    SketchUp 2014
    205 Posts 79 Posters 67.2k Views 79 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Steve means that the files "date.rb" and "rational.rb" are not the ones distro'd with SketchUp 2014, because those are in the "Tools/RubyStdLib" directory.
      Further we know this because the versions you are loading are much larger then the v2.0.0 files.
      Ie, "date.rb" v2.0.0 has only 61 lines. Your errors occur on high line counts!
      "rational.rb" v2.0.0 has only 23 lines. Your errors occur on high line counts!
      I'm not here much anymore.
        AirWindSolar
        @numerobis said:
        :shock:
        • new 3d warehouse
        • IFC
        • arc tool
        • faster shadows
        • ruby 2.0
        • some layout improvements
        REALLY?!? This is 2014?!?
        Well, it does appear they've finally recognized that I don't need to see that stupid "by adding a location..." monologue every time I use geolocation. Sadly, that seems to be the best benefit I've found so far.
        • soloS Offline
          I am having a problem with Vertex tools, I download it from SCF download manager and it asks me to activate it but when I put info it it does nothing, whites out, anyone have similar issue or solution?
          • BoxB Offline
            I downloaded from the store and it installed and licensed automatically.
            • FrederikF Offline
              Frederik
              I bought the Vertex tool the other day, received my key and activated it...
              Works like a charm...
              (Perhaps Thomthom doesn't like you...) 😕 😛
              Cheers
              Kim Frederik
              • arail1A Offline
                arail1
                I haven't tried to download if for 2014 yet. Love Vertex Tools.
                  Go to vertex tools site. Login. And download.
                  Might be related to your account.
                  • soloS Offline
                    That worked thanks
                    • tt_suT Offline
                      tt_su
                      Screenshots?
                      Any errors in the Ruby Console?
                      • soloS Offline
                        @tt_su said:
                        Screenshots?
                        Not now as it works, however at the time the user name and password part for existing users whites out once you hit enter and does nothing.
                        • emerald15E Offline
                          emerald15
                          Sorry to bother you – I’m sure you’re getting massed of questions re: getting SU2014 going & it’s not as if I haven’t installed plugins before… but - I‘m diligently installing all my plugins from new into SU2014, (an excellent opportunity to have a tidy)
                          All’s going well but I do like use 000_AdditionalPluginFolders_v4.2a.rbz to keep as many plugins as will work in an ‘Additional Plugins’ (AP2014) folder. I’ve downloaded each .rbz fresh from the store to my downloads folder. For those that I’ve installed directly into SU I’ve installed each extension via the system preferences window. Perfect so far!
                          For those plugins I intend to keep in the ‘AP2014’ folder I copied them from the download folder & pasted them into ‘AP2014’. Although SU is setup with the ‘AP2014…’link – these plugins do not run.
                          I also installed them via the system preferences/install extensions – directed to the ‘AP2014’ folder – however this installed them directly into the main SU plugins folder (see 2D tools & Extrude tools in directories 1 & 2 attached)… guess that was wrong then! My question then is what else should I be doing to get the ‘AP2014’ plugins to run?
                          • cottyC Offline
                            cotty
                            I haven't used the additional plugin, but perhaps you have to unpack the RBZs in your folder?
                            my SketchUp gallery
                            • charly2008C Offline
                              charly2008
                              I have now installed Sketchup 2014. I must say that it is a difficult and time-consuming business to find all the beloved plugins again. Many are not yet available for 2014. That means you have to look always in the Extension warehouse or in the Plugin store if there is a matching plugin available.Some will perhaps not at all updated. I think It will certainly take months until the most Plugins are up to date. Until then I will continue to maintain my beloved Sketchup 8. Until now I can still see no advantage over Sketchup 8. Maybe I will recognize the benefits later.
                                emerald15
                                Hmmm...! that rings a bell Cotty. It used to be that you un-packed a few files (incl. .rb's) & a folder & just copied them to the correct place. But I'm a bit lost with .rbz's... how does one un-pack them. The only method I can find is via SU's 'system preferences' ... which puts everything back directly into SU again!
                                  @emerald
                                  • install Additional Folders
                                  • activate it and define your 'additional plugins folder/s'
                                  • use the PluginStore to install plugins and when the prompt asks if you want to place it in the 'additional' folder choose it....
                                  • cottyC Offline
                                    cotty
                                    They are renamed ZIPs. If your pack program don't want to open them, you can rename them to ZIP and unpack them afterwards.
                                    But you should follow Richs suggestion...
                                    my SketchUp gallery
                                      @Fiona / aka emerald
                                      An RBZ is an archive [like a ZIP file] containing the Ruby file and other support files that the Plugin needs to be loaded to work.
                                      When you use the Preferences > Extensions > Install tool, the Plugin's files inside the RBZ are extracted into the main User's Plugins folder [as your screenshot shows]. This destination is hard-wired and cannot be changed.
