    [Plugin] Multiple Component Edit Warning
    77 Posts 21 Posters 46.3k Views 21 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @ashscott said:
      In terms of the notification position and style - you can move the webdialog to wherever you please and it will appear in the same place next time. The webdialog also serves as a button in the latest revision in that clicking it zooms the camera out to show all components being edited.
      Also.. if you know CSS, you can COPY the "user.css" file, up into the EditFlag directory (one level,) .. and then modify it to change color, font, text size, etc.
      The WebDialog HTML will load the "user.css" file IF (and only if,) it is in the same directory as the HTML file. (If it is not, then the inline StyleSheet will be used unchanged.
      There are also 2 variables that can be changed in the "EditFlag_loader.rb" file:
          ### Module Variables
          @@topmenu = "Edit" # change to "Plugins" if desired
          @@remind  = true   # change to false for no reminders
      πŸ’­
      I'm not here much anymore.
        Dan Rathbun
        @monmonred said:
        -make the notification become just a text that goes above the sketchup workspace at the lower-left corner (or probably make it have options for the location).
        I tried using a view-based model note in the initial version 1.
        No one liked it because it modified every model ... even model's you only wished to view, and not change.
        @monmonred said:
        ...the text doesn't not have to have its own window ...
        It does,... so that users can size it and move it around.
        The API does NOT have cross-platfrom features that allow us to create borderless and/or captionless windows. I could do it on only Microsoft platforms.. but how would a user move it, or size it?
        πŸ€“
          Dan Rathbun
          Well actually it is a single-click (the second click is ignored.) Helps prevent "a zoom out and back in again so fast ya' head spun" πŸ˜‰
          • JQLJ Offline
            JQL
            Hi, I hadn't noticed this new version of the plugin. It's working very nicely... Thanks for implementing that zoom out feature. It's great!
            www.casca.pt
            Visit us on facebook!
            • ashscottA Offline
              ashscott
              yeah I like it too
              Just some stuff I do with Sketchup.
                Dan Rathbun
                Yes we fixed these issues you reported, earlier:
                @jql said:
                When working on nested components, there are two things happening that I think could be revised.
                1 - The flag doesn't go off as I dig inside components nested inside other components. One has to turn them off manually.
                2 - The value showed does not reflect how many components really exist in the model if there are components inside other components.
                • JQLJ Offline
                  JQL
                  Yes I've noticed that too! It's very handy. I also notice that if you have a group within a component, it says you're inside a group too. What more could one need from context management plugins... 😎
                  www.casca.pt
                  • ashscottA Offline
                    ashscott
                    Hi all, Dan made some quick modifications and upgraded the plugin to version 2.4.0
                    Bug fixed so that multiple edit warnings do not appear on top of each other
                    This allows better compatibility with the latest version of SU
                    Also, I can't understand why this plugin isn't more popular, we (people I work with daily) use it on a daily basis and it has sped up our workflow immensely.....should I name it something more descriptive??
                    • JQLJ Offline
                      JQL
                      Yup, You have a name for this thread that is different from the plugin name and the the plugin's name isn't either descriptive or compelling.
                      My suggestion:
                      • ACHTUNG BABY Plugin!
                      • DANGER! DANGER!
                      • This city ain't big enought for both of us components!
                      Or simply:
                      • Editing Multiple Components Warning
                      www.casca.pt
                        Dan Rathbun
                        For some reason the PluginStore still has the old v2.2.1 ?
                        Oh.. and only the first post should have the plugin package. (There is still a post above with an old version.)
                        • ashscottA Offline
                          ashscott
                          Hi all, a really cool update to the plugin -
                          Now, when you receive the notification you can double click the webdialog that appears and the camera view will zoom out to show all instances that you are currently editing. Double click again and it will zoom back to where you were.
                          Based on your suggestions.
                          Cool huh?
                          • ashscottA Offline
                            ashscott
                            Every time I try to add the new plugin (V2.4.0) to the plugin store, there seems to be a timeout and nothing changes....
                              I have updated the entry to v2.4.0 for you...
                              Worked fine for me... πŸ˜•
                              I don't know what went wrong.
                              Can you fill in the other items in your plugin's page tabs - like release notes and overview...
                              Its link-name included a version-ref...
                              The very first RBZ uploaded should reflect the link-name desired - but after that it is used whatever the RBZ is then called...
                              It can be edited in the SCF data-base ,but the various files need adding back in...
                              It's fixed now anyway, as the files needed updating anyway... πŸ˜„
                              http://sketchucation.com/pluginstore?pln=CoastalConcepts_EditFlag
                              • ashscottA Offline
                                ashscott
                                Thanks TIG - changes made
                                any recommendations on the plugin? Do you use it yourself?
                                • U Offline
                                  unearthed
                                  Thanks for this Ash - A neat plugin - instant satisfaction πŸŽ‰ ! no loading, or switching on toolbars, it simply works .
                                  I wouldn't mind paying something for this plugin - it sure will save some time (and time really is money) - with an (overly complex) file, I recently changed all my broadleaf to fluoro green, when I thought I made the one I was working on unique .
                                  Growplan - People ∩ Plants ∩ Place
                                  windows 7 64b, 4GB RAM, SU 8.0.16846
                                  Gimp, QGIS, Vectorworks 12, Bricscad 11
                                    Dan Rathbun
                                    @Ash, thanks for renaming the topic thread.
                                    It should make more sense to persons browsing the Plugins Forum list.
                                    πŸ‘
                                    • bazB Offline
                                      baz
                                      I check the forum most days but somehow I missed this fantaboulous helper, I love it!!!
                                      My worst disaster was when a client wanted small changes amounting to 8 versions, then decided to go back to the original which was, you guessed it, totally screwed. Had to redraw from scratch almost.
                                      I would happily pay for this.
                                      Thanks Ash and Dan.
                                      • ashscottA Offline
                                        ashscott
                                        Thanks Baz, we think its handy.
                                        Seems every time I bump into a sketchup user they lament about this issue but haven't heard of the plugin and are quite excited when I show it to them.
                                        I should try promote it harder I guess...
                                        • bazB Offline
                                          baz
                                          I found it purely by chance under 'Text/Labeling' in the Plugin Store widget inside SU. Not very intuitive because I didn't know I needed it til then, as I knew the problem was my error, Duh!
                                          I think you should sell it to Trimble, it should be part of the GUI just like the popups which warn of 'changing styles'/'you are about to intersect with hidden geometry'/'your model is crap, start again' etc..
                                          Actually, I made the last one up... but what an idea for a plugin!
                                          Rgds from the home of the Wallabies
                                          • ashscottA Offline
                                            ashscott
                                            Convince Trimble to buy it and I'll send you a pet kiwi
                                            • 3 / 4
