    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.2k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      When first opened, Layers Panel sorts the layers in the order they were created. There is no way to recover the order of the layers window.
      As for the missing layers, could you send me the file by PM? (Even with all the geometry deleted if you're not comfortable with that)
      • EdsonE Offline
        Edson
        no problem. I will send you the file right away.
        http://www.mahfuz.arq.br
          jiminy-billy-bob
          Thanks, I'll take a look at it.
          • EdsonE Offline
            Edson
            LP has a nice feature that allows one to decide whether it opens when Sketchup starts or not. now, could you include something to tell it to open the main dialog at the same spot it was when Sketchup closed for the last time? right now it opens always on the same place of the screen.
              jiminy-billy-bob
              Oh? On Windows it remembers the position. Anyone else has the same issue?
                jiminy-billy-bob
                New version 0.10.2 beta !
                Changelog :
                • Better management of multiple models opened on OSX (You need to pan/orbit/zoom to trigger the change)
                • Added debug dialog
                • Fixed bug at startup
                Download in the plugin store !
                • F Offline
                  function
                  this keeps getting better and better. 😎
                  i had an idea from a screen a few posts up. how about layer colors? and then on top of that, 'auto-color sub-group' this would be a great way to quickly locate layers when you are dealing with quite a few.
                  thanks for the great plug
                    jiminy-billy-bob
                    Unfortunatly, there is no way to retreive or set the layer colors in the current versions of Sketchup. Let's hope Trimble adds it to the API in future versions!
                    Can you explain a bit more your 'auto-color sub-group' idea?
                      jiminy-billy-bob
                      New version 1.0.0 !
                      This is the first "stable" version. The plugin is now out of beta, as all features are now present, and it's running fine on OSX.
                      Changelog :
                      • Added layer colors for SketchUp 2014 (Right-click on a color to change it)
                      • Fixed issue with undo operations
                      http://i.imgur.com/UgA185k.png
                        jiminy-billy-bob
                        It was hard not to tell you this was coming.
                        The feature was ready and just waiting for SU2014 to officialy come out. πŸ˜„
                        Hope you guy will like it. Now Layers Panel has all the features of Su's default layers window.
                        • F Offline
                          function
                          awesome! thanks jiminy-billy-bob
                          by "auto-color groups" The idea was that layers could inherit the color of their group folder- this may cause problems with nested folders however
                          • EdsonE Offline
                            Edson
                            jbb,
                            I am still experiencing some difficulties on mac: there is always a missing layer comparing to what the native panel shows. until all the layers appear in your Layers Panel all the time it will be difficult to switch definitely to it.
                            please, keep up the great work.
                              jiminy-billy-bob
                              Even when using the debug dialog?
                              Could you send me your file?
                              • EdsonE Offline
                                Edson
                                jbb,
                                I am sorry. I had completely forgotten what you taught me. after debugging the missing layer showed up.
                                now I will be able to switch to LP. great.
                                  jiminy-billy-bob
                                  Glad to hear that!
                                  • EdsonE Offline
                                    Edson
                                    one other thing that could be improved: the ability to accept characters from other languages, for instance, when I write PRAÇA (square in portuguese) I get what you see in the attached image (layer at bottom). could this be done?
                                    regards.
                                    • vremennyiV Offline
                                      vremennyi
                                      This plugin doesn't work on my laptop.
                                      After installing it shows, works. But after restarting SU it crashes.
                                      Stack:
                                      Error Loading File C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb
                                      Error; #<LoadError; cannot load such file -- Win32API>
                                      C;/Users/vremennyi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb;19;in `require'
                                      I'm using Win 8.1 x64.
                                        jiminy-billy-bob
                                        Edson > It works fine on windows, I'll look into it.
                                        vremennyi > Are you using the last version of Layers Panel? Is this a fresh install?
                                          jiminy-billy-bob
                                          Oh, I just reproduced this by accident. It seems to happen when opening an old file coming from SU2013. When saving it with SU2014 and restarting, it works fine. This is weird.
                                            vremennyi
                                            Yes, latest version 1.0.0.
                                            Reproduced on other PC. I removed SU2013, cleaned up folders and installed SU2014(Make) and plugin.
                                            I get this error just opening SU.
                                            This is really weird: after saving my old 2013 file and relaunch SU - plugin is working.
                                            Last opened file affects on plugin loading?
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 30 / 34
