    Sketchup not responding when handling more complex plugins
    15 Posts 9 Posters 6.4k Views 9 Watching
      Also switch Textures off - these eat memory.
      By 'minimize Styling' Dan means to use a Style that is without profiles, extensions, endpoints, jitter, line-styling, back-faces, watermarks, photo-matching, finest-transparency, xray-mode, etc etc... You can have different Scene tabs sets - one with a simple Style to use when doing complex editing and the others for 'presentation' etc...
      Shadows do take up a lot of processing to...
      Check your OpenGL settings are also optimized to give the best performance generally...
        darrentan
        Thanks for the reply.
        The problem I am facing now is that all the actions involving the curves or complex plugins cause my sketchup to stop responding (not crash-sorry for misusing the term earlier).
        My office computer, windows version, seems to work perfectly fine when i perform the similar actions. They usually take just seconds to complete, but on my macbook, the longest I waited was about 2 hours and it still wasn't responding.
        I have tried simple geometry just to get the plugin to work. Like trying to get a rectangle to bend along an arc in shape bender. No shadows or materials, working on a new file. It always get stuck at "finalizing all bends".
        Would a reinstall of my sketchup help? Everything else works fine though. Just the mentioned problems with the plugins.
          @darrentan said:
          I'm currently running on:
          macbook pro 8gb ram,
          2.4ghz osx lion v10.7.4
          sketchup pro 8.03
          8.03? The current version of SketchUp 8 for Mac is 8.0.15157. Where did you get version 8.03? Maybe that has something to do with it?
          • Dan RathbunD
            Dan Rathbun
            He likely means MR3, and should update to MR4 if he has not yet. (There are some Mac bug fixes in the latest release.)
            See Release Notes.
            I'm not here much anymore.
            • Dan RathbunD
              Dan Rathbun
              Also be sure the Outliner is closed.
                melosa
                Darren,
                Have you found a solution yet? I'm having the exact problems.
                Thanks,
                Melissa
                  Melissa, welcome to SCF.
                  So exactly what problem are you having? What plugin(s) do you have? What is the geometry like that you are trying to work on? Could you post an example SKP file?
                  • Dan RathbunD
                    Dan Rathbun
                    @darrentan said:
                    My SketchUp (Mac) stops responding [beachballs] whenever i am using more "complex" and curve-related plugins such as shape bender, round corners and fredo scale.
                    It would be best to contact the author of a specific plugin, by posting a query in the talk thread for that plugin. (It is usually in the Plugins forum.)
                    Generally... we developers have noticed that some of the API's geometry creation methods get overloaded when arrays of very precise Numeric values (expressed to many decimal places far beyond SketchUp's internal 0.001 inch tolerance,) are passed into these methods.
                    These methods perform MUCH better (and faster,) if the values passed in are first converted to Geom::Point3d objects OR Arrays of Length class objects (despite the fact that the API dictionary says that arrays of Numerics are compatible with most methods expecting Geom::Point3d or Geom::Vector3d objects.)
                    So it may also help, when contacting the plugin author, to tell them what you have the model units set to, and also the decimal precision you have set. (SketchUp still uses inches internally.)
                    πŸ’­
                      Sample model or screenshots would help so we have an idea of what we're talking about.
                      • B
                        broady0rr
                        2014 is not responding to Quit, have reinstalled, deleted 2013 etc. etc. [Mac 10.9.2, 8GB RAM.
                        2013 was performing absolutely fine. Also not Plugin Folder? Thanks, GB
                        • JQLJ
                          JQL
                          This is the first thing to do!
                          Close the Outliner and every complex plugin will be faster. Sometimes they're only useable with this turned on. Sometimes even simple plugins only work with this turned of. Take a look at the mirror plugin page.
                          www.casca.pt
                          Visit us on facebook!
                            saidgank
                            i have same problem.... http://saidgank.blogspot.com/2017/03/cara-mengatasi-not-responding-pada-SKETCHUP.html my sketchup always not responding
