    [Plugin] Multiple Component Edit Warning
    77 Posts 21 Posters 52.0k Views 21 Watching
    • ashscottA
      ashscott
      This is probably a dumb question, but I'm going to ask it anyway for interests sake:
      I got Dan to do some more tweaking and added the following features that you people suggested:
      1. Have the flag turn back off as you exit components that you have been editing including nested components.
      2. reverse iterating the edit path (nesting) array, and multiplying the lower instance counts by the next level up - if that will return an accurate count of the components being edited.
      3. Make the zoom out function when the flag is clicked. Must be reversible so that when clicked a second time the user will be taken back to the close up view of the component they were originally editing (you simply click on the body of the webdialog to see all components being edited and click it again to go back to where you were).
      I've paid to have this plugin developed and I wondered about charging a small price for this advanced version. Funds would go towards furthering the plugin. However, we all know of the "Penny Gap" issue and charging for this plugin could mean no-one uses it and it simply fades into obscurity (something I definitely DONT want to happen).....
      What are people's thoughts? Is the penny gap too big an obstacle to successfully keep plugins like this available?
      Or maybe I should just stop working so much and learn to code so I don't have to pay others to do it for me??
      Just some stuff I do with Sketchup.
      • jiminy-billy-bobJ
        jiminy-billy-bob
        How about crowdfunding ?
        "We need $XX for these functions"
          monmonred
          hello!
          i suggest these 2 things:
          -make the notification become just a text that goes above the sketchup workspace at the lower-left corner (or probably make it have options for the location). the text doesn't not have to have its own window and just a floating text like how the "two point perspective" label appears on the screen when you go to 2-pt-persp view. this is a very useful plugin and it will help a lot if it appears as if it is a native option in sketchup.
          -the notification auto-closes/disappears when you leave a component. and make it so that you do not have to close it yourself, and that you do not have to leave the whole 10-level grouping that your edited component is in just to make the notification disappear automatically.
          thanks for being awesome and for this awesome plugin!
          +Greatness may be measured on how much we have lost for the betterment of mankind+
          • ashscottA
            ashscott
            @monmonred
            Your second suggestion has been done in the update I refer to above.
            In terms of the notification position and style - you can move the webdialog to wherever you please and it will appear in the same place next time. The webdialog also serves as a button in the latest revision in that clicking it zooms the camera out to show all components being edited.
            • ashscottA
              ashscott
              So.....no one is willing to fork out for this plugin?
                monmonred
                thanks!
                i hope someone helps in this plugin's development. i wish i am that knowledgeable in scripting/programming. :l
                • JQLJ
                  JQL
                  Well Ashcott, I forked this thread to another one and I would love to have your contribution:
                  404 Not Found
                  (sketchucation.com)
                  Thanks and best regards,
                  JQL
                  www.casca.pt
                  Visit us on facebook!
                  • ashscottA
                    ashscott
                    I think that the discussion about reimbursing plugin developers for work done is fundamental to pushing SU forward as a community - I highly recommend that people consider the thread that JQL just linked to
                    • Dan RathbunD
                      Dan Rathbun
                      Also.. if you know CSS, you can COPY the "user.css" file, up into the EditFlag directory (one level,) .. and then modify it to change color, font, text size, etc.
                      The WebDialog HTML will load the "user.css" file IF (and only if,) it is in the same directory as the HTML file. (If it is not, then the inline StyleSheet will be used unchanged.
                      There are also 2 variables that can be changed in the "EditFlag_loader.rb" file:
                          ### Module Variables
                          @@topmenu = "Edit" # change to "Plugins" if desired
                          @@remind  = true   # change to false for no reminders
                      πŸ’­
                      I'm not here much anymore.
                      • Dan RathbunD
                        Dan Rathbun
                        I tried using a view-based model note in the initial version 1.
                        No one liked it because it modified every model ... even model's you only wished to view, and not change.
                        @monmonred said:
                        ...the text doesn't not have to have its own window ...
                        It does,... so that users can size it and move it around.
                        The API does NOT have cross-platfrom features that allow us to create borderless and/or captionless windows. I could do it on only Microsoft platforms.. but how would a user move it, or size it?
                        πŸ€“
                        • Dan RathbunD
                          Dan Rathbun
                          Well actually it is a single-click (the second click is ignored.) Helps prevent "a zoom out and back in again so fast ya' head spun" πŸ˜‰
                          • JQLJ
                            JQL
                            Hi, I hadn't noticed this new version of the plugin. It's working very nicely... Thanks for implementing that zoom out feature. It's great!
                            www.casca.pt
                            • ashscottA
                              ashscott
                              yeah I like it too
                              • Dan RathbunD
                                Dan Rathbun
                                Yes we fixed these issues you reported, earlier:
                                @jql said:
                                When working on nested components, there are two things happening that I think could be revised.
                                1 - The flag doesn't go off as I dig inside components nested inside other components. One has to turn them off manually.
                                2 - The value showed does not reflect how many components really exist in the model if there are components inside other components.
                                • JQLJ
                                  JQL
                                  Yes I've noticed that too! It's very handy. I also notice that if you have a group within a component, it says you're inside a group too. What more could one need from context management plugins... 😎
                                  www.casca.pt
                                  • ashscottA
                                    ashscott
                                    Hi all, Dan made some quick modifications and upgraded the plugin to version 2.4.0
                                    Bug fixed so that multiple edit warnings do not appear on top of each other
                                    This allows better compatibility with the latest version of SU
                                    Also, I can't understand why this plugin isn't more popular, we (people I work with daily) use it on a daily basis and it has sped up our workflow immensely.....should I name it something more descriptive??
                                    • JQLJ
                                      JQL
                                      Yup, You have a name for this thread that is different from the plugin name and the the plugin's name isn't either descriptive or compelling.
                                      My suggestion:
                                      • ACHTUNG BABY Plugin!
                                      • DANGER! DANGER!
                                      • This city ain't big enought for both of us components!
                                      Or simply:
                                      • Editing Multiple Components Warning
                                      www.casca.pt
                                      • Dan RathbunD
                                        Dan Rathbun
                                        For some reason the PluginStore still has the old v2.2.1 ?
                                        Oh.. and only the first post should have the plugin package. (There is still a post above with an old version.)
                                        • ashscottA
                                          ashscott
                                          Hi all, a really cool update to the plugin -
                                          Now, when you receive the notification you can double click the webdialog that appears and the camera view will zoom out to show all instances that you are currently editing. Double click again and it will zoom back to where you were.
                                          Based on your suggestions.
                                          Cool huh?
                                          • ashscottA
                                            ashscott
                                            Every time I try to add the new plugin (V2.4.0) to the plugin store, there seems to be a timeout and nothing changes....
                                            • 3 / 4
