    Curved Staircases
    171 Posts 19 Posters 62.5k Views 19 Watching
      mwm5053
      Now thats really weird
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • jeff hammondJ
        @garry k said:
        Jeff - both the top and bottom of the tread get bullnosed. So you can't bullnose the top with a 1" radius and the bottom with a 1" radius.
        In this case the maximum bullnose for a 1.5" tread is 0.75".
        that's what i thought.. you may want to consider changing the wording of the error message then:
        'Tread bullnose must be at least 1/2 of tread thickness'
        to something along the lines of:
        max bullnose is 1/2 tread thickness.
          driven
          @Garry
          it's working in 'feet' Template now...
          the cache reset took a couple of goes...
          added some info so you can see what I get my end...
          Ruby version is _____________ 1.8.5 Sketchup version is __________ 13.0.4811 Sketchup version path is __________ /Applications/SketchUp 2013/SketchUp.app Sketchup process pid is __________ 86823 @modPath is __________ unsaved stair time 0.922734 stair time 0.922350
          <html><head>
          <meta http-equiv="MSThemeCompatible" content="Yes">
          <style type="text/css">
            * { padding; 0; margin; 0; }
            body { background-color; #F9EBD1}
            fieldset { float; left; background-color; #F9EBD1; border-color; black; margin; 3px;}
            fieldset p {display; table-row;
          			  font-family; Arial, Helvetica, sans-serif;
          			  font-size; 90%; color; black; height; 27px;}
            fieldset input,
            fieldset select,
            fieldset label {display; table-cell; margin; 2px; width; 120px;}
            fieldset label {text-align; right;}
            fieldset input,
            fieldset select {margin-left; 10px; background-color; wheat;}
          </style>
          </head>
          <body>
          <form>
              <fieldset>
                  <p><label>Inside Stringer;</label><select id="inside_stringer"><option>Housed</option><option>Sawtooth</option><option>None</option></select></p>
                  <p><label>Options;</label><select id="inside_option"><option>Has Heel</option><option>Has Foot</option><option>Both</option><option>None</option></select></p>
                  <p><label>Thickness;</label><input type="text" id="inside_thickness"></p>
                  <p><label>Width;</label><input type="text" id="inside_width"></p>
                  <p><label>Rail Options;</label><select id="inside_rail"><option>Guard Rail</option><option>Wall Rail</option><option>None</option></select></p>
              </fieldset>
              <fieldset>
                  <p><label title="Set to none for a spiral where spindles are used to tie the treads togethers">Outside
                      Stringer;</label><select id="outside_stringer"><option>Housed</option><option>Sawtooth</option><option>None</option></select></p>
                  <p><label>Options;</label><select id="outside_option"><option>Has Heel</option><option>Has Foot</option><option>Both</option><option>None</option></select></p>
                  <p><label>Thickness;</label><input type="text" id="outside_thickness"></p>
                  <p><label>Width;</label><input type="text" id="outside_width"></p>
                  <p><label>Rail Options;</label><select id="outside_rail"><option>Guard Rail</option><option>Wall Rail</option><option>None</option></select></p>
              </fieldset>
              <fieldset>
                  <p><label>Stair Direction;</label><select id="direction"><option>Clockwise</option><option>Anti Clockwise</option></select></p>
                  <p><label>Stair Width;</label><input type="text" id="stair_width"></p>
                  <p><label title="Set to 0 and StairMaker will calculate based on degrees and Average Run">Radius;</label><input type="text" id="radius"></p>
                  <p><label title="Set to 0 and StairMaker will calculate based on radius and Average Run">Degrees;</label><input type="text" id="degrees"></p>
                  <p><label>Rail Style;</label><select id="rail_style"><option>Classic</option><option>Modern</option><option>Round</option><option>Square</option><option>Standard</option><option>Traditional</option></select></p>
                  <p><label>Open Risers;</label><input type="checkbox" id="open_riser"></p>
                  <p><label>Total Rise;</label><input type="text" id="total_rise"></p>
                  <p><label>Risers;</label><input type="text" id="risers"></p>
                  <p><label>Riser Thickness;</label><input type="text" id="riser_thickness"></p>
              </fieldset>
              <fieldset>
                  <p><label>Tread Thickness;</label><input type="text" id="tread_thickness"></p>
                  <p><label title="Average Run is ignored if both Radius and Degrees are set">Average Run;</label><input type="text" id="average_run"></p>
                  <p><label>Tread Bullnose;</label><input type="text" id="tread_bullnose"></p>
                  <p><label>Nosing;</label><input type="text" id="nosing"></p>
                  <p><label>Flare Amount;</label><input type="text" id="flare_amount"></p>
          		<p><label>Progressive Flare;</label><input type="text" id="progressive_flare"></p>
                  <p><label>Flare Count;</label><input type="text" id="flare_count"></p>
                  <p><label>Floor Thickness;</label><input type="text" id="floor_thickness"></p>
                  <p><label>Create Stair;</label><input type="button" onclick="do_click()" style="background; silver" value="OK"></p>
              </fieldset>
