    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 183.0k Views 109 Watching
    • EdsonE Offline
      Edson
      no problem. I will send you the file right away.
      http://www.mahfuz.arq.br
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Thanks, I'll take a look at it.
        • EdsonE Offline
          Edson
          LP has a nice feature that allows one to decide whether it opens when Sketchup starts or not. now, could you include something to tell it to open the main dialog at the same spot it was when Sketchup closed for the last time? right now it opens always on the same place of the screen.
            jiminy-billy-bob
            Oh? On Windows it remembers the position. Anyone else has the same issue?
              jiminy-billy-bob
              New version 0.10.2 beta !
              Changelog :
              • Better management of multiple models opened on OSX (You need to pan/orbit/zoom to trigger the change)
              • Added debug dialog
              • Fixed bug at startup
              Download in the plugin store !
              • F Offline
                function
                this keeps getting better and better. 😎
                i had an idea from a screen a few posts up. how about layer colors? and then on top of that, 'auto-color sub-group' this would be a great way to quickly locate layers when you are dealing with quite a few.
                thanks for the great plug
                  jiminy-billy-bob
                  Unfortunatly, there is no way to retreive or set the layer colors in the current versions of Sketchup. Let's hope Trimble adds it to the API in future versions!
                  Can you explain a bit more your 'auto-color sub-group' idea?
                    jiminy-billy-bob
                    New version 1.0.0 !
                    This is the first "stable" version. The plugin is now out of beta, as all features are now present, and it's running fine on OSX.
                    Changelog :
                    • Added layer colors for SketchUp 2014 (Right-click on a color to change it)
                    • Fixed issue with undo operations
                    http://i.imgur.com/UgA185k.png
                      jiminy-billy-bob
                      It was hard not to tell you this was coming.
                      The feature was ready and just waiting for SU2014 to officialy come out. πŸ˜„
                      Hope you guy will like it. Now Layers Panel has all the features of Su's default layers window.
                      • F Offline
                        function
                        awesome! thanks jiminy-billy-bob
                        by "auto-color groups" The idea was that layers could inherit the color of their group folder- this may cause problems with nested folders however
                        • EdsonE Offline
                          Edson
                          jbb,
                          I am still experiencing some difficulties on mac: there is always a missing layer comparing to what the native panel shows. until all the layers appear in your Layers Panel all the time it will be difficult to switch definitely to it.
                          please, keep up the great work.
                            jiminy-billy-bob
                            Even when using the debug dialog?
                            Could you send me your file?
                            • EdsonE Offline
                              Edson
                              jbb,
                              I am sorry. I had completely forgotten what you taught me. after debugging the missing layer showed up.
                              now I will be able to switch to LP. great.
                                jiminy-billy-bob
                                Glad to hear that!
                                • EdsonE Offline
                                  Edson
                                  one other thing that could be improved: the ability to accept characters from other languages, for instance, when I write PRAÇA (square in portuguese) I get what you see in the attached image (layer at bottom). could this be done?
                                  regards.
                                  • vremennyiV Offline
                                    vremennyi
                                    This plugin doesn't work on my laptop.
                                    After installing it shows, works. But after restarting SU it crashes.
                                    Stack:
                                    Error Loading File C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb
                                    Error; #<LoadError; cannot load such file -- Win32API>
                                    C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb;19;in `require'
                                    I'm using Win 8.1 x64.
                                      jiminy-billy-bob
                                      Edson > It works fine on windows, I'll look into it.
                                      vremennyi > Are you using the last version of Layers Panel? Is this a fresh install?
                                        jiminy-billy-bob
                                        Oh, I just reproduced this by accident. It seems to happen when opening an old file coming from SU2013. When saving it with SU2014 and restarting, it works fine. This is weird.
                                          vremennyi
                                          Yes, latest version 1.0.0.
                                          Reproduced on other PC. I removed SU2013, cleaned up folders and installed SU2014(Make) and plugin.
                                          I get this error just opening SU.
                                          This is really weird: after saving my old 2013 file and relaunch SU - plugin is working.
                                          Last opened file affects on plugin loading?
                                          • PixeroP Offline
                                            Pixero
                                            Now that its at 1.0 I desided to download it and it looks great.
                                            One wish though. Thea Render support.
                                            Oh and is it possible to doubleclick on panel to minimize it? Mine gets stuck as minimized.
                                            • 33
                                            • 34
                                            • 6 / 34
