    Curved Staircases
    171 Posts 19 Posters 54.1k Views 19 Watching
      mwm5053
      Ok so I got the two screen shots to show what I'm getting but after pressing ok with defaults noting happens.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        driven
        Hi garry
        I'm still getting the 'extra' <body''> tag, with 'feet' templates, which prevents the load...
        other templates are fine...
        You most likely don't see two tags as WebKit always makes tags for any missing or malformed ones.
        It doesn't remove the malformed ones, so if they contain js or html control chars, the page will fail to varying degrees...
        I cleared my SU cache but sometimes that needs to be done with a restart... will try later
          Garry K
          Walt,
          It appears there can be many different problems that can cause an http error code 0. In the majority of cases it has to do with configuration. Essentially - the host is unreachable. Some google searches suggest that it is a firewall issue.
          Try going to your browser and enter this
          cabmaker32.com/stairmaker_service.php
          If you can reach the service from the browser you should get back
          {"code":-11,"text":"invalid format","token":240583372}
          • jeff hammondJ Offline
            @mwm5053 said:
            Still having problems here. I installed 1.0.7 and changed username and password in default txt, on 1st click getting "http error" and clicking again getting "can not reach web server"
            oh.. right. that's a different issue (the whole connecting to a website prior to using a ruby.. I mean, what is someone supposed to do if they're not online while drawing??)
            the fix I was talking about had to do with model units
              mwm5053
              @ Garry yes I get {"code":-11,"text":"invalid format","token":240583372}
              In Safari
              2011 iMac
              V2 Twilight
                Garry K
                Jeff have you tried with template of feet?
                My plan is to connect to web while in trial. Once a user is licensed then connecting to web site will no longer be necessary.
                  Garry K
                  John - can you send me a file with the extra tags and the malformed ones.
                    driven
                    @Walt
                    what do you get if you paste this in 'Ruby Console'
                     status = Sketchup.is_online
                    @Garry I PM'd them the other day?
                      mwm5053
                      @Driven
                      2011 iMac
                      V2 Twilight
                        yeah.. and i encountered another error with it (using the 2013 template Engineering - Feet
                        i keeping getting the error 'Tread bullnose must be at least 1/2 of tread thickness'.
                        the settings i'm using while getting that error are:
                        Tread Thickness: 0.125' (or 1.5")
                        Tread Bullnose: 0.083' (or 1")
                        so the error message isn't corresponding to my settings (if i'm properly understanding the message and settings)
                        oh.. i see. that sounds good
                          Garry K
                          Jeff - both the top and bottom of the tread get bullnosed. So you can't bullnose the top with a 1" radius and the bottom with a 1" radius.
                          In this case the maximum bullnose for a 1.5" tread is 0.75".
                            Garry K
                            Walt - all I can think of doing is pulling out the http code and putting it into a very simple rb script ( not scrambled ).
                            What user ID are you using? If it isn't the default "User" "test" then I will see what my logs show at the web site. We'll see if we made it that far.
                              Garry K
                              John - I looked at my PM messages - I have only received 1 since I put up version 1.0.7 08 Feb 2014, 08:39( which had the feet fix ).
                              Your last message had to do with the beta version 2014.
                                mwm5053
                                @ Garry username is mwm5053. I have been able to Login to website with no problems still getting 101 error after clicking ok web dialogue pops up but clicking ok for default values nothing happens heres a screenshot.
                                2011 iMac
                                V2 Twilight
                                  Garry K
                                  Walt - If you look at the title of the web dialog it is saying "http error 0". Sorry about the confusion. I thought that it would be good to show the web dialog whether you have an error or not? I could change the back ground color from wheat to red or something like that.
                                  The other thing to note is that you may need more accuracy than 1/2" precision to properly draw a stair case. I'm not exactly sure how sketchup handles smaller values than precision.
