    1.5k Posts 471 Posters 3.4m Views 470 Watching
    • jeff hammondJ Offline
      @dave r said:
      I tried on a simple box with the 150mm offset and 50 sides and it worked fine. I'm guessing there was something strange with your geometry such as an internal face maybe.
      i think they aren't sharp corners prior to using roundCorner and he's using too big of a radius for the softened corners.. so there's guess #3 😉
        Subtle. I couldn't see those lines on my Mac but now that I'm home from work I can see them.
          really? mac at work - windows at home?
          that's opposite of the norm for people using both systems.
          (re: the topic- it's hard to tell if those are just some sort of layout lines down below or if they're also on the object which has been roundCorner_ed.. hence the request for the file)
            I use my MacBook Pro at work more than at home. I mostly use my PC at home but both have SU Pro so I can go back and forth between them.
            [/quote][/quote]
            Agreed.
            • N Offline
              nwarner33
              Thanks for the quick responses!
              I had it scaled up largely. I figured it must have been that the radiuses were too large for the size, however it didnt appear to be. The typography needs to be exactly as is. Ive attached the file to see if anyone can have another crack at it. Thanks again.
              logo 3d.skp
              • mitcorbM Offline
                mitcorb
                Hi.
                If you need this in a hurry, I suggest the following:
                Select the flat face of the 5, copy to the side. Harden the edges. Delete the flat face, leaving the outline of the 5. Create your 150mm arc with 4 segments, or some other number. Make a quarter round face/profile. Set it in position. Select the profile as a path. Use the FollowMe tool.
                In spite of all the vagaries of the figure, I got a clean result.
                • gillesG Offline
                  gilles
                  Give as at least a V8 .skp please, not everybody run 2013.
                  • mitcorbM Offline
                    mitcorb
                    Actually, it is possible to take your result with the corner wings, make a selection only of the intersecting faces, right click intersect selection, erase the concealing faces, draw lines where intersection didn't complete, then erase the wings. This is more tedious, obviously, and you will need to do it for each of those sharp corners. Also, when I performed the rounding, the offset preview showed overlapping of the offset at the corners. The offset that got a clean preview profile was a mere 30mm. Not really what you wanted.
                    Also, when I downloaded your skp I noticed that the bottom of the figure was a closed face. You need to delete the face or you get rounding of the bottom and the wings.
                    None of my business, but what are those diamonds and trapezoids about on the underside of the 5?
                      michelleyeo
                      Dear Fredo,
                      I have followed your instructions to place the plugin into Sketchup plugin folder. (mac version sketchup2013)
                      However, in the window i do find the libFredo6 setting but no tool bar or anything else to be found in my sketch up.
                      Please help
                      Michelle
                        michelleyeo
                        please see attached file
                        I m not sure if I have installed it properly or not as the is no tool bar or any sign of rounder corner but libFredo6 setting.
                        Please help.
                        • OxerO Offline
                          Oxer
                          If you have installed correctly the plugin in User/Library/Applications Support/Sketchup 2013/Sketchup/ Plugins, go to View Menu/Toolbars/..... and mark the Round Corner to see its toolbar.
                          • TIGT Online
                            Also ensure that it is enabled [checked] under Preferences > Extensions...
                            Otherwise its Toolbar isn't available...
                              michelleyeo
                              Dear TIG and Oxer,
                              Many thanks for your reply.
                              I've installed correctly and enabled the extensions however no sign for Roundcorner.
                              Please helpppp
                              • BoxB Offline
                                Are you saying that if you put your mouse on the words "Tool Palettes" you don't get round corner in the list that pops up? or haven't you found that list of toolbars yet.
                                  michelleyeo
                                  Yes, I don't get the round corner in the list
                                    @michelleyeo said:
                                    Dear TIG and Oxer,
                                    Please helpppp
                                    according to your second picture, you haven't installed it correctly.. you're missing libFredo files.
                                    you can get that here:
                                    http://sketchucation.com/forums/viewtopic.php?t=17947
                                    (download the .rbz version underneath the word DOWNLOAD in the first post)
                                    to install it, go Sketchup (menu)-> Preferences-> Extensions..
                                    click the 'Install Extensions' button at the bottom then navigate to the libFredo .rbz file... it will be placed in the proper location for you..
                                    • W Offline
                                      wisar
                                      Great tool but I am wondering if I can undo the rounded corners if I want to revisit a design and make some changes like pushing and pulling a face?
                                      Cheers,
                                      W
                                      • mitcorbM Offline
                                        mitcorb
                                        Hi:
                                        You can undo the rounded corners while in the same session, but you cannot undo the round corners tomorrow.
                                        If you were using Blender you could simply switch it off, because rounded corners would be a modifier "channel"(?).
                                        In Sketchup, do the rounding on a separate copy, group or unique component of the original geometry.
                                        You could then save these copies out of your working file if you wish.
                                          Lyubov
                                          Please, help me to delete plugin from SketchUp Pro 2013, after Setting plugin Fredo6_Round Corner i decieded to delete him from foulder plugins, but now after openning SketchUp I have every time notice about that I have to install this plugin...(YOU MUST INSTALL LIBFREDO6 VERSION 5.2 OR HIGHER TO RUN FREDO ROUND CORNER)... Thank you so much for helping!! 😒
                                          • mitcorbM Offline
                                            mitcorb
                                            Hi, Lyubov:
                                            Your question generates many questions.
                                            Please visit this thread and see if an answer is there:
                                            http://sketchucation.com/plugin/696-SketchUcationTools
                                            Fredo6's RoundCorner is a very reliable plugin and requires a helper file called Libfredo. In fact, most if not all of his tools utilize the helper file.
                                            See if the above helps and post back if you need further assistance.
                                            Someone is sure to respond.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 73
                                            • 74
                                            • 13 / 74
