    Sketchup 13 undo bug
    30 Posts 13 Posters 9.1k Views 13 Watching
    • Bob JamesB Offline
      Bob James
      Mostly "undo properties" and some about "observers". Do not have Components Manager installed.
      • E Offline
        eddie
        I tried two things:
        For sketchup 8 pro i uninstalled and reinstalled, and it worked fine for about a 1/2 hour and then it started doing the same thing...only letting me do one undo before it starts undoing properties only...
        So then i restored windows from a point about two weeks ago, long before the last group of windows updates, and it seems to be working fine now. I can undo more than once, and i can manually input dimensions while in the active push pull command. However after finishing up the project last night, im a little hesitant to fire up sketchup again for fear that it will revert back to being unusable..
          So Ctrl-Z does not undo? Is it possible some plugin is doing this? Have you tried with the Plugins folder temporarily renamed so plugins can't load?
          • E Offline
            eddie
            Dave R. When my deadlines slow down a little bit i might try and reinstall the windows updates to see if it happens again, and ill try temporarily disabling the plugins folder if it does, but for now i cant spare the time to trouble shoot. I will also try and remove any outdated plugins that might be causing conflicts to.
            but so far rolling back the windows updates seems to be working...
              dtrarch
              Undo
              OK for me if all plugins were removed.
              SU pro 2013
              Which one??? ❓
              Maybe one of them is holding memory space.
              dtr
                Put half of them back and see if the problem occurs again. If so, it's in the half you put back. If not it's in the other half. Problem is, it could be a couple of plugins fighting each other.
                  dtrarch
                  Hi Y'all
                  I think Ive found the dirty devil. πŸ‘Ž πŸ‘Ž
                  BG Sketchup Component Manager
                  You will have to reload to make the fix after killing the plug.
                  Anyway this fixed the undo for me. 😍
                  dtr
                    Good find, sir. πŸ‘
                      dtrarch
                      I do work for food too.
                      d
                        Bob James
                        @dtrarch said:
                        Hi Y'all
                        dtr
                        I have the problem and do not have BG Sketchup Component Manager installed.
                        • jiminy-billy-bobJ Offline
                          jiminy-billy-bob
                          If it's "Undo Add Layer Observer", it's related to Layers Panel. I fixed it and will soon release an update.
                          As for "Undo Properties", it's not Layers Panel. But it's a generic name, it happens when a plugin doesn't give names to its operations.
                            Pherim
                            @bob james said:
                            @dtrarch said:
                            Hi Y'all
                            dtr
                            I have deactivated it and the problem persists... now is is even happening when I have just started Sketchup with an empty file and have not yet done anything. Seems I have to test my plugins one by one to find out which is responsible.
                            • Chris FullmerC Offline
                              Re-read the post right above yours Pherim. Jiminy suggests it is also possible that it might be his plugin - Layer Panel. Check to see if you have that installed.
                                jiminy-billy-bob
                                TT also found a bug that produces "Undo properties" in some cases with Layers Panel. I'll publish a fix soon.
                                  Pherim
                                  One question, is it enough to disable the plugin in the plugins/extension manager of the Plugin Store? I did this first and it still appeared directly after starting Sketchup, but when I played around a little with various tools it did not seem to happen again. I don't know if it was Component Manager or Layers Panel, still have to test that and see if it really is gone now.
                                    jiminy-billy-bob
                                    The bug should be fixed in version 1.0.1
                                    http://sketchucation.com/pluginstore?pln=Layers_Panel
                                    • ToboboT Offline
                                      Tobobo
                                      I had the same problem, and found that it was Vray 1.49. but now the undo command undoes two or three steps not just one. so I'm constantly having to repeat things.
                                      It is very annoying.
                                      Toby
                                      Philippians 4:13
                                      • E Offline
                                        eddie
                                        looks like uninstalling the component manager did it for me...so far. Took a while to find though since it was called BGScomposants...
                                        Thanks for all your help everyone!
                                        • onzkiO Offline
                                          onzki
                                          I just had this problem today.. can't find this "BGScomposants".. where is it located?
                                          [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                                          • onzkiO Offline
                                            onzki
                                            After a day of struggle of trying to work precisely knowing there's no undo available πŸ˜„.. I finally found the culprit (in my situation)- It's the luxrender plugin that I installed few days ago.
                                            IMHO, I think the cause will vary (I use Sketchup 8), so as a tip, I suggest to always log or remember the plugins that you install so it's easier to spot the troublemaker πŸ˜„.
