    Requesting help skewing a 3D object
    53 Posts 11 Posters 5.2k Views 11 Watching
    • gillesG
      gilles
      Gilles said "When you proceed to deleting unwanted geometries, make the part soft and smooth", and Box mentioned welding the segments of the curves together. It got me thinking, because the ultimate aim is to print a real clip on a 3D printer (I'm new to that, too.....).
      Smoothing allow you to to select a continuity of faces with one click (according to the smooth angle) when hidden geometry is off instead of one face.
      if you extrude a face with welded edges instead of exploded edges, smooth will be automatic.
      Now I know that SU draws circles as a series of straight lines, and I wanted the final 3D printed object to be circular not blocky, so I increased the segment count on the half circles to 100. Is this sensible, or just way too much? Gilles mentioned smoothing - does that just improve the visuals aspect of the image in SU, or does it have a real impact on a 3D printed object?
      Smooth just improve the visuals aspect of the image in SU if you want to have a better 3D print render increase segmentation but don't forget 3D printing tolerance, so not that much segments.
      And Box mentioned welding the lines/segments of the curves together (presumably because the model was exploded at some stage in its history). I googled about this, and got rather confused. I understand that welding the lines together creates a polyline (polygonal curve), but I'm not clear how that actually differs from a regular line, and whether the arc/circle tools in SU create a series of regular lines or a polyline. And in the context of 3D printing, is it better that the curves be default SU arc/circles, or polylines?
      this does not matter for 3D print, but make sure you part is a solid, must be a group or component in su to be a solid and a good orientation of the faces
      • ely862meE
        ely862me
        Haha, I was typing like crazy then Submit to just find out two other almost exact answers have been submitted. At least I am glad it was the right answer !
        Natives really type fast,though!!
        Edited Duh moment for me, " Paste in place " - never used it ! I was just thinking, what is Jeff doing by deleting those !!
        Elisei (sketchupper)
        Come and See EliseiDesign
          jant
          Fantastic - all my questions answered (well, until I encounter the next problem). Once again, and with feeling, thank you so much to all of you for taking a lot of time and effort to help me out (and apologies to Pilou and others for not uploading the v6 version of the model earlier).
            @gilles said:
            Natives type rather faster than me.
            I only type with two fingers. Maybe I'll have to start typing with one eye tied behind my back. πŸ˜„
              Mostly because I was curious about the steps in the process I outlined, I made a video of it. I did it at almost the speed I'd work if I was doing it for myself and didn't need to say anything. I could have shortened it up. I think my computer was a bit overloaded when I recorded it because the first right to left selection didn't work correctly.
              Although I use Edit>Paste in place a lot--so much so I have a keyboard shortcut for it--I'd never thought to use it in a case like this. I can see some good uses for it, though.
                Another classic
                • gillesG
                  gilles
                  forget typing with one eye tied behind your back, type in french how many fingers you need then google translate. πŸ’š
                    The only thing I know in French would be Oui, Crepe Suzette and mon dieu! πŸ˜†
                      Thx for the V6: that must be a reflex, a sort of esperento of file export between versions! πŸ‘
                      I will exam the videos tomorrow πŸ€“
                      @Dave : that will be funny to know where you found only these 3 words! πŸ˜„
                      That can be a good resume of the Universe! πŸ’š
                        πŸ˜†
                        • jeff hammondJ
                          nice dave πŸ‘
                          pretty much anything which can show someone to avoid trying to manually delete a hundred or so edges with the eraser tool is the 'right' method πŸ˜‰
                          [EDIT]
                          good one pilou. i used to use that plugin (inverse selection) a lot... until v8 and the Solid Tools. (which is how i'd normally do this)
                            Ok! Very cool videos Jeff and Dave! πŸ‘
                            But sorry for this time in this particular case...
                            I believe that I am more speedy and more simple! πŸ’š
                            You right I use plugin but just one and indispensable in the Toolbox! 😎
                            The genious Inverse Selection by TIG! By Right Click πŸ‘
                            Only curvated face is duplicated not the volume!
                            Edit : I verify this morning because that was just theoric this night! πŸ˜„
                            One of the curvated face must be "inverse white / blue" and the 2 curvated faces must be "Intersect with the model" ! And of course Rectangle Selection must be left to right! πŸ€“
                            Don't forget that in the past I have made "speedy challenge" Sketchup / Moi3D
                            "without plugin" πŸ€“
                            (of course I have losted at each time because Moi is unbeatable! πŸ˜’
                            It's maybe for that I use now plugins! πŸ’š :
                            If you are interested : Moi 22 seconds by PaQ! 😲 SU 40 seconds and playing as Horowitz! πŸ˜„
                            http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=c1961cccf715ed10247d21984cc1bc51&filename=testsk01.jpg
