    A test with Daz3D model *Nudity warning*
    32 Posts 13 Posters 14.3k Views 13 Watching
    • jo-keJ Offline
      jo-ke
      I've had success this time.
      I've exported a V4 via Poser to OBJ an imported it to SU. Reducing the mesh with meshlab outside SU wasn't possible. The file has 35 MB and took over an hour to import. Unfortunately all textures were lost and I had to retexture the whole body.
      I've embeded to my scene, which has also about 50 MB. Unfotunately that was to much fΓΌr twilight and kerkythea, the xml has over 100 MB and couldn't be loaded to the Application.
      So I gave up, hoping for a better capacity of future SU- Version and hoping for the new twilght version.
      http://www.zz7.de
      • FrederikF Offline
        Frederik
        I haven't tested these models with TWR, however, like I wrote previously, you can import an OBJ file direct to KT and then merge it together with your SU scene...
        Really can't see what the issue is... πŸ˜•
        Cheers
        Kim Frederik
          Roger
          Does she have a phone number?
          http://www.azcreative.com
          • BoxB Offline
            As you already had the nudity warning and I was bored this morning I knocked up a bit of a sculpture to help soften the lines in your bathroom.
            • FrederikF Offline
              Frederik
              Looks really good, Box... πŸ‘
              Cheers
              Kim Frederik
              • BoxB Offline
                Thanks Frederik, I rather enjoy playing with Vertex tools.
                • jgbJ Offline
                  jgb
                  Anybody ever tried creating a 3D model (car, room fixtures, etc) in SU and export it to DAZ? If yes, how?
                  jgb
                  • FrederikF Offline
                    Frederik
                    That's easy...
                    Export to i.e. OBJ and use the import function in Daz3D... πŸ˜„
                    Cheers
                    Kim Frederik
                    • jgbJ Offline
                      jgb
                      @frederik said:
                      That's easy...
                      If I had known it was that easy, I would have persevered with my copy of DAZ years ago.
                      I found it a bit too steep on the learning curve, so I put it away.
                      Stayed with my tried and true Disney(esque) cell by cell animation.
                      All XXX rated of course. πŸ˜†
                      jgb
                      • jo-keJ Offline
                        jo-ke
                        not DAZ but I've done it with poser.
                        It worked well, but I've had to find good materials for the rendering that wasn't easy because I'm not so experienced with the Material Tab in poser
                        http://www.zz7.de
                        • 2 / 2