                                      If you want to have Plugins loading from a different Plugins folder firstly you need to have that folder added to the SketchUp $LOAD_PATH: Fredo's 'AdditionalPluginFolder' tool allows you to do this.
                                      As SketchUp starts it auto-loads all .rb/.rbs files it finds in all of the folders listed in the $LOAD_PATH, including your newly added additional Plugins folder...
                                      Unfortunately because only the main User's Plugins folder is always used by the native RBZ installer, all of thae Plugins that you have installed to date by using that tool have ended up in there.
                                      However, if you use the SketchUcation submenu 'Archive Installer' on your RBZ archives [or even ZIP files] OR use the SketchUcation 'Plugin Store' dialog's AutoInstall button within SketchUp [skipping the RBZ download altogether]... then if there is an alternative Plugins folder in the $LOAD_PATH, then you are offered that as an alternative destination for your installation - so that way you CAN install a Plugin's files directly into your alternative Plugins folder.
                                      So far what you have done is install all of your RBZ archives using the native installer, so that those Plugins' files are now in the main Plugins folder.
                                      Then you seem to have put your RBZ archives [unchanged] into your own custom Plugins folder.
                                      There they will do nothing, because SketchUp will simply not 'see' the RBZ as a loadable file format.
                                      To get Plugins to auto-load from your alternative Plugins folder you will need to do this:
                                      EITHER remove the currently installed Plugins files AND their sub-folders from the main Plugins folder and then use one of the SketchUcation installation methods outlined above to re-install those Plugins into your alternative Plugins folder.
                                      OR you could physically move the Plugins .rb/.rbs files AND their support subfolders from the main Plugins folder into your alternative Plugins folder.
                                      Remember that you do NOT want duplicated sets of Plugins coexisting and auto-loading - you might get double or confusing menu entries etc...
                                      This second way is the most fraught with danger because you might not get all of the required files/subfolders transferred.
                                      And in both cases you might inadvertently move SketchUp's own 'shipped' "su_...rb" files and their subfolders, which SketchUp needs to have in the main User's Plugins folder - if you remove them SketchUp simply adds them back from its 'ShippedExtensions' subfolder anyway - running duplication risks.
                                      The User's main Plugins folder always contains the four "su_...rb" 'shipped' sets, but everything else that you install is 'yours' alone - so in your case there is little benefit in having an alternative Plugins folder... 😕
                                      One reason people do use an alternative Plugins folder is in a 'DropBox' scenario - where they have one installed set of Plugins which is accessible to various computers that have access to that DropBox... A simple Plugins 'sync' method...
                                      Its less straightforward installation process is counterbalanced by the one-installion to suit all computers benefit.
                                      However, in your case I suspect that you will see little benefit from having an alternative Plugins folder configured - and you'll just get a bigger admin headache to sort out your current mess.
                                        emerald15
                                        Thank you TIG, Rich & Cotty. I’m feeling a right fool! I’ve been trying to download direct from Plugins Store (top right of SketchUcation page – not via the new SketchUcation tools. – so there wasn’t an ‘Autoinstall’ option. Right – found that… followed procedure… selected AP2014 folder… clicked ‘autoinstall’… nothing happens – the plugin does not show up listed in the AP2014 folder.
                                        Conclusion – as you advised TIG – messing about & moving files is dangerous and is probably causing me more problems. So I’m going to clean off all the plugins I’ve installed so far - & start again – tomorrow!
                                        TIG, it sounds as though you are suggesting I may not really need Fredo’s Additional Plugins folder option? I don’t use masses of plugins – approx.. 20 regular use & perhaps 10 more rare use. I set up the additional folder on advice from the forum a couple of years ago when menus were starting to grey out. Is it perhaps not so vital now with SU2014?
                                        Thank you again for all your patient advice, particularly for TIG's detailed explanations. I didn’t quite understand the .rbz format until now. I’ll post again when I’ve succeeded.
                                          @emerald
                                          You do not need Fredo' AdditionalPluginsFolder tool... UNLESS you really need extra folders of Plugins auto-loading.
                                          I think you do not need them 😕
                                          Without it you'll get no choice in the installation destination - every RBZ based Plugin gets installed into the User's Plugins folder - either through Preferences > Extensions > Install or the SketchUcation Plugin Store tools run within SketchUp itself.
                                          So in you case I'd remove all Plugins and subfolders from the standard User's Plugins folder [as previously advised], then reinstall new versions of what you need - automatically using the standard User's Plugins folder.
                                          Do not install or initialize the AdditionalPluginsFolder tool, as there is no need for any extra folder paths in your case...
                                            emerald15
                                            Yes, I think you're right. & it will help me sort this install problem. I'll get on it in the morning. Many thanks.
                                            • 11
                                            • 7 / 11
