    Get rid of that black lines !!!
    21 Posts 7 Posters 10.6k Views 7 Watching
      The other apps have triangulated the faces.
      So there are lots of 'coplanar' edges.
      These can be erased using the Eraser to 'wipe them out' [you might need to double-click a group/component to get inside it in an 'edit'], or one of the 'Erase-Coplanar-Edges' tools available to batch process them.
      If you erase a diagonal-edge and its two faces vanish then that edge was not 'coplanar' and is needed to keep the faces.
      This can be common in poorly modeled geometry, where faces that really ought to be coplanar are just off.
      In this case you either need to remodel so the diagonal-edge is no longer needed, of you can 'hide' the edge [Erase+Shift].
      This will leave a visible change in the planes.
      If you want to hide that and have a 'smoothed' appearance then Erase+Ctrl will smooth the edge instead.
      If you want to see [and thereby select/edit] hidden/smoothed edges, you need to use View > Hidden Geometry > ON.
      You can unhide edges by using Erase+Shidt+Ctrl on them.
      To unsmooth an edge or edges you need to select it/them and use Entity-Info to uncheck the appropriate smooth/soft/hidden check-boxes...
      • cottyC
        cotty
        Can you share the model?
        my SketchUp gallery
        • mitcorbM
          mitcorb
          Hi:
          Here's an image of an interpretation from your image. I made the assumption that the wall thickness was 4" and made assumptions on other dimensions but lengthened the side wings. Modeled one half and mirrored.
            Andrerc
            Here is the file, and, nice rebuild dude ! If someone know how to get rid of them correctly, please do it and send him back here, I would appreciate it so much !
            XB4 Protector.skp
            • massimoM
              massimo Moderator
              Just manually erase those coplanar lines or use Thomthom's cleanup plugin.
              XB4 Protector.skp
              • BoxB
                Select all and use soften smooth. then clean up your edges,
                  Andrerc
                  What I also got before, was that when I round the edges, some of the triangle faces, just erased themselves...
                    If the object is very very small then SketchUp can't cope with very tiny facets [tolerance issue... where very close points are deemed to be coincident]
                    In that case scale it up x10 or x100.
                    Do the radius-ing - jeeping in mind that you need to scale up the radii...
                    Then the tiny facets will form.
                    Then scale it down x0.1 or x0.01...
                      Andrerc
                      Thanks Guys ! When i know select the object, and klick to round corners, he says : Some corners are unable to round off or something like that.
                      Also, like I sais before some faces are gone when I round something, the method from TIG don't works.
                      Is there a way to just select the hole model, click round and is just blends nicely everywhere with nice rounded corners?
                      • cottyC
                        cotty
                        There are a lot of very small corners in your design that will not allow you to do a simple round corner for the hole model...
                        my SketchUp gallery
                          Andrerc
                          I know, but is there no way to blend it all together? So it just nicely fits?
                            To start with... your model is too small.
                            It has tiny facets making rounding impossible.
                            Scale it up x10 or x100 and do the rounding before scaling back down again...
                            BUT it's not as simple as that...
                            Also there are some 'scrappy bits' of modeling - almost coplanar edges, tiny ledges etc.
                            As it's symmetrical I fixed one half and mirror copied it about a centerline.
                            I hope I interpreted what its form should be...
                            I assume you want a 'solid'.
                            It was NOT solid unless you adjusted some aspects.
                            The attached v8 SKP IS a solid and it's been scaled back to your original size.
                            [Units Snapping is still switched off - as having it 'on' makes manual moving of vertices, edges etc all but impossible...]
                            To round corners... scale x10, round assuming x10 in the radii.
                            Scale down x0.1 on completion...
                            XB4 Protector.skp
                            • cottyC
                              cotty
                              TIG was faster...
                              and I would suggest to simplify your model too.
                              my SketchUp gallery
                                Andrerc
                                Thanks TIG !
                                How did you get the lines even cotty?
                                • cottyC
                                  cotty
                                  I've only used the move tool.
                                  my SketchUp gallery
                                  • Jean LemireJ
                                    Jean Lemire
                                    Hi folks.
                                    Just a trick for those who are using SU Pro : export as dwg and reimport while checking the option to merge coplanar faces.
                                    Just ideas.
                                      Andrerc
                                      Could you send me the file Cotty? TIG's version is not mirrored completely straight...
                                      • cottyC
                                        cotty
                                        Sorry, I didn't save it because I only changed one face for illustration...
                                        my SketchUp gallery
                                          Andrerc
                                          Ow, could you redo it? Or not, it doesn't work out so well by me. Or could you straighten yours out TIG?
                                            I made it symmetrical about the Y axis [green] plane so the two halves ARE matching and 'consistent': based on the right-side which I sliced off and copied/mirrored.
                                            It may be that you didn't model the right-half exactly axially, so the parts are askew.
                                            Certainly the two sides has slight variations, but so slight it looked like sloppy modeling and not a minor variant on one side only...
                                            Since no one but you can know what you think it ought to look like, then I suggest you adjust the SKP I have given you to suit your desires.
                                            You can easily rotate its geometry so that the right side is say axial on the red X plane, or any way you want it to be.
                                            Then draw a large temporary face as a vertical plane on the Y axis [green] and intersect to make the cut line and erase the geometry from unwanted skewed half and the temporary plane/cutter.
                                            Then make a copy of the 'good' half [Move+Ctrl], set well off to the left side, and use Scale -1 on it to mirror it as the new left hand part.
                                            Snap the left part onto the right part.
                                            Now you have a solid object, that's reconfigured so its two symmetrical sides are arranged as YOU wish...
                                            You have spent more time discussing this that it would have taken to re-model it from scratch, entirely within SketchUp... 😒
