    A little question... [comma or dot]
    19 Posts 8 Posters 2.7k Views 8 Watching
    • jeff hammondJ
      @gaieus said:
      on other OS's (like my Hungarian) it is 4,5;6,7
      ugh.. that'd be enough to make me quit using sketchup 😆
      @icoff, in case you missed this, the english version of sketchup doesn't act this way and will let you enter the numbers in the manner you're asking.. so, you seem to read/write english well enough -- maybe switch to that version ? 😉
      [edit] oh.. i see you've found a solution… does that change take effect system wide? that could be a problem too i think..
      • massimoM
        massimo Moderator
        Well Jeff, it's OS (language) related not SU's version (language) related. I have an english version of SU and I have to use comma and semicolon. 😄
        • GaieusG
          @massimo said:
          Well Jeff, it's OS related not SU's version related. I have an english version of SU and I have to use comma and semicolon.
          Indeed. The OS "decides". And it is buggy as hell - and no matter that in each new beta all non-English users we try to get them to do something; they never change anything.
          An example of the glitch why it is completely unusable:
          You try to move something entering 3D coordinates as per the method posted here:
          http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863
          Now for me to move an entity to the origin, I would need to enter these values to the VCB: [0;0;0]
          But to enter either the [] brackets or the semicolon ; I need to press Ctrl+Alt - and Ctrl for Move means to copy (and clears all the entry I have entered so far) so I am there get f#&@@ked and cannot use the tool which should be something basic.
          • jeff hammondJ
            ouch!
            i've seen these topics before (the comma topics) but never engaged or read enough to get the details..
            now that i have, i guess all i can do is say "I feel bad for you lot!" 😄
            • jeff hammondJ
              ok then.. i guess i'll say "I feel bad for you… AND… hahahahahah " 💚
              • icoffI
                icoff
                ="Jeff Hammond@icoff, in case you missed this, the english version of sketchup doesn't act this way and will let you enter the numbers in the manner you're asking.. so, you seem to read/write english well enough -- maybe switch to that version ? 😉
                Hi Jeff, I know that the english version probably work like I wish, but my english is not so good to work with a program like SU..... and secondly, as Gaieus said, is a ploblem of SO. Indeed I can change in the preferences if I want the comma of the dot as decimal separator but don't change the key in the keypad....
                With this little program I have changed only this key. I try all the other letters and simbols and all works fine....
                • massimoM
                  massimo Moderator
                  Not a big deal if you get used. Btw if you were European your signature would be "commacommacomma"? 😛
                  • jeff hammondJ
                    ^ LOL
                    (and yeah.. I'm just being whiney about the comma thing on purpose.. (maybe venting some fiberglass frustration here).. i'm sure i'd get used to it and be just fine with it))
                      commacommacomma chameleon....he comes and goes.... everybody now....
                      • BepB
                        Bep
                        The only solution i could find until now ia a simple freeware key-mapper http://www.inchwest.com/mapkeyboard.htm
                        It solved my point to komma problem on the num-pad in Sketchup ,but also in Google spreadsheet.
                        Bep
                        "History is written by the winners"
                        • JQLJ
                          JQL
                          Guys manipulate your windows the way it wants to manipulate you. You can also do this on macs.
                          Sorry for Portuguese control panel, it happens I was born in a comma/dot+comma world.
                          www.casca.pt
                          Visit us on facebook!