          </form>
          <script type="text/javascript">
          if ( document.addEventListener )
          	document.addEventListener( "DOMContentLoaded", ready, false );
          else if ( document.attachEvent )
          	document.attachEvent( "onreadystatechange", check_ready );
          function do_click()
             var items  = document.getElementsByTagName( '*' );
             var count  = items.length;
             var text   = "";
             for ( var i = 0; i < count; i++ )
          	  if ( items[i].type == "select-one" )
          		 value = items[i].options[items[i].selectedIndex].value;
          	  else if ( items[i].type == "text" )
          		 value = items[i].value.replace(/'/g, '`');
          	  else if ( items[i].type == "checkbox" )
          		 value = items[i].checked.toString();
          	  else
          		 value = "";
          	  if ( value.length > 0 )
          		  if ( text.length > 0 )
          			 text += "&";
          		  text += ( items[i].id + "=" + value );
             ruby_call( text );
          function from_ruby( data )
          	var element;
          	var pair;
          	var pairs = data.split( '&' );
          	var count = pairs.length;
          		pair = pairs[i].split( '=' );
          		element = document.getElementById( pair[0] );
          		if ( element.type == "select-one" )
          			if ( pair[1].indexOf('|') == -1 )
          				element.selectedIndex = pair[1];
          			else
          				populate_drop_down( element, pair[1] );
          		else if ( element.type == "text" )
          			element.value = pair[1].replace(/`/g, "'");
          		else if ( element.type == "checkbox" )
          			element.checked = pair[1] == '1';
          function populate_drop_down( element, data )
          	var options = data.split( '|' );
          	var count   = options.length;
          	var option;
          	element.innerText = "";
          		option = document.createElement( "option" );
          		option.text = options[i];
          		element.add( option, null );
          function ruby_call( text )
             query = 'skp;ruby_callback@' + text;
             window.location.href = query;
          function check_ready()
          	if ( document.readyState === "complete" )
          		ready();
          function ready()
             ruby_call( 'loaded' );
          </script>
          </body></html>
          • G
            Garry K
            Jeff - Good catch. You are correct - the message is worded wrong. I have changed it for the next version.
            • G
              Garry K
              Walt - that is wierd - you normally don't see that screen. The web hosting site has been experiencing hack attacks. Please tell me if you see this screen again.
              • G
                Garry K
                Walt - put this rb into your plugins folder and see what you get.
                There will be a menu item under plugins called "Web Dialog Test"
                test file
                  mwm5053
                  Here's my results.
                  I wonder what the deal is about my login on your site?
                  2011 iMac
                  V2 Twilight
                  • G
                    Garry K
                    Walt - I'm sorry but I can't answer that question. I haven't heard anyone else having that problem. It may have something to do with http configurations on your specific machine.
                    Maybe someone else can answer it. Perhaps start a new thread on this. Maybe the developer forum will catch some attention.
                    As you can see - the code isn't doing a whole lot.
                      mwm5053
                      @ Garry you're right I installed 1.0.8 rbz on Mac Book Pro and works great with no hitches. Mac Pro (desktop) running SU 8 and Lion and Mac Book Pro (laptop) running SU 8 and Mavericks. 😉
                      2011 iMac
                      V2 Twilight
                      • G
                        Garry K
                        I now have language translation working. There is a folder called translations and currently there are 4 files in it.
                        en.lang - English
                        fr.lang - French
                        ru.lang - Russian
                        zh.lang - Chineses ( traditional )
                        Near the top of the defaults.txt file there is a language= section where you can enter the 2 character language code. If you leave the language= blank the system will try to figure out the locale code.
                        These language files are straight translations and as a result there might be some funny and or inappropriate translations.
                        Anyone interested in helping out with any language translation can get a hold of me.
                        French Stair Maker
                        Russian Stair Maker
                        Chinese Stair Maker
                        • G
                          Garry K
                          A user with a windows 8 machine running SU 2013 has reported an error that I can't duplicate ( I don't have a windows 8 machine )
                          puts "starting: dialog.execute_script( js_command )"
                          this code doesn't run
                          puts "finished: dialog.execute_script( js_command )"
                          it errors out with this
                          type: mismatch
                          code: 0
                          url: file:///C:/Users/Admin/AppData/Local/Temp/skp8C34.tmp
                          Is there anyone else with a Windows 8 machine running 2013 who would be willing to try this code.
