    Curved Staircases
    171 Posts 19 Posters 36.8k Views 19 Watching
      mwm5053
      @Driven
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • jeff hammondJ Offline
        @garry k said:
        Jeff have you tried with template of feet?
        yeah.. and i encountered another error with it (using the 2013 template Engineering - Feet
        i keeping getting the error 'Tread bullnose must be at least 1/2 of tread thickness'.
        the settings i'm using while getting that error are:
        Tread Thickness: 0.125' (or 1.5")
        Tread Bullnose: 0.083' (or 1")
        so the error message isn't corresponding to my settings (if i'm properly understanding the message and settings)
        My plan is to connect to web while in trial. Once a user is licensed then connecting to web site will no longer be necessary.
        oh.. i see. that sounds good
          Garry K
          Jeff - both the top and bottom of the tread get bullnosed. So you can't bullnose the top with a 1" radius and the bottom with a 1" radius.
          In this case the maximum bullnose for a 1.5" tread is 0.75".
            Garry K
            Walt - all I can think of doing is pulling out the http code and putting it into a very simple rb script ( not scrambled ).
            What user ID are you using? If it isn't the default "User" "test" then I will see what my logs show at the web site. We'll see if we made it that far.
              Garry K
              John - I looked at my PM messages - I have only received 1 since I put up version 1.0.7 08 Feb 2014, 08:39( which had the feet fix ).
              Your last message had to do with the beta version 2014.
                mwm5053
                @ Garry username is mwm5053. I have been able to Login to website with no problems still getting 101 error after clicking ok web dialogue pops up but clicking ok for default values nothing happens heres a screenshot.
                2011 iMac
                V2 Twilight
                  Garry K
                  Walt - If you look at the title of the web dialog it is saying "http error 0". Sorry about the confusion. I thought that it would be good to show the web dialog whether you have an error or not? I could change the back ground color from wheat to red or something like that.
                  The other thing to note is that you may need more accuracy than 1/2" precision to properly draw a stair case. I'm not exactly sure how sketchup handles smaller values than precision.
                  If you let the defaults.txt file to "User" and "test" and connected then you should see "Testing - temporary status granted"
                  If you edited defaults.txt file to "mwm5053" and put in the emailed password then you should see "You have 30 days left in trial"
                    mwm5053
                    I changed defaults txt back to user / test and precision to 1/64 still get screenshot error
                    2011 iMac
                    V2 Twilight
                      Garry K
                      Walt - I went to my web site and took a look. There isn't a single http attempt for user "mwm5053".
                      I also looked at all of my registered users and there isn't a user "mwm5053" in that file.
                      You need to go to my web site - CabMaker32.com and click logon and register. You will then receive an email with your password. You can also send me a private message with your email address. I can also look in my user file and see if that email address has been registered under perhaps a different user.
                        mwm5053
                        Now thats really weird
                        2011 iMac
                        V2 Twilight
                          that's what i thought.. you may want to consider changing the wording of the error message then:
                          to something along the lines of:
                          max bullnose is 1/2 tread thickness.
                            driven
                            @Garry
                            it's working in 'feet' Template now...
                            the cache reset took a couple of goes...
                            added some info so you can see what I get my end...
                            Ruby version is _____________ 1.8.5 Sketchup version is __________ 13.0.4811 Sketchup version path is __________ /Applications/SketchUp 2013/SketchUp.app Sketchup process pid is __________ 86823 @modPath is __________ unsaved stair time 0.922734 stair time 0.922350
                            <html><head>
                            <meta http-equiv="MSThemeCompatible" content="Yes">
                            <style type="text/css">
                              * { padding; 0; margin; 0; }
                              body { background-color; #F9EBD1}
                              fieldset { float; left; background-color; #F9EBD1; border-color; black; margin; 3px;}
                              fieldset p {display; table-row;
                            			  font-family; Arial, Helvetica, sans-serif;
                            			  font-size; 90%; color; black; height; 27px;}
                              fieldset input,
                              fieldset select,
                              fieldset label {display; table-cell; margin; 2px; width; 120px;}
                              fieldset label {text-align; right;}
                              fieldset input,
                              fieldset select {margin-left; 10px; background-color; wheat;}
                            </style>
                            </head>
                            <body>
                            <form>
                                <fieldset>
                                    <p><label>Inside Stringer;</label><select id="inside_stringer"><option>Housed</option><option>Sawtooth</option><option>None</option></select></p>
                                    <p><label>Options;</label><select id="inside_option"><option>Has Heel</option><option>Has Foot</option><option>Both</option><option>None</option></select></p>
                                    <p><label>Thickness;</label><input type="text" id="inside_thickness"></p>
                                    <p><label>Width;</label><input type="text" id="inside_width"></p>
                                    <p><label>Rail Options;</label><select id="inside_rail"><option>Guard Rail</option><option>Wall Rail</option><option>None</option></select></p>
                                </fieldset>
                                <fieldset>
                                    <p><label title="Set to none for a spiral where spindles are used to tie the treads togethers">Outside
                                        Stringer;</label><select id="outside_stringer"><option>Housed</option><option>Sawtooth</option><option>None</option></select></p>
