    [Plugin] Component Dropper
    49 Posts 21 Posters 57.5k Views 21 Watching
    • Y
      Yucon
      Hi Tom,
      I am trying to use your plugin and it almost works great but the boxes are jumping away from the original position. Is that a problem for sketchup 2013 maybe?
      See here some screenshots http://puu.sh/6g5M2.jpg and http://puu.sh/6g5Nx.jpg. I tried it on several models.
      Hope you can help me.
      • tt_suT
        tt_su
        Can you share a test model?
        • Y
          Yucon
          Yes ofcourse, here http://www.yucon.nl/projecten/testfile.zip you can download the file. If I want to replace the trees for a simpel box you can see that the boxes will be placed on a different location.
          Daan
          • Y
            Yucon
            Hi Tom,
            Did you download the test file? Do you understand the problem?
            Daan
            • tt_suT
              tt_su
              You tried to replace the trees with what? With component?
              (Btw - your SKP file that you shared wsa 40MB - but when I purged it (Model Info > Statistics > Purge Unused it became only 18MB.)
              Also, what version do you have? I'm not sure if I've published the latest on SketchUcation yet. The latest version is 1.1.0.
                The PluginStore version is v1.0.0 - as it is the title to this thread... 😕
                • tt_suT
                  tt_su
                  Ackh! Then it's one of the about 20 I need to update on SCF... 😞
                  • Y
                    Yucon
                    I am trying to replace the tree for a simple box component. I think the problem will besolved if you upload the latest version.
                    Many tx
                    • tt_suT
                      tt_su
                      The latest is available on Extension Warehouse at the moment. I'm currently too overloaded to update my plugins on SCF. Probably won't happen until February.
                      • Y
                        Yucon
                        Works great now. Thanks for your help and your great plugin of course!
                        • romboutR
                          rombout
                          i there, this is used to work in SU2015 free. I doesnt do anything now, the ruby console is empty (no feedback). Even the simplest scene with SU start file and cube doesnt work
                            I'm not able to reproduce this. When I select a component in SU2015 and pick another component it replaces the selected instances.
                            Do you perhaps have a video capture?
                            • jojo9J
                              jojo9
                              Thomthom, your plugin looks quite useful, so i tried to add a toolbar button because digging in menus isnt my thing.
                              i wanted to ask you some help embedding that button in the right place…with all the loaders of the last time, its confusing to get where to insert other code. (id prefer not, but…its the magic toolbar button… and solely that)
                              anyway, when i try to add a toolbar button code block after the extension code block in tt_replacer, i get:
                              Error Loading File tt_replacer.rb
                              wrong number of arguments (2 for 1)
                              heres the code:
                              #=begin
                                  cmd = UI;;Command.new( PLUGIN_NAME, loader )
                              #    cmd.small_icon =  "Images/icon_16.png"
                                  cmd.tooltip = "Component Replacer"
                                  tb= UI.toolbar "ThomThom"
                                  tb.add_item(cmd)
                              #=end
                              • sdmitchS
                                sdmitch
                                heres the code:
                                #=begin
                                >     tb.add_item(cmd)
                                > #=end
                                I think it should be
                                #=begin
                                    cmd = UI;;Command.new( PLUGIN_NAME ) { loader }
                                    tb.add_item(cmd)
                                #=end
                                http://sdmitch.blogspot.com/
                                • jojo9J
                                  jojo9
                                  oh, yeah! thats true, i forgot the parenthesis, and it was the core file. Thanks sdmitch!
                                  Now i got it working, yay!
                                  • shake1S
                                    shake1
                                    Not working in SU 2020 20.2.172
                                    Pleace chek this.
                                    correction - 2D objects i mean
                                    • G
                                      Grey24601
                                      HI ThomThom
                                      Does Component replacer work with 2021? It appears to have stopped working.
                                      I select the components to replace, invoke the tool and then it prompts me to select the component to replace with but nothing happens.
                                      • B
                                        Bg1137
                                        It also doesn't work for me in 2021. I loved this extension 😞
                                        • 3 / 3
