    Curved Staircases
    171 Posts 19 Posters 61.0k Views 19 Watching
    • G
      Garry K
      Walt - all I can think of doing is pulling out the http code and putting it into a very simple rb script ( not scrambled ).
      What user ID are you using? If it isn't the default "User" "test" then I will see what my logs show at the web site. We'll see if we made it that far.
      • G
        Garry K
        John - I looked at my PM messages - I have only received 1 since I put up version 1.0.7 08 Feb 2014, 08:39( which had the feet fix ).
        Your last message had to do with the beta version 2014.
          mwm5053
          @ Garry username is mwm5053. I have been able to Login to website with no problems still getting 101 error after clicking ok web dialogue pops up but clicking ok for default values nothing happens heres a screenshot.
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
          • G
            Garry K
            Walt - If you look at the title of the web dialog it is saying "http error 0". Sorry about the confusion. I thought that it would be good to show the web dialog whether you have an error or not? I could change the back ground color from wheat to red or something like that.
            The other thing to note is that you may need more accuracy than 1/2" precision to properly draw a stair case. I'm not exactly sure how sketchup handles smaller values than precision.
            If you let the defaults.txt file to "User" and "test" and connected then you should see "Testing - temporary status granted"
            If you edited defaults.txt file to "mwm5053" and put in the emailed password then you should see "You have 30 days left in trial"
              mwm5053
              I changed defaults txt back to user / test and precision to 1/64 still get screenshot error
              2011 iMac
              V2 Twilight
              • G
                Garry K
                Walt - I went to my web site and took a look. There isn't a single http attempt for user "mwm5053".
                I also looked at all of my registered users and there isn't a user "mwm5053" in that file.
                You need to go to my web site - CabMaker32.com and click logon and register. You will then receive an email with your password. You can also send me a private message with your email address. I can also look in my user file and see if that email address has been registered under perhaps a different user.
                  mwm5053
                  Now thats really weird
                  2011 iMac
                  V2 Twilight
                  • jeff hammondJ
                    @garry k said:
                    Jeff - both the top and bottom of the tread get bullnosed. So you can't bullnose the top with a 1" radius and the bottom with a 1" radius.
                    In this case the maximum bullnose for a 1.5" tread is 0.75".
                    that's what i thought.. you may want to consider changing the wording of the error message then:
                    'Tread bullnose must be at least 1/2 of tread thickness'
                    to something along the lines of:
                    max bullnose is 1/2 tread thickness.
                      driven
                      @Garry
                      it's working in 'feet' Template now...
                      the cache reset took a couple of goes...
                      added some info so you can see what I get my end...
                      Ruby version is _____________ 1.8.5 Sketchup version is __________ 13.0.4811 Sketchup version path is __________ /Applications/SketchUp 2013/SketchUp.app Sketchup process pid is __________ 86823 @modPath is __________ unsaved stair time 0.922734 stair time 0.922350
                      <html><head>
                      <meta http-equiv="MSThemeCompatible" content="Yes">
                      <style type="text/css">
                        * { padding; 0; margin; 0; }
                        body { background-color; #F9EBD1}
                        fieldset { float; left; background-color; #F9EBD1; border-color; black; margin; 3px;}
                        fieldset p {display; table-row;
                      			  font-family; Arial, Helvetica, sans-serif;
                      			  font-size; 90%; color; black; height; 27px;}
                        fieldset input,
                        fieldset select,
                        fieldset label {display; table-cell; margin; 2px; width; 120px;}
                        fieldset label {text-align; right;}
                        fieldset input,
                        fieldset select {margin-left; 10px; background-color; wheat;}
                      </style>
                      </head>
                      <body>
                      <form>
                          <fieldset>
                              <p><label>Inside Stringer;</label><select id="inside_stringer"><option>Housed</option><option>Sawtooth</option><option>None</option></select></p>
                              <p><label>Options;</label><select id="inside_option"><option>Has Heel</option><option>Has Foot</option><option>Both</option><option>None</option></select></p>
                              <p><label>Thickness;</label><input type="text" id="inside_thickness"></p>
                              <p><label>Width;</label><input type="text" id="inside_width"></p>
                              <p><label>Rail Options;</label><select id="inside_rail"><option>Guard Rail</option><option>Wall Rail</option><option>None</option></select></p>
                          </fieldset>
                          <fieldset>
                              <p><label title="Set to none for a spiral where spindles are used to tie the treads togethers">Outside
                                  Stringer;</label><select id="outside_stringer"><option>Housed</option><option>Sawtooth</option><option>None</option></select></p>
                              <p><label>Options;</label><select id="outside_option"><option>Has Heel</option><option>Has Foot</option><option>Both</option><option>None</option></select></p>
                              <p><label>Thickness;</label><input type="text" id="outside_thickness"></p>
                              <p><label>Width;</label><input type="text" id="outside_width"></p>