                                    <p><label>Options;</label><select id="outside_option"><option>Has Heel</option><option>Has Foot</option><option>Both</option><option>None</option></select></p>
                                    <p><label>Thickness;</label><input type="text" id="outside_thickness"></p>
                                    <p><label>Width;</label><input type="text" id="outside_width"></p>
                                    <p><label>Rail Options;</label><select id="outside_rail"><option>Guard Rail</option><option>Wall Rail</option><option>None</option></select></p>
                                </fieldset>
                                <fieldset>
                                    <p><label>Stair Direction;</label><select id="direction"><option>Clockwise</option><option>Anti Clockwise</option></select></p>
                                    <p><label>Stair Width;</label><input type="text" id="stair_width"></p>
                                    <p><label title="Set to 0 and StairMaker will calculate based on degrees and Average Run">Radius;</label><input type="text" id="radius"></p>
                                    <p><label title="Set to 0 and StairMaker will calculate based on radius and Average Run">Degrees;</label><input type="text" id="degrees"></p>
                                    <p><label>Rail Style;</label><select id="rail_style"><option>Classic</option><option>Modern</option><option>Round</option><option>Square</option><option>Standard</option><option>Traditional</option></select></p>
                                    <p><label>Open Risers;</label><input type="checkbox" id="open_riser"></p>
                                    <p><label>Total Rise;</label><input type="text" id="total_rise"></p>
                                    <p><label>Risers;</label><input type="text" id="risers"></p>
                                    <p><label>Riser Thickness;</label><input type="text" id="riser_thickness"></p>
                                </fieldset>
                                <fieldset>
                                    <p><label>Tread Thickness;</label><input type="text" id="tread_thickness"></p>
                                    <p><label title="Average Run is ignored if both Radius and Degrees are set">Average Run;</label><input type="text" id="average_run"></p>
                                    <p><label>Tread Bullnose;</label><input type="text" id="tread_bullnose"></p>
                                    <p><label>Nosing;</label><input type="text" id="nosing"></p>
                                    <p><label>Flare Amount;</label><input type="text" id="flare_amount"></p>
                            		<p><label>Progressive Flare;</label><input type="text" id="progressive_flare"></p>
                                    <p><label>Flare Count;</label><input type="text" id="flare_count"></p>
                                    <p><label>Floor Thickness;</label><input type="text" id="floor_thickness"></p>
                                    <p><label>Create Stair;</label><input type="button" onclick="do_click()" style="background; silver" value="OK"></p>
                                </fieldset>
                            </form>
                            <script type="text/javascript">
                            if ( document.addEventListener )
                            	document.addEventListener( "DOMContentLoaded", ready, false );
                            else if ( document.attachEvent )
                            	document.attachEvent( "onreadystatechange", check_ready );
                            function do_click()
                               var items  = document.getElementsByTagName( '*' );
                               var count  = items.length;
                               var text   = "";
                               for ( var i = 0; i < count; i++ )
                            	  if ( items[i].type == "select-one" )
                            		 value = items[i].options[items[i].selectedIndex].value;
                            	  else if ( items[i].type == "text" )
                            		 value = items[i].value.replace(/'/g, '`');
                            	  else if ( items[i].type == "checkbox" )
                            		 value = items[i].checked.toString();
                            	  else
                            		 value = "";
                            	  if ( value.length > 0 )
                            		  if ( text.length > 0 )
                            			 text += "&";
                            		  text += ( items[i].id + "=" + value );
                               ruby_call( text );
                            function from_ruby( data )
                            	var element;
                            	var pair;
                            	var pairs = data.split( '&' );
                            	var count = pairs.length;
                            		pair = pairs[i].split( '=' );
                            		element = document.getElementById( pair[0] );
                            		if ( element.type == "select-one" )
                            			if ( pair[1].indexOf('|') == -1 )
                            				element.selectedIndex = pair[1];
                            			else
                            				populate_drop_down( element, pair[1] );
                            		else if ( element.type == "text" )
                            			element.value = pair[1].replace(/`/g, "'");
                            		else if ( element.type == "checkbox" )
                            			element.checked = pair[1] == '1';
                            function populate_drop_down( element, data )
                            	var options = data.split( '|' );
                            	var count   = options.length;
                            	var option;
                            	element.innerText = "";
                            		option = document.createElement( "option" );
                            		option.text = options[i];
                            		element.add( option, null );
                            function ruby_call( text )
                               query = 'skp;ruby_callback@' + text;
                               window.location.href = query;
                            function check_ready()
                            	if ( document.readyState === "complete" )
                            		ready();
                            function ready()
                               ruby_call( 'loaded' );
                            </script>
                            </body></html>
                              Garry K
                              Jeff - Good catch. You are correct - the message is worded wrong. I have changed it for the next version.