                                  If you let the defaults.txt file to "User" and "test" and connected then you should see "Testing - temporary status granted"
                                  If you edited defaults.txt file to "mwm5053" and put in the emailed password then you should see "You have 30 days left in trial"
                                    mwm5053
                                    I changed defaults txt back to user / test and precision to 1/64 still get screenshot error
                                    2011 iMac
                                    V2 Twilight
                                      Garry K
                                      Walt - I went to my web site and took a look. There isn't a single http attempt for user "mwm5053".
                                      I also looked at all of my registered users and there isn't a user "mwm5053" in that file.
                                      You need to go to my web site - CabMaker32.com and click logon and register. You will then receive an email with your password. You can also send me a private message with your email address. I can also look in my user file and see if that email address has been registered under perhaps a different user.
                                        mwm5053
                                        Now thats really weird
                                        2011 iMac
                                        V2 Twilight
                                          that's what i thought.. you may want to consider changing the wording of the error message then:
                                          to something along the lines of:
                                          max bullnose is 1/2 tread thickness.
                                            driven
                                            @Garry
                                            it's working in 'feet' Template now...
                                            the cache reset took a couple of goes...
                                            added some info so you can see what I get my end...
                                            Ruby version is _____________ 1.8.5 Sketchup version is __________ 13.0.4811 Sketchup version path is __________ /Applications/SketchUp 2013/SketchUp.app Sketchup process pid is __________ 86823 @modPath is __________ unsaved stair time 0.922734 stair time 0.922350
                                            <html><head>
                                            <meta http-equiv="MSThemeCompatible" content="Yes">
                                            <style type="text/css">
                                              * { padding; 0; margin; 0; }
                                              body { background-color; #F9EBD1}
                                              fieldset { float; left; background-color; #F9EBD1; border-color; black; margin; 3px;}
                                              fieldset p {display; table-row;
                                            			  font-family; Arial, Helvetica, sans-serif;
                                            			  font-size; 90%; color; black; height; 27px;}
                                              fieldset input,
                                              fieldset select,
                                              fieldset label {display; table-cell; margin; 2px; width; 120px;}
                                              fieldset label {text-align; right;}
                                              fieldset input,
                                              fieldset select {margin-left; 10px; background-color; wheat;}
                                            </style>
                                            </head>
                                            <body>
                                            <form>
                                                <fieldset>
                                                    <p><label>Inside Stringer;</label><select id="inside_stringer"><option>Housed</option><option>Sawtooth</option><option>None</option></select></p>
                                                    <p><label>Options;</label><select id="inside_option"><option>Has Heel</option><option>Has Foot</option><option>Both</option><option>None</option></select></p>
                                                    <p><label>Thickness;</label><input type="text" id="inside_thickness"></p>
                                                    <p><label>Width;</label><input type="text" id="inside_width"></p>
                                                    <p><label>Rail Options;</label><select id="inside_rail"><option>Guard Rail</option><option>Wall Rail</option><option>None</option></select></p>
                                                </fieldset>
                                                <fieldset>
                                                    <p><label title="Set to none for a spiral where spindles are used to tie the treads togethers">Outside
                                                        Stringer;</label><select id="outside_stringer"><option>Housed</option><option>Sawtooth</option><option>None</option></select></p>
                                                    <p><label>Options;</label><select id="outside_option"><option>Has Heel</option><option>Has Foot</option><option>Both</option><option>None</option></select></p>
                                                    <p><label>Thickness;</label><input type="text" id="outside_thickness"></p>
                                                    <p><label>Width;</label><input type="text" id="outside_width"></p>
                                                    <p><label>Rail Options;</label><select id="outside_rail"><option>Guard Rail</option><option>Wall Rail</option><option>None</option></select></p>
                                                </fieldset>
                                                <fieldset>
                                                    <p><label>Stair Direction;</label><select id="direction"><option>Clockwise</option><option>Anti Clockwise</option></select></p>
                                                    <p><label>Stair Width;</label><input type="text" id="stair_width"></p>
                                                    <p><label title="Set to 0 and StairMaker will calculate based on degrees and Average Run">Radius;</label><input type="text" id="radius"></p>
                                                    <p><label title="Set to 0 and StairMaker will calculate based on radius and Average Run">Degrees;</label><input type="text" id="degrees"></p>
