    Sketchup 2013 Missing Plugin Tab (Extensions don't work)
    21 Posts 6 Posters 9.8k Views 6 Watching
      simon510
      @jeff hammond said:
      @simon510 said:
      Thanks for the reply,
      How come I don't have the option of installing rb files?
      There something in my plugin folder called su.sandbox.rb
      you do have the option.. those are inside the .rbz..
      change the extension name of .rbz to .zip on one of those files then unzip it.. it's just a compressed file contain ruby scripts and sometimes images etc..
      the .rbz files just save you the manual trip to your plugins folder as well as not requiring a sketchup restart as you need to do with manual installs.. (and the plugin i linked to.. the scf manager.. makes the process even easier)
      I got the scf manager to work through your method.
      With the scf manager, I was able to see my other plugins like "sandbox tool" etc.
      However, after I restart Sketchup everything is gone.
      What to do?
      • jeff hammondJ
        @simon510 said:
        What to do?
        hmm.. im not quite sure as i use mac.. but the sandbox tools were always there.. they came with sketchup and are in the Tools menu.. you can turn the extension on/off (i.e.- whether or not it loads when you launch sketchup) via the extensions preferences you've already found..
        but to get better answers, it will be helpful if you provide more info.
        "However, after I restart Sketchup everything is gone."
        gone from where, exactly? gone from the plugins folder? from the tools menu? no more toolbar? etc.
        what have you turned on and how did you turn it on etc..
        lots of ways to interpret your problems especially when you might not realize you could be using terminology which means one thing in sketchup while you're saying another..
        that said, bear with it through tomorrow.. someone here will get you past the AHA moment in which all of this stuff becomes much more simple ๐Ÿ˜„
        (fwiw, the .rbz files & the 'install extension' function are meant to be a way to keep things more simple.. but if you want to learn about the plugin paths/folders/.rb files etc then you can do that and you do have the ability to manually do all the installs.. it's just going to lead to a bit more confusion at first)
          simon510
          Sorry about that I should of worded it better.
          The "Sandbox" plugin was never there in my Sketchup until I got the scf manager downloaded and working.
          With scf manager, "sandbox" magically appeared in my tools menu.
          I closed the scf manager toolbar and after a restart of Sketchup, I can't seem to find the scf manager toolbar and sandbox under the tools menu.
          Also in my preferences> extensions is completely blank as you can see in the first image I provided in the first post
          Hope that makes sense.
          • jeff hammondJ
            oh.. right.. i missed that little detail ๐Ÿ˜‰
            yeah, something is wrong.. the europeans will be awake soon drinking their tea.. they'll probably be able to sort it out.
            • Wo3DanW
              Wo3Dan
              @jeff hammond said:
              ....yeah, something is wrong.. the europeans will be awake soon drinking their tea.. they'll probably be able to sort it out.
              Jeff, how did you know about the tea drinking?
              @simon510 said:
              .... I closed the scf manager toolbar and after a restart of Sketchup, I can't seem to find the scf manager toolbar and sandbox under the tools menu.
              Simon, can't you find 'Sandbox' toolbar in menu View > Toolbars > check 'Sandbox'?
              For all I know you don't have to download any sandbox plugin. It's there right from when you install SketchUp.
                Read this... ๐Ÿ˜’
                Fix the plugins folder's permissions and the exe...
                Reinstall your plugins...
                Restart...
                Report back...
                404 Not Found
                (sketchucation.com)
                  simon510
                  ^ Hi Gerrit,
                  Sorry but its not there, which is the problem.
                    simon510
                    ^ That seem to be the problem.
                    Thanks.
                      Thanks.
                      B U T... is it now fixed ? ๐Ÿ˜•
                      • jeff hammondJ
                        just a wild guess ๐Ÿ˜‰
                        • BoxB
                          NSA at it again!
                          • jeff hammondJ
                            @box said:
                            NSA at it again!
                            haha.
                            more like-- one of the very first u.s history lessons kids are taught about over here is the boston tea party.. 8 year olds that have no clue as to what really happened other than a bunch of crazy brits killing their greatgreatgreat grandparents over tea..
                            • Wo3DanW
                              Wo3Dan
                              @jeff hammond said:
                              @box said:
                              NSA at it again!
                              haha
                              Not So Amused.... ๐Ÿ˜ž ๐Ÿ˜ฒ not ๐Ÿ˜ฎ
                              ๐Ÿ’š
                                simon510
                                @tig said:
                                Thanks.
                                Oh sorry, yes it is.
                                However I can't seem to get my twilight demo download to work, but I guess that's another topic.