                                Garry K
                                Walt - that is wierd - you normally don't see that screen. The web hosting site has been experiencing hack attacks. Please tell me if you see this screen again.
                                  Garry K
                                  Walt - put this rb into your plugins folder and see what you get.
                                  There will be a menu item under plugins called "Web Dialog Test"
                                  test file
                                    mwm5053
                                    Here's my results.
                                    I wonder what the deal is about my login on your site?
                                    2011 iMac
                                    V2 Twilight
                                      Garry K
                                      Walt - I'm sorry but I can't answer that question. I haven't heard anyone else having that problem. It may have something to do with http configurations on your specific machine.
                                      Maybe someone else can answer it. Perhaps start a new thread on this. Maybe the developer forum will catch some attention.
                                      As you can see - the code isn't doing a whole lot.
                                        mwm5053
                                        @ Garry you're right I installed 1.0.8 rbz on Mac Book Pro and works great with no hitches. Mac Pro (desktop) running SU 8 and Lion and Mac Book Pro (laptop) running SU 8 and Mavericks. 😉
                                        2011 iMac
                                        V2 Twilight
                                          Garry K
                                          I now have language translation working. There is a folder called translations and currently there are 4 files in it.
                                          en.lang - English
                                          fr.lang - French
                                          ru.lang - Russian
                                          zh.lang - Chineses ( traditional )
                                          Near the top of the defaults.txt file there is a language= section where you can enter the 2 character language code. If you leave the language= blank the system will try to figure out the locale code.
                                          These language files are straight translations and as a result there might be some funny and or inappropriate translations.
                                          Anyone interested in helping out with any language translation can get a hold of me.
                                          French Stair Maker
                                          Russian Stair Maker
                                          Chinese Stair Maker
                                            Garry K
                                            A user with a windows 8 machine running SU 2013 has reported an error that I can't duplicate ( I don't have a windows 8 machine )
                                            puts "starting: dialog.execute_script( js_command )"
                                            this code doesn't run
                                            puts "finished: dialog.execute_script( js_command )"
                                            it errors out with this
                                            type: mismatch
                                            code: 0
                                            url: file:///C:/Users/Admin/AppData/Local/Temp/skp8C34.tmp
                                            Is there anyone else with a Windows 8 machine running 2013 who would be willing to try this code.
                                            ` require 'sketchup.rb'
                                            show_dialog
                                            def show_dialog()
                                            dlg = UI::WebDialog.new( "Stair Measurements", false, "DialogTest", 200, 150, 150, 150, true );
                                            dlg.add_action_callback( "ruby_callback" ) { |dialog, params|
                                            text = params.to_s
                                            	if( text == 'loaded' )
                                            		args =  'inside_stringer=Housed|Sawtooth|None' +
                                            				'&inside_stringer=1' +
                                            				'&inside_option=Has Heel|Has Foot|Both|None' +
                                            				'&inside_option=3' +
                                            				'&inside_thickness=60' +
                                            				'&inside_width=300' +
                                            				'&inside_rail=Guard Rail|Wall Rail|None' +
                                            				'&inside_rail=2' +
                                            				'&outside_stringer=Housed|Sawtooth|None' +
                                            				'&outside_stringer=0' +
                                            				'&outside_option=Has Heel|Has Foot|Both|None' +
                                            				'&outside_option=3' +
                                            				'&outside_thickness=60' +
                                            				'&outside_width=400' +
                                            				'&outside_rail=Guard Rail|Wall Rail|None' +
                                            				'&outside_rail=2' +
                                            				'&total_rise=2667' +
                                            				'&risers=15' +
                                            				'&riser_thickness=12.7' +
                                            				'&direction=Clockwise|Anti Clockwise' +
                                            				'&direction=1' +
                                            				'&stair_width=1000' +
                                            				'&radius=2400' +
                                            				'&degrees=90' +
                                            				'&floor_thickness=60' +
                                            				'&rail_style=Classic|Modern|Round|Square|Standard|Traditional' +
                                            				'&rail_style=4' +
                                            				'&tread_thickness=38' +
                                            				'&average_run=254' +
                                            				'&tread_bullnose=12.7' +
                                            				'&nosing=25.4' +
                                            				'&flare_amount=0' +
                                            				'&progressive_flare=20' +
                                            				'&flare_count=0'
                                            		js_command = "from_ruby( '" + args + "' )"
                                            		puts( js_command )