                                                    <p><label>Rail Style;</label><select id="rail_style"><option>Classic</option><option>Modern</option><option>Round</option><option>Square</option><option>Standard</option><option>Traditional</option></select></p>
                                                    <p><label>Open Risers;</label><input type="checkbox" id="open_riser"></p>
                                                    <p><label>Total Rise;</label><input type="text" id="total_rise"></p>
                                                    <p><label>Risers;</label><input type="text" id="risers"></p>
                                                    <p><label>Riser Thickness;</label><input type="text" id="riser_thickness"></p>
                                                </fieldset>
                                                <fieldset>
                                                    <p><label>Tread Thickness;</label><input type="text" id="tread_thickness"></p>
                                                    <p><label title="Average Run is ignored if both Radius and Degrees are set">Average Run;</label><input type="text" id="average_run"></p>
                                                    <p><label>Tread Bullnose;</label><input type="text" id="tread_bullnose"></p>
                                                    <p><label>Nosing;</label><input type="text" id="nosing"></p>
                                                    <p><label>Flare Amount;</label><input type="text" id="flare_amount"></p>
                                            		<p><label>Progressive Flare;</label><input type="text" id="progressive_flare"></p>
                                                    <p><label>Flare Count;</label><input type="text" id="flare_count"></p>
                                                    <p><label>Floor Thickness;</label><input type="text" id="floor_thickness"></p>
                                                    <p><label>Create Stair;</label><input type="button" onclick="do_click()" style="background; silver" value="OK"></p>
                                                </fieldset>
                                            </form>
                                            <script type="text/javascript">
                                            if ( document.addEventListener )
                                            	document.addEventListener( "DOMContentLoaded", ready, false );
                                            else if ( document.attachEvent )
                                            	document.attachEvent( "onreadystatechange", check_ready );
                                            function do_click()
                                               var items  = document.getElementsByTagName( '*' );
                                               var count  = items.length;
                                               var text   = "";
                                               for ( var i = 0; i < count; i++ )
                                            	  if ( items[i].type == "select-one" )
                                            		 value = items[i].options[items[i].selectedIndex].value;
                                            	  else if ( items[i].type == "text" )
                                            		 value = items[i].value.replace(/'/g, '`');
                                            	  else if ( items[i].type == "checkbox" )
                                            		 value = items[i].checked.toString();
                                            	  else
                                            		 value = "";
                                            	  if ( value.length > 0 )
                                            		  if ( text.length > 0 )
                                            			 text += "&";
                                            		  text += ( items[i].id + "=" + value );
                                               ruby_call( text );
                                            function from_ruby( data )
                                            	var element;
                                            	var pair;
                                            	var pairs = data.split( '&' );
                                            	var count = pairs.length;
                                            		pair = pairs[i].split( '=' );
                                            		element = document.getElementById( pair[0] );
                                            		if ( element.type == "select-one" )
                                            			if ( pair[1].indexOf('|') == -1 )
                                            				element.selectedIndex = pair[1];
                                            			else
                                            				populate_drop_down( element, pair[1] );
                                            		else if ( element.type == "text" )
                                            			element.value = pair[1].replace(/`/g, "'");
                                            		else if ( element.type == "checkbox" )
                                            			element.checked = pair[1] == '1';
                                            function populate_drop_down( element, data )
                                            	var options = data.split( '|' );
                                            	var count   = options.length;
                                            	var option;
                                            	element.innerText = "";
                                            		option = document.createElement( "option" );
                                            		option.text = options[i];
                                            		element.add( option, null );
                                            function ruby_call( text )
                                               query = 'skp;ruby_callback@' + text;
                                               window.location.href = query;
                                            function check_ready()
                                            	if ( document.readyState === "complete" )
                                            		ready();
                                            function ready()
                                               ruby_call( 'loaded' );
                                            </script>
                                            </body></html>
                                            • 8 / 9