                              <p><label>Rail Options;</label><select id="outside_rail"><option>Guard Rail</option><option>Wall Rail</option><option>None</option></select></p>
                          </fieldset>
                          <fieldset>
                              <p><label>Stair Direction;</label><select id="direction"><option>Clockwise</option><option>Anti Clockwise</option></select></p>
                              <p><label>Stair Width;</label><input type="text" id="stair_width"></p>
                              <p><label title="Set to 0 and StairMaker will calculate based on degrees and Average Run">Radius;</label><input type="text" id="radius"></p>
                              <p><label title="Set to 0 and StairMaker will calculate based on radius and Average Run">Degrees;</label><input type="text" id="degrees"></p>
                              <p><label>Rail Style;</label><select id="rail_style"><option>Classic</option><option>Modern</option><option>Round</option><option>Square</option><option>Standard</option><option>Traditional</option></select></p>
                              <p><label>Open Risers;</label><input type="checkbox" id="open_riser"></p>
                              <p><label>Total Rise;</label><input type="text" id="total_rise"></p>
                              <p><label>Risers;</label><input type="text" id="risers"></p>
                              <p><label>Riser Thickness;</label><input type="text" id="riser_thickness"></p>
                          </fieldset>
                          <fieldset>
                              <p><label>Tread Thickness;</label><input type="text" id="tread_thickness"></p>
                              <p><label title="Average Run is ignored if both Radius and Degrees are set">Average Run;</label><input type="text" id="average_run"></p>
                              <p><label>Tread Bullnose;</label><input type="text" id="tread_bullnose"></p>
                              <p><label>Nosing;</label><input type="text" id="nosing"></p>
                              <p><label>Flare Amount;</label><input type="text" id="flare_amount"></p>
                      		<p><label>Progressive Flare;</label><input type="text" id="progressive_flare"></p>
                              <p><label>Flare Count;</label><input type="text" id="flare_count"></p>
                              <p><label>Floor Thickness;</label><input type="text" id="floor_thickness"></p>
                              <p><label>Create Stair;</label><input type="button" onclick="do_click()" style="background; silver" value="OK"></p>
                          </fieldset>
                      </form>
                      <script type="text/javascript">
                      if ( document.addEventListener )
                      	document.addEventListener( "DOMContentLoaded", ready, false );
                      else if ( document.attachEvent )
                      	document.attachEvent( "onreadystatechange", check_ready );
                      function do_click()
                         var items  = document.getElementsByTagName( '*' );
                         var count  = items.length;
                         var text   = "";
                         for ( var i = 0; i < count; i++ )
                      	  if ( items[i].type == "select-one" )
                      		 value = items[i].options[items[i].selectedIndex].value;
                      	  else if ( items[i].type == "text" )
                      		 value = items[i].value.replace(/'/g, '`');
                      	  else if ( items[i].type == "checkbox" )
                      		 value = items[i].checked.toString();
                      	  else
                      		 value = "";
                      	  if ( value.length > 0 )
                      		  if ( text.length > 0 )
                      			 text += "&";
                      		  text += ( items[i].id + "=" + value );
                         ruby_call( text );
                      function from_ruby( data )
                      	var element;
                      	var pair;
                      	var pairs = data.split( '&' );
                      	var count = pairs.length;
                      		pair = pairs[i].split( '=' );
                      		element = document.getElementById( pair[0] );
                      		if ( element.type == "select-one" )
                      			if ( pair[1].indexOf('|') == -1 )
                      				element.selectedIndex = pair[1];
                      			else
                      				populate_drop_down( element, pair[1] );
                      		else if ( element.type == "text" )
                      			element.value = pair[1].replace(/`/g, "'");
                      		else if ( element.type == "checkbox" )
                      			element.checked = pair[1] == '1';
                      function populate_drop_down( element, data )
                      	var options = data.split( '|' );
                      	var count   = options.length;
                      	var option;
                      	element.innerText = "";
                      		option = document.createElement( "option" );
                      		option.text = options[i];
                      		element.add( option, null );
                      function ruby_call( text )
                         query = 'skp;ruby_callback@' + text;
                         window.location.href = query;
                      function check_ready()
                      	if ( document.readyState === "complete" )
                      		ready();
                      function ready()
                         ruby_call( 'loaded' );
                      </script>
                      </body></html>
                      • G
                        Garry K
                        Jeff - Good catch. You are correct - the message is worded wrong. I have changed it for the next version.
                        • G
                          Garry K
                          Walt - that is wierd - you normally don't see that screen. The web hosting site has been experiencing hack attacks. Please tell me if you see this screen again.
                          • G
                            Garry K
                            Walt - put this rb into your plugins folder and see what you get.
