    A test with Daz3D model *Nudity warning*
    32 Posts 13 Posters 14.8k Views 13 Watching
    • BoxB
      I know Jeff it's ridiculous, my first thought on seeing Frederiks post title is that this one will hit the view record in no time. My experiences with the lunacy of US censorship knows no bounds, I have even been employed to rework sculptures to remove nipples and other assorted bits for the US Market.
      • tademaT
        tadema
        "The frog perspective view inside the shower is quite spectacular... ๐Ÿ˜ฒ"
        see... being a frog has it's advantages ๐Ÿ˜„
        Great scene and clean render ๐Ÿ‘
        John
        • BoxB
          Great scene, clean render and a well put together bum p map.
          • FrederikF
            Frederik
            Another angle for Oli and Rich... ๐Ÿ˜„
            Cheers
            Kim Frederik
            • pbacotP
              Probably someone employed to put them back on. What job descriptions!
              • olisheaO
                olishea
                Nicely done!! ๐Ÿ˜„ it really is a great model! ๐Ÿ˜†
                My only crit is perhaps it needs more entourage. ๐Ÿ˜Ž I thought ladies always go to the bathroom together? ๐Ÿ˜†
                oli
                • jo-keJ
                  jo-ke
                  That is a very interessting topic.
                  I use poser. which is quite similar to DAZ Studio.
                  I often tried to export models like Victoria 4 to SU via obj. But it was always to hightpoly. I also wasn't able to preserve the textures.
                  I'm very interessted in your workflow.
                  http://www.zz7.de
                  • FrederikF
                    Frederik
                    I also had a license of Poser v6 (which is app. 7 years ago ๐Ÿ˜ฎ ), but never became satisfied with it...
                    Daz3D is available for free and development have progressed since, I wanted to give it a shot and I was very happy with it... ๐Ÿ˜„
                    I assume you tried to import the model directly into SU using one of the OBJ-importers available... Have to say that I also had issues with the direct import... ๐Ÿ˜
                    @frederik said:
                    ...it's easy to export the model from Daz3D to OBJ and then I can use Simlab Composer to export to SU or another 3D file format...
                    (For this I exported to 3DS which is easy to import to directly to Thea Render...)
                    Indeed the models are very heavy when brought into SU...
                    Since I'm using Thea4SU, I can make a library in Thea, insert the model as a proxy in SU and then make the render... ๐Ÿ˜‰
                    Cheers
                    Kim Frederik
                    • jo-keJ
                      jo-ke
                      I'm still using twilight.
                      What can I do to preserve the texture and texture cordinates and to reduce the mesh?
                      Which programm is able to do that?
                      http://www.zz7.de
                      • FrederikF
                        Frederik
                        Rumor has it that TWR will also get a proxy system in v2... ๐Ÿ˜‰
                        In the mean time, you can use KT as studio and place your Poser models in KT...
                        Kt is able to import OBJ and 3DS directly... ๐Ÿ˜‰
                        Like I wrote previously, I use Simlab Composer...
                        I can import various 3D formats and to export an equal variety of different 3D formats, including SKP...
                        Although I haven't tested it with a Daz3D and/or Poser model, Artisan has a PolyReducer tool...
                        Whaat have also made the Polyreducer 0.1 plugin, but I really don't know how it work with such complex models...
                        If you're looking for external programs, Blender has a very good poly reducer tool...
                        Cheers
                        Kim Frederik
                        • jo-keJ
                          jo-ke
                          good news. Can't wait for the update.
                          Blender... well... hmmm... I started 7 years ago to understand blender but refused everytime. may be I have to try it one more time.
                          I think I have to reduce the polys before importing it to SU
                          http://www.zz7.de
                          • jo-keJ
                            jo-ke
                            I've had success this time.
                            I've exported a V4 via Poser to OBJ an imported it to SU. Reducing the mesh with meshlab outside SU wasn't possible. The file has 35 MB and took over an hour to import. Unfortunately all textures were lost and I had to retexture the whole body.
                            I've embeded to my scene, which has also about 50 MB. Unfotunately that was to much fรผr twilight and kerkythea, the xml has over 100 MB and couldn't be loaded to the Application.
                            So I gave up, hoping for a better capacity of future SU- Version and hoping for the new twilght version.
                            http://www.zz7.de
                            • FrederikF
                              Frederik
                              I haven't tested these models with TWR, however, like I wrote previously, you can import an OBJ file direct to KT and then merge it together with your SU scene...
                              Really can't see what the issue is... ๐Ÿ˜•
                              Cheers
                              Kim Frederik
                                Roger
                                Does she have a phone number?
                                http://www.azcreative.com
                                • BoxB
                                  As you already had the nudity warning and I was bored this morning I knocked up a bit of a sculpture to help soften the lines in your bathroom.
                                  • FrederikF
                                    Frederik
                                    Looks really good, Box... ๐Ÿ‘
                                    Cheers
                                    Kim Frederik
                                    • BoxB
                                      Thanks Frederik, I rather enjoy playing with Vertex tools.
                                      • jgbJ
                                        jgb
                                        Anybody ever tried creating a 3D model (car, room fixtures, etc) in SU and export it to DAZ? If yes, how?
                                        jgb
                                        • FrederikF
                                          Frederik
                                          That's easy...
                                          Export to i.e. OBJ and use the import function in Daz3D... ๐Ÿ˜„
                                          Cheers
                                          Kim Frederik
                                          • jgbJ
                                            jgb
                                            @frederik said:
                                            That's easy...
                                            If I had known it was that easy, I would have persevered with my copy of DAZ years ago.
                                            I found it a bit too steep on the learning curve, so I put it away.
                                            Stayed with my tried and true Disney(esque) cell by cell animation.
                                            All XXX rated of course. ๐Ÿ˜†
                                            jgb
                                            • 2 / 2