                                            	else
                                            		UI.messagebox( text )
                                            		puts( text )
                                            dialog.close();
                                              html = <<-HTML
                                            <!DOCTYPE html>
                                            <html>
                                            body { background-color: #F9EBD1}
                                            fieldset { float: left; background-color: #F9EBD1; border-color: black; margin: 3px;}
                                            fieldset p {display: table-row;
                                            font-family: Arial, Helvetica, sans-serif;
                                            font-size: 90%;
                                            color: black;
                                            height: 27px}
                                            fieldset input,
                                            fieldset select,
                                            fieldset label {display: table-cell; margin: 2px; width: 120px }
                                            fieldset label {text-align: right;}
                                            fieldset input,
                                            fieldset select {margin-left: 10px; background-color: wheat;}
                                            </style>
                                            <head>
                                            <script>
                                            function do_click()
                                            var text = "";
                                            value = items[i].value;
                                            else
                                            value = "";
                                            		 text += "&";
                                            ruby_call( text );
                                            var element;
                                            var pair;
                                            		else
                                            		element.value = pair[1];
                                            var option;
                                            element.innerHTML = "";
                                            query = 'skp:ruby_callback@' + text;
                                            function on_load()
                                            </script>
                                            </head>
                                            <body onload="on_load()">
                                            <form>
                                            <fieldset>
                                            <p><label>Inside Stringer:</label><select id="inside_stringer"></select></p>
                                            <p><label>Options:</label><select id="inside_option"></select></p>
                                            <p><label>Thickness:</label><input type="text" id="inside_thickness"</p>
                                            <p><label>Width:</label><input type="text" id="inside_width"</p>
                                            <p><label>Rail Options:</label><select id="inside_rail"></select></p>
                                            </fieldset>
                                            <fieldset>
                                            <p><label>Outside Stringer:</label><select id="outside_stringer"></select></p>
                                            <p><label>Options:</label><select id="outside_option"></select></p>
                                            <p><label>Thickness:</label><input type="text" id="outside_thickness"</p>
                                            <p><label>Width:</label><input type="text" id="outside_width"</p>
                                            <p><label>Rail Options:</label><select id="outside_rail"></select></p>
                                            </fieldset>
                                            <fieldset>
                                            <p><label>Stair Direction:</label><select id="direction"></select></p>
                                            <p><label>Stair Width:</label><input type="text" id="stair_width"</p>
                                            <p><label>Radius:</label><input type="text" id="radius"</p>
                                            <p><label>Degrees:</label><input type="text" id="degrees"</p>
                                            <p><label>Rail Style:</label><select id="rail_style"></select></p>
                                            <p><label>Open Risers:</label><input type="checkbox" id="open_riser"</p>
                                            <p><label>Total Rise:</label><input type="text" id="total_rise"</p>
                                            <p><label>Risers:</label><input type="text" id="risers"</p>
                                            <p><label>Riser Thickness:</label><input type="text" id="riser_thickness"</p>
                                            </fieldset>
                                            <fieldset>
                                            <p><label>Tread Thickness:</label><input type="text" id="tread_thickness"</p>
                                            <p><label>Average Run:</label><input type="text" id="average_run"</p>
                                            <p><label>Tread Bullnose:</label><input type="text" id="tread_bullnose"</p>
                                            <p><label>Nosing:</label><input type="text" id="nosing"</p>
                                            <p><label>Flare Amount:</label><input type="text" id="flare_amount"</p>
                                            <p><label>Progressive Flare:</label><input type="text" id="progressive_flare"</p>
                                            <p><label>Flare Count:</label><input type="text" id="flare_count"</p>
                                            <p><label>Floor Thickness:</label><input type="text" id= "floor_thickness"</p>
                                            <p><label>Create Stair:</label><input type="button" onclick="do_click()" style="background: silver" value="Ok"></p>
                                            </fieldset>
                                            </form>
                                            </body>
                                            </html>
                                              HTML
                                              dlg.set_html html
                                              dlg.show
                                            if ( not file_loaded?( "dialog_test.rb" ) )
                                            UI.menu( "Plugins" ).add_item( "Web Dialog Test" ) { show_dialog() }
                                            file_loaded( "dialog_test.rb" )
                                            • 4 / 9