                            There will be a menu item under plugins called "Web Dialog Test"
                            test file
                              mwm5053
                              Here's my results.
                              I wonder what the deal is about my login on your site?
                              2011 iMac
                              V2 Twilight
                              • G
                                Garry K
                                Walt - I'm sorry but I can't answer that question. I haven't heard anyone else having that problem. It may have something to do with http configurations on your specific machine.
                                Maybe someone else can answer it. Perhaps start a new thread on this. Maybe the developer forum will catch some attention.
                                As you can see - the code isn't doing a whole lot.
                                  mwm5053
                                  @ Garry you're right I installed 1.0.8 rbz on Mac Book Pro and works great with no hitches. Mac Pro (desktop) running SU 8 and Lion and Mac Book Pro (laptop) running SU 8 and Mavericks. 😉
                                  2011 iMac
                                  V2 Twilight
                                  • G
                                    Garry K
                                    I now have language translation working. There is a folder called translations and currently there are 4 files in it.
                                    en.lang - English
                                    fr.lang - French
                                    ru.lang - Russian
                                    zh.lang - Chineses ( traditional )
                                    Near the top of the defaults.txt file there is a language= section where you can enter the 2 character language code. If you leave the language= blank the system will try to figure out the locale code.
                                    These language files are straight translations and as a result there might be some funny and or inappropriate translations.
                                    Anyone interested in helping out with any language translation can get a hold of me.
                                    French Stair Maker
                                    Russian Stair Maker
                                    Chinese Stair Maker
                                    • G
                                      Garry K
                                      A user with a windows 8 machine running SU 2013 has reported an error that I can't duplicate ( I don't have a windows 8 machine )
                                      puts "starting: dialog.execute_script( js_command )"
                                      this code doesn't run
                                      puts "finished: dialog.execute_script( js_command )"
                                      it errors out with this
                                      type: mismatch
                                      code: 0
                                      url: file:///C:/Users/Admin/AppData/Local/Temp/skp8C34.tmp
                                      Is there anyone else with a Windows 8 machine running 2013 who would be willing to try this code.
                                      ` require 'sketchup.rb'
                                      show_dialog
                                      def show_dialog()
                                      dlg = UI::WebDialog.new( "Stair Measurements", false, "DialogTest", 200, 150, 150, 150, true );
                                      dlg.add_action_callback( "ruby_callback" ) { |dialog, params|
                                      text = params.to_s
                                      	if( text == 'loaded' )
                                      		args =  'inside_stringer=Housed|Sawtooth|None' +
                                      				'&inside_stringer=1' +
                                      				'&inside_option=Has Heel|Has Foot|Both|None' +
                                      				'&inside_option=3' +
                                      				'&inside_thickness=60' +
                                      				'&inside_width=300' +
                                      				'&inside_rail=Guard Rail|Wall Rail|None' +
                                      				'&inside_rail=2' +
                                      				'&outside_stringer=Housed|Sawtooth|None' +
                                      				'&outside_stringer=0' +
                                      				'&outside_option=Has Heel|Has Foot|Both|None' +
                                      				'&outside_option=3' +
                                      				'&outside_thickness=60' +
                                      				'&outside_width=400' +
                                      				'&outside_rail=Guard Rail|Wall Rail|None' +
                                      				'&outside_rail=2' +
                                      				'&total_rise=2667' +
                                      				'&risers=15' +
                                      				'&riser_thickness=12.7' +
                                      				'&direction=Clockwise|Anti Clockwise' +
                                      				'&direction=1' +
                                      				'&stair_width=1000' +
                                      				'&radius=2400' +
                                      				'&degrees=90' +
                                      				'&floor_thickness=60' +
                                      				'&rail_style=Classic|Modern|Round|Square|Standard|Traditional' +
                                      				'&rail_style=4' +
                                      				'&tread_thickness=38' +
                                      				'&average_run=254' +
                                      				'&tread_bullnose=12.7' +
                                      				'&nosing=25.4' +
                                      				'&flare_amount=0' +
                                      				'&progressive_flare=20' +
                                      				'&flare_count=0'
                                      		js_command = "from_ruby( '" + args + "' )"
                                      		puts( js_command )
                                      	else
                                      		UI.messagebox( text )
                                      		puts( text )
                                      dialog.close();
                                        html = <<-HTML
                                      <!DOCTYPE html>
                                      <html>
                                      body { background-color: #F9EBD1}
                                      fieldset { float: left; background-color: #F9EBD1; border-color: black; margin: 3px;}
                                      fieldset p {display: table-row;
                                      font-family: Arial, Helvetica, sans-serif;
                                      font-size: 90%;
                                      color: black;
                                      height: 27px}
                                      fieldset input,
                                      fieldset select,
