    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • N
      nwarner33
      Can anybody help me out rather urgently?? I have attached screen shots of the settings that I have used and the results I have gotten, as well as what I am trying to achieve. How do I get rid of those little wing pieces on the top that shouldn't be there??
      Is this the best tool to use for the job or can someone recommend a better one? I have tried the soap skin tool which works for the top and bottom banners, however its very uneven on the 5.
      Any advice would be super welcome. Thanks.
      • jeff hammondJ
        it's hard to tell what the problem is without seeing the base geometry.. copy that 5 into it's own file then attach the .skp to your post.. you'll get an exact answer that way instead of a bunch of guesses.
          We need the SKP... but my guess is it is too small !
          Scale x 10 [or x100] and retry, scale back down on success... 😕
            I tried on a simple box with the 150mm offset and 50 sides and it worked fine. I'm guessing there was something strange with your geometry such as an internal face maybe.
            • jeff hammondJ
              i think they aren't sharp corners prior to using roundCorner and he's using too big of a radius for the softened corners.. so there's guess #3 😉
                Subtle. I couldn't see those lines on my Mac but now that I'm home from work I can see them.
                • jeff hammondJ
                  really? mac at work - windows at home?
                  that's opposite of the norm for people using both systems.
                  (re: the topic- it's hard to tell if those are just some sort of layout lines down below or if they're also on the object which has been roundCorner_ed.. hence the request for the file)
                    I use my MacBook Pro at work more than at home. I mostly use my PC at home but both have SU Pro so I can go back and forth between them.
                    [/quote][/quote]
                    Agreed.
                    • N
                      nwarner33
                      Thanks for the quick responses!
                      I had it scaled up largely. I figured it must have been that the radiuses were too large for the size, however it didnt appear to be. The typography needs to be exactly as is. Ive attached the file to see if anyone can have another crack at it. Thanks again.
                      logo 3d.skp
                      • mitcorbM
                        mitcorb
                        Hi.
                        If you need this in a hurry, I suggest the following:
                        Select the flat face of the 5, copy to the side. Harden the edges. Delete the flat face, leaving the outline of the 5. Create your 150mm arc with 4 segments, or some other number. Make a quarter round face/profile. Set it in position. Select the profile as a path. Use the FollowMe tool.
                        In spite of all the vagaries of the figure, I got a clean result.
                        • gillesG
                          gilles
                          Give as at least a V8 .skp please, not everybody run 2013.
                          • mitcorbM
                            mitcorb
                            Actually, it is possible to take your result with the corner wings, make a selection only of the intersecting faces, right click intersect selection, erase the concealing faces, draw lines where intersection didn't complete, then erase the wings. This is more tedious, obviously, and you will need to do it for each of those sharp corners. Also, when I performed the rounding, the offset preview showed overlapping of the offset at the corners. The offset that got a clean preview profile was a mere 30mm. Not really what you wanted.
                            Also, when I downloaded your skp I noticed that the bottom of the figure was a closed face. You need to delete the face or you get rounding of the bottom and the wings.
                            None of my business, but what are those diamonds and trapezoids about on the underside of the 5?
                              michelleyeo
                              Dear Fredo,
                              I have followed your instructions to place the plugin into Sketchup plugin folder. (mac version sketchup2013)
                              However, in the window i do find the libFredo6 setting but no tool bar or anything else to be found in my sketch up.
                              Please help
                              Michelle
                                michelleyeo
                                please see attached file
                                I m not sure if I have installed it properly or not as the is no tool bar or any sign of rounder corner but libFredo6 setting.
                                Please help.
                                • OxerO
                                  Oxer
                                  If you have installed correctly the plugin in User/Library/Applications Support/Sketchup 2013/Sketchup/ Plugins, go to View Menu/Toolbars/..... and mark the Round Corner to see its toolbar.
                                    Also ensure that it is enabled [checked] under Preferences > Extensions...
                                    Otherwise its Toolbar isn't available...
                                      michelleyeo
                                      Dear TIG and Oxer,
                                      Many thanks for your reply.
                                      I've installed correctly and enabled the extensions however no sign for Roundcorner.
                                      Please helpppp
                                      • BoxB
                                        Are you saying that if you put your mouse on the words "Tool Palettes" you don't get round corner in the list that pops up? or haven't you found that list of toolbars yet.
                                          michelleyeo
                                          Yes, I don't get the round corner in the list
                                          • jeff hammondJ
                                            @michelleyeo said:
                                            Dear TIG and Oxer,
                                            Please helpppp
                                            according to your second picture, you haven't installed it correctly.. you're missing libFredo files.
                                            you can get that here:
                                            http://sketchucation.com/forums/viewtopic.php?t=17947
                                            (download the .rbz version underneath the word DOWNLOAD in the first post)
                                            to install it, go Sketchup (menu)-> Preferences-> Extensions..
                                            click the 'Install Extensions' button at the bottom then navigate to the libFredo .rbz file... it will be placed in the proper location for you..
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 74
                                            • 75
                                            • 43 / 75