                          ` require 'sketchup.rb'
                          show_dialog
                          def show_dialog()
                          dlg = UI::WebDialog.new( "Stair Measurements", false, "DialogTest", 200, 150, 150, 150, true );
                          dlg.add_action_callback( "ruby_callback" ) { |dialog, params|
                          text = params.to_s
                          	if( text == 'loaded' )
                          		args =  'inside_stringer=Housed|Sawtooth|None' +
                          				'&inside_stringer=1' +
                          				'&inside_option=Has Heel|Has Foot|Both|None' +
                          				'&inside_option=3' +
                          				'&inside_thickness=60' +
                          				'&inside_width=300' +
                          				'&inside_rail=Guard Rail|Wall Rail|None' +
                          				'&inside_rail=2' +
                          				'&outside_stringer=Housed|Sawtooth|None' +
                          				'&outside_stringer=0' +
                          				'&outside_option=Has Heel|Has Foot|Both|None' +
                          				'&outside_option=3' +
                          				'&outside_thickness=60' +
                          				'&outside_width=400' +
                          				'&outside_rail=Guard Rail|Wall Rail|None' +
                          				'&outside_rail=2' +
                          				'&total_rise=2667' +
                          				'&risers=15' +
                          				'&riser_thickness=12.7' +
                          				'&direction=Clockwise|Anti Clockwise' +
                          				'&direction=1' +
                          				'&stair_width=1000' +
                          				'&radius=2400' +
                          				'&degrees=90' +
                          				'&floor_thickness=60' +
                          				'&rail_style=Classic|Modern|Round|Square|Standard|Traditional' +
                          				'&rail_style=4' +
                          				'&tread_thickness=38' +
                          				'&average_run=254' +
                          				'&tread_bullnose=12.7' +
                          				'&nosing=25.4' +
                          				'&flare_amount=0' +
                          				'&progressive_flare=20' +
                          				'&flare_count=0'
                          		js_command = "from_ruby( '" + args + "' )"
                          		puts( js_command )
                          	else
                          		UI.messagebox( text )
                          		puts( text )
                          dialog.close();
                            html = <<-HTML
                          <!DOCTYPE html>
                          <html>
                          body { background-color: #F9EBD1}
                          fieldset { float: left; background-color: #F9EBD1; border-color: black; margin: 3px;}
                          fieldset p {display: table-row;
                          font-family: Arial, Helvetica, sans-serif;
                          font-size: 90%;
                          color: black;
                          height: 27px}
                          fieldset input,
                          fieldset select,
                          fieldset label {display: table-cell; margin: 2px; width: 120px }
                          fieldset label {text-align: right;}
                          fieldset input,
                          fieldset select {margin-left: 10px; background-color: wheat;}
                          </style>
                          <head>
                          <script>
                          function do_click()
                          var text = "";
                          value = items[i].value;
                          else
                          value = "";
                          		 text += "&";
                          ruby_call( text );
                          var element;
                          var pair;
                          		else
                          		element.value = pair[1];
                          var option;
                          element.innerHTML = "";
                          query = 'skp:ruby_callback@' + text;
                          function on_load()
                          </script>
                          </head>
                          <body onload="on_load()">
                          <form>
                          <fieldset>
                          <p><label>Inside Stringer:</label><select id="inside_stringer"></select></p>
                          <p><label>Options:</label><select id="inside_option"></select></p>
                          <p><label>Thickness:</label><input type="text" id="inside_thickness"</p>
                          <p><label>Width:</label><input type="text" id="inside_width"</p>
                          <p><label>Rail Options:</label><select id="inside_rail"></select></p>
                          </fieldset>
                          <fieldset>
                          <p><label>Outside Stringer:</label><select id="outside_stringer"></select></p>
                          <p><label>Options:</label><select id="outside_option"></select></p>
                          <p><label>Thickness:</label><input type="text" id="outside_thickness"</p>
                          <p><label>Width:</label><input type="text" id="outside_width"</p>
                          <p><label>Rail Options:</label><select id="outside_rail"></select></p>
                          </fieldset>
                          <fieldset>
                          <p><label>Stair Direction:</label><select id="direction"></select></p>
                          <p><label>Stair Width:</label><input type="text" id="stair_width"</p>
                          <p><label>Radius:</label><input type="text" id="radius"</p>
                          <p><label>Degrees:</label><input type="text" id="degrees"</p>
                          <p><label>Rail Style:</label><select id="rail_style"></select></p>
                          <p><label>Open Risers:</label><input type="checkbox" id="open_riser"</p>
                          <p><label>Total Rise:</label><input type="text" id="total_rise"</p>
