    How to enhance the smooth edges?
    12 Posts 5 Posters 852 Views 5 Watching
      skibbbi
      Hello,
      Since I always have a problem with it and finally decided to ask for help because I can not cope.
      View pictures first, please.
      How do I make a top view of the visible contour of depressions in the sink?
      I know I can manually select the soft edges and make unsoft. But it is very labor intensive. Is there any way (plugin) which can permanently stressed the boundary edges. A similar effect I get when I turn on View -> Edge styles - Profiles but it's not enough. If you set the top, unfortunately, does not work very well.
      If there is no automatic way to get clear contours, although it might be a plugin to quickly unsoft soften edges?
      I hope that there will be a solution?
      Regards,
      1 Shaded view
      2 Hidden line view
      3 Hidden line view + profile view
      4 Hidden line view + profile view + top view
      • BoxB
        You could start with on the View menu put a tick beside Hidden Geometry.
          skibbbi
          Of course I know the Hidden Geometry function but this is not the case. In Figure 6 I manually unsoft edges to be visible contour of sink.
          About the effect I want. If there is a plugin that will automatically do something like this, it can be a tool that will help me unsoft selected edges.
          5 Hidden line view + profile view + top view + hidden geometry on
          6 Hidden line view + profile view + top view + manualy unsoft edges
            Maybe if you don't soften those edges in the first place?
            • BoxB
              Have you tried adjusting the slider on the soften dialog until you get the edges you want?
                skibbbi
                I tried this but unfortunately such a way also requires a lot of manual processing.
                7 Hidden line view + profile view + top view + soften edges no to strong
                8 Hidden line view + profile view + top view + soften edges a little stronger
                • mitcorbM
                  mitcorb
                  We're not talking about iso-contours here?
                  • BoxB
                    You do know about CRTL Eraser for soften and CRTL Shift Eraser for unsoften I assume.
                      skibbbi
                      I just checked on the internet which means iso-contours. And it really might be it 😄
                      I did not know it was so called. Is it possible to do something like that with my sink?
                        skibbbi
                        Of course I know these functions. Unfortunately this is still a lot of manual work. I thought that someone knows a faster way.
                        • BoxB
                          Sorry, stupid of me not to know that.
                          • jeff hammondJ
                            you can usually fix this pretty quick by turning on hidden geometry, window select the faces you'd like to give visible edges to, copy, exit group (or group original), paste in place, turn off hidden geometry, explode group..
                            (sometimes readjusting the soften smooth setting on the copied face after pasting.. or selecting the face and deleting, etc..).
                            attach the .skp if you can't figure it out.. i'm pretty sure you should be able to do it on this model.
