dave said but thanks Dave and John 😄
                                        2011 iMac
                                        V2 Twilight
                                        • H
                                          Hendrik_G
                                          I'm having the same "Failure to Save File" issue when I tried to edit any of my textures in SU2015 running Mac Yosemite. I've read this discussion, and I'm still unable to resolve my issue. I'm hoping someone can help me or let me know what I'm missing. I've tried the following:
                                          When, as suggested above, I entered this into SU's Ruby Console:
                                          = ENV["TMPDIR" + "com.sketchup.SketchUp 2014." + ENV["USER"]
                                          UI.openpanel(path, path)]
                                          I received the following error: %(#FF0000)[Error: #<SyntaxError: <main>: syntax error, unexpected '='
                                          SketchUp:1:in `eval']
                                          I searched and found "com.sketchup/SketchUp 2015/" in this location:
                                          Library/Caches/com.sketchup.SketchUp.2015/
                                          I've attached a screenshot of the contents of this folder.
                                          I confirmed in the Get Info window that my user had Read/Write access to that entire folder path and the contents within.
                                          I'm still having issues. Any help would be greatly appreciated.
                                          • jeff hammondJ
                                            what application are you trying to use for your external editor?
                                            i haven't read through the thread but i did see pixelmator mentioned and in its case, the default setting is to open any file in its .pxm format instead of .jpg/.png/etc..
                                            so, if your external editor is opening/converting the file, it won't save back into sketchup properly..
                                            in other words, i don't think this is a permissions issue. (not ruling it out.. just check some other stuff first)