                          <p><label>Risers:</label><input type="text" id="risers"</p>
                          <p><label>Riser Thickness:</label><input type="text" id="riser_thickness"</p>
                          </fieldset>
                          <fieldset>
                          <p><label>Tread Thickness:</label><input type="text" id="tread_thickness"</p>
                          <p><label>Average Run:</label><input type="text" id="average_run"</p>
                          <p><label>Tread Bullnose:</label><input type="text" id="tread_bullnose"</p>
                          <p><label>Nosing:</label><input type="text" id="nosing"</p>
                          <p><label>Flare Amount:</label><input type="text" id="flare_amount"</p>
                          <p><label>Progressive Flare:</label><input type="text" id="progressive_flare"</p>
                          <p><label>Flare Count:</label><input type="text" id="flare_count"</p>
                          <p><label>Floor Thickness:</label><input type="text" id= "floor_thickness"</p>
                          <p><label>Create Stair:</label><input type="button" onclick="do_click()" style="background: silver" value="Ok"></p>
                          </fieldset>
                          </form>
                          </body>
                          </html>
                            HTML
                            dlg.set_html html
                            dlg.show
                          if ( not file_loaded?( "dialog_test.rb" ) )
                          UI.menu( "Plugins" ).add_item( "Web Dialog Test" ) { show_dialog() }
                          file_loaded( "dialog_test.rb" )
                          • G
                            Garry K
                            Version 1.0.11 06-Mar-2014
                            1. Now SU 2014 compatible
                            2. Added missing line to gkware_stairmaker_loader.rb. Utils.rbs was only loading if door maker was installed.
                            3. Added Config folder to hold user configuration and temp files
                            4. Make button images for add Handrail profile and glue edges
                            5. Fixed bug in handrail scaling
                            6. Auto Sizing of Web Dialog. For some reason – need to add room for scroll – even if it shouldn’t be needed
                            7. Fixed bug where trial string keeps growing
                            8. Handrail was not going into “Handrail” layer. Fixed
                            9. Changed Stringer “Width” to “Depth” in web dialog, language files and in defaults.txt
                            10. Made changes to defaults.txt for “imperial_stair_width”
                              aconk25
                              error in windows 8 64bit
                                mwm5053
                                You might want to add .rbz to post or transfer this to plugins forum it's hard to find the file embedded in the middle of topic I can't find maybe I missed it somewhere.
                                2011 iMac
                                V2 Twilight
                                • G
                                  Garry K
                                  I've been busy learning about JQuery, Ajax, JSONP etc.
                                  Here are 2 ruby scripts that I would like someone to try on OSX Lion, OSX Maverick and Windows 8.
                                  The first script is called 'dialog_test_tabs.rb' and is set up with tabs. The tabs code came from user NewOne
                                  http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=22662
                                  This works nicely on my machine which is a Windows 7 machine. I have Internet Explorer 11 installed.
                                  The second script is call dialog_test_5.rb and connects to a test web service on my web site. It just passes a very simple JSONP record {"firstname":"Jeff"} and is suppose to respond with 'Your name is Jeff Hansen'
                                  Tabbed test dialog
                                  Web service test script
                                  • P
                                    pisosse
                                    Well i'm on SU2014 and yosemite
                                    First of all I still get the "HTTP error"
                                    That is very well the reason I get these outputs of your test files.
                                    Dialog 5 output
                                    Dialog tab output
                                    • P
                                      pisosse
                                      Installed via the sketchucation plugin and all is good.. Just wonder what to do if stringers have different curvatures ?
                                      • G
                                        Garry K
                                        Do you have an example of what you mean by different curvatures?
                                        My understanding so far is this.
                                        Curved stringers do have different curvatures (radius), but they both have the same pivot point. The best I can do right now for irregular stairs is the 2D to 3D portion of the stair maker suite.
                                        • P
                                          pisosse
                                          Ahh.. ok thanks. Would I mean is that the stringers is curved but not in parallel. On stringer has a sharper curve than the other. Btw. the 2D to 3D feature sounds promising but the documentation in the help file is leaving me a little puzzled. Should I make 2 stringers as pollens and the select them an push the 2Do3D button or do I have to make a face? sorry this is totally obvious to other than stupid old me. Other than that it is a pretty solid piece of coding sir!
                                          • G
                                            Garry K
                                            I have a few videos on the 2D to 3D stairs.
                                            • 8 / 9
