    [Plugin] Mirror
    211 Posts 72 Posters 390.6k Views 72 Watching
      How did you install it [tell us steps, please] ?
      Next open the Ruby Console open...
      Any error messages when you try to use the Mirror tool ?
      This tool is used many hundreds of times a week without issues, so something somewhere is wrong... πŸ˜•
      I'm wondering if you have another rogue plugin loading that messes with base classes like 'group' and thereby messes up Mirror's legit work...
      If you have SketchyPhysics, older-Podium, some newer-'BIM' tools etc try disabling those, restart and try Mirror... Let us know if you find the culprit... There is a 'quarantine' list...
      • cottyC Offline
        cotty
        http://sketchucation.com/forums/viewtopic.php?f=323&t=47371
        my SketchUp gallery
        • rishikeshavateR Offline
          rishikeshavate
          @ Tig
          Hi Tig.Thanx for ur reply.
          I installed it using sketchucation plugin store from sketchup. I installed without any error. also i can see the plugin in plugin, context menu also i can see tool bar for it.
          I have SketchyBevel and SketchyFDD installed on my PC. Is sketchy plugin messes with Mirror?
          will try after disabling sketchy plugins?
            I don't think either of those mess with other plugins, but you never know... so try disabling them and see if Mirror then works...
            Do you get any error messages in the Ruby Console when using Mirror ??
            Clearly something is wrong because hundreds of users use Mirror hundreds of times every day, and have no issues - so you must have some specific thing causing this...
            I would like to 'get to the bottom of it' πŸ˜’
              Here's a future-proofed update.
              http://sketchucation.com/forums/viewtopic.php?p=276512#p276512
                KrisM
                Tig,
                Thank you for a most useful plugin. Is there a way to change a minor irritation for me? The default choice after mirroring is to erase the original part. Ninety percent of the time, I am copying & vmirroring the part. I just erased my original part for the umpteenth time because I hit Enter too quickly. Not the end of the world but irritating nonetheless. Can I change the code to set the default button to NO.
                Kris
                • Rich O BrienR Online
                  on line 367
                  if UI.messagebox("Erase Original Selection ? ",MB_YESNO,"")==6
                  change the last number, 6, to 7
                  if UI.messagebox("Erase Original Selection ? ",MB_YESNO,"")==7
                  Now when you hit enter it will always be no
                    @krism said:
                    Tig,
                    Thank you for a most useful plugin. Is there a way to change a minor irritation for me? The default choice after mirroring is to erase the original part. Ninety percent of the time, I am copying & mirroring the part. I just erased my original part for the umpteenth time because I hit Enter too quickly. Not the end of the world but irritating nonetheless. Can I change the code to set the default button to NO.
                    Kris
                    Rich's solution reverses the result - but keeps the wording πŸ˜• so answering Yes to the 'Erase Original...' prompt would NOT then erase it - that is plain silly πŸ˜’ see below on how to reword it AND reverse the result sensibly***
                    The standard SketchUp dialog's default 'submit' button is 'Yes', it can't be changed...
                    I'd never hit 'enter', but instead train myself to use the Y and N keys - which chose Y-es and N-o...
                    You could reword the script to ask the opposite question "Keep Original ?" and then swap the results - but it will confuse others who might use your version!
                    The current setup also follows the old AutoCAD's Mirror tool which it sought to mimic, and which effectively asks' do you want to to delete the original' - but if you exit without answering Y/N it might take N ? ...
                    ***Edit the "Mirror.rb" script with a plain-text editor - like Notepad++ - and find line #355 and change
                    @msg = "Mirror: Erase Original Selection ?"
                    to read:
                    @msg = "Mirror: **Keep** Original Selection ?"
                    so that the stausbar prompt is in step...
                    Then go to line #367
                    if UI.messagebox("Erase Original Selection ? ",MB_YESNO,"")==6 ### 6=YES 7=NO
                    edit it to read:
                    if UI.messagebox("**Keep** Original Selection ? ",MB_YESNO,"")==**7** ### 6=YES 7=NO
                    which reverses the question and the result of Pressing 'Yes'...
                    For tidiness's sake also on line #369
                    else ### NO
                    change the rem note 'NO' after the ### to:
                    else ### **YES**
                    πŸ˜’
                      I was gonna tell the hack for completely removing that useless dialog but I thought my elegant answer left you with a wonderfully ironic question...
                        KrisM
                        Tig & Rich,
                        Thanks for your replies. I will implement the "sensible" solution. No one else uses my computer so there is no opportunity for confusion from others. I checked my Autocad default for the mirror tool and it is set to No. I must have changed that sometime in the past as it is always like that for me.
                        Kris
                          KrisM
                          Okay, works great. Thanks again.
                          Kris
                            PJB
                            Great tool, use it every day. Can't wait for the 2014 version.
                              patchso
                              TIG,
                              Thank you very much for posting this extension. Incredibly useful!
                              Best Wishes
                              Patrick.
                                πŸ˜’
                                Why are you waiting? It is already SU2014 compliant and it has been since December. See this.
                                • KrisidiousK Offline
                                  Krisidious
                                  Yes, TIG has been diligently updating all his stuff. Thanks TIG!
                                  By: Kristoff Rand
                                    PJB
                                    @dave r said:
                                    πŸ˜’
                                    I could not find it in extension warehouse, so now i used a copy from SU2013 and put it in the plugin folder from SU2014. It works! thank you 😍
                                      πŸ˜’ NONE of my Plugins are in the EWH !
                                      They are ALL in the SketchUcation PluginStore.
                                      They should all be compliant with v2014.
                                      You should NEVER copy ANY plugins across into v2014 from older installation of SketchUp. unless you cannot get a current version.
                                      Most authors have updated their Plugins to be compatible with v2014, so you need to install the latest version.
                                        Krisidious
                                        You should use the Plugin Store and or the SketchUcation Tools that will search and install plugins for you. Many authors here in the forums are not on the EWH.
                                        By: Kristoff Rand
                                        • jiminy-billy-bobJ Offline
                                          jiminy-billy-bob
                                          Why not?
                                            Krisidious
                                            Cuz he's SCF O-G Baby!
                                            By: Kristoff Rand
                                            • 11
                                            • 6 / 11
