    Sketchup 13 undo bug
    30 Posts 13 Posters 9.1k Views 13 Watching
      dtrarch
      Undo
      OK for me if all plugins were removed.
      SU pro 2013
      Which one??? ❓
      Maybe one of them is holding memory space.
      dtr
        Put half of them back and see if the problem occurs again. If so, it's in the half you put back. If not it's in the other half. Problem is, it could be a couple of plugins fighting each other.
          dtrarch
          Hi Y'all
          I think Ive found the dirty devil. πŸ‘Ž πŸ‘Ž
          BG Sketchup Component Manager
          You will have to reload to make the fix after killing the plug.
          Anyway this fixed the undo for me. 😍
          dtr
            Good find, sir. πŸ‘
              dtrarch
              I do work for food too.
              d
              • Bob JamesB Offline
                Bob James
                @dtrarch said:
                Hi Y'all
                dtr
                I have the problem and do not have BG Sketchup Component Manager installed.
                • jiminy-billy-bobJ Offline
                  jiminy-billy-bob
                  If it's "Undo Add Layer Observer", it's related to Layers Panel. I fixed it and will soon release an update.
                  As for "Undo Properties", it's not Layers Panel. But it's a generic name, it happens when a plugin doesn't give names to its operations.
                    Pherim
                    @bob james said:
                    @dtrarch said:
                    Hi Y'all
                    dtr
                    I have deactivated it and the problem persists... now is is even happening when I have just started Sketchup with an empty file and have not yet done anything. Seems I have to test my plugins one by one to find out which is responsible.
                    • Chris FullmerC Offline
                      Re-read the post right above yours Pherim. Jiminy suggests it is also possible that it might be his plugin - Layer Panel. Check to see if you have that installed.
                        jiminy-billy-bob
                        TT also found a bug that produces "Undo properties" in some cases with Layers Panel. I'll publish a fix soon.
                          Pherim
                          One question, is it enough to disable the plugin in the plugins/extension manager of the Plugin Store? I did this first and it still appeared directly after starting Sketchup, but when I played around a little with various tools it did not seem to happen again. I don't know if it was Component Manager or Layers Panel, still have to test that and see if it really is gone now.
                            jiminy-billy-bob
                            The bug should be fixed in version 1.0.1
                            http://sketchucation.com/pluginstore?pln=Layers_Panel
                            • ToboboT Offline
                              Tobobo
                              I had the same problem, and found that it was Vray 1.49. but now the undo command undoes two or three steps not just one. so I'm constantly having to repeat things.
                              It is very annoying.
                              Toby
                              Philippians 4:13
                              • E Offline
                                eddie
                                looks like uninstalling the component manager did it for me...so far. Took a while to find though since it was called BGScomposants...
                                Thanks for all your help everyone!
                                • onzkiO Offline
                                  onzki
                                  I just had this problem today.. can't find this "BGScomposants".. where is it located?
                                  [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                                  • onzkiO Offline
                                    onzki
                                    After a day of struggle of trying to work precisely knowing there's no undo available πŸ˜„.. I finally found the culprit (in my situation)- It's the luxrender plugin that I installed few days ago.
                                    IMHO, I think the cause will vary (I use Sketchup 8), so as a tip, I suggest to always log or remember the plugins that you install so it's easier to spot the troublemaker πŸ˜„.
                                      ltchest
                                      Im using version 1.2 & still get the problem where Undo does not work. It just gives you "undo properties" and does nothing.
                                      Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
                                      RTX2070 + GTX1080, Driver 472.12
                                        jiminy-billy-bob
                                        Are you 100% sure it's caused by Layers Panel?
                                          Glenn at home
                                          I also had this problem as well and did have the Lux plugins installed. I have removed them and I think it has fixed the problem on my end.
                                            Jarhead
                                            So... none of the suggestions above worked for me, neither having a fresh install of SketchUp 8... So I determined that it must be something in the model itself.
                                            A clean new project doesn't have the bug, only some files that I work on from the get go.
                                            After cutting and pasting the elements of the file I was having an issue with, into a new SketchUp project, the issue isn't there anymore.
                                            I have Layers Panel & Layer Manager, and they don't seem to be the problem (evident by the fact that the issue persisted with a clean SketchUp install