                                      fieldset label {display: table-cell; margin: 2px; width: 120px }
                                      fieldset label {text-align: right;}
                                      fieldset input,
                                      fieldset select {margin-left: 10px; background-color: wheat;}
                                      </style>
                                      <head>
                                      <script>
                                      function do_click()
                                      var text = "";
                                      value = items[i].value;
                                      else
                                      value = "";
                                      		 text += "&";
                                      ruby_call( text );
                                      var element;
                                      var pair;
                                      		else
                                      		element.value = pair[1];
                                      var option;
                                      element.innerHTML = "";
                                      query = 'skp:ruby_callback@' + text;
                                      function on_load()
                                      </script>
                                      </head>
                                      <body onload="on_load()">
                                      <form>
                                      <fieldset>
                                      <p><label>Inside Stringer:</label><select id="inside_stringer"></select></p>
                                      <p><label>Options:</label><select id="inside_option"></select></p>
                                      <p><label>Thickness:</label><input type="text" id="inside_thickness"</p>
                                      <p><label>Width:</label><input type="text" id="inside_width"</p>
                                      <p><label>Rail Options:</label><select id="inside_rail"></select></p>
                                      </fieldset>
                                      <fieldset>
                                      <p><label>Outside Stringer:</label><select id="outside_stringer"></select></p>
                                      <p><label>Options:</label><select id="outside_option"></select></p>
                                      <p><label>Thickness:</label><input type="text" id="outside_thickness"</p>
                                      <p><label>Width:</label><input type="text" id="outside_width"</p>
                                      <p><label>Rail Options:</label><select id="outside_rail"></select></p>
                                      </fieldset>
                                      <fieldset>
                                      <p><label>Stair Direction:</label><select id="direction"></select></p>
                                      <p><label>Stair Width:</label><input type="text" id="stair_width"</p>
                                      <p><label>Radius:</label><input type="text" id="radius"</p>
                                      <p><label>Degrees:</label><input type="text" id="degrees"</p>
                                      <p><label>Rail Style:</label><select id="rail_style"></select></p>
                                      <p><label>Open Risers:</label><input type="checkbox" id="open_riser"</p>
                                      <p><label>Total Rise:</label><input type="text" id="total_rise"</p>
                                      <p><label>Risers:</label><input type="text" id="risers"</p>
                                      <p><label>Riser Thickness:</label><input type="text" id="riser_thickness"</p>
                                      </fieldset>
                                      <fieldset>
                                      <p><label>Tread Thickness:</label><input type="text" id="tread_thickness"</p>
                                      <p><label>Average Run:</label><input type="text" id="average_run"</p>
                                      <p><label>Tread Bullnose:</label><input type="text" id="tread_bullnose"</p>
                                      <p><label>Nosing:</label><input type="text" id="nosing"</p>
                                      <p><label>Flare Amount:</label><input type="text" id="flare_amount"</p>
                                      <p><label>Progressive Flare:</label><input type="text" id="progressive_flare"</p>
                                      <p><label>Flare Count:</label><input type="text" id="flare_count"</p>
                                      <p><label>Floor Thickness:</label><input type="text" id= "floor_thickness"</p>
                                      <p><label>Create Stair:</label><input type="button" onclick="do_click()" style="background: silver" value="Ok"></p>
                                      </fieldset>
                                      </form>
                                      </body>
                                      </html>
                                        HTML
                                        dlg.set_html html
                                        dlg.show
                                      if ( not file_loaded?( "dialog_test.rb" ) )
                                      UI.menu( "Plugins" ).add_item( "Web Dialog Test" ) { show_dialog() }
                                      file_loaded( "dialog_test.rb" )
                                      • G
                                        Garry K
                                        Version 1.0.11 06-Mar-2014
                                        1. Now SU 2014 compatible
                                        2. Added missing line to gkware_stairmaker_loader.rb. Utils.rbs was only loading if door maker was installed.
                                        3. Added Config folder to hold user configuration and temp files
                                        4. Make button images for add Handrail profile and glue edges
                                        5. Fixed bug in handrail scaling
                                        6. Auto Sizing of Web Dialog. For some reason – need to add room for scroll – even if it shouldn’t be needed
                                        7. Fixed bug where trial string keeps growing
                                        8. Handrail was not going into “Handrail” layer. Fixed
                                        9. Changed Stringer “Width” to “Depth” in web dialog, language files and in defaults.txt
                                        10. Made changes to defaults.txt for “imperial_stair_width”
                                          aconk25
                                          error in windows 8 64bit
                                            mwm5053
                                            You might want to add .rbz to post or transfer this to plugins forum it's hard to find the file embedded in the middle of topic I can't find maybe I missed it somewhere.
                                            2011 iMac
                                            V2 Twilight
                                            • 8 / 9
