    [Plugin] Multiple Component Edit Warning
    77 Posts 21 Posters 50.6k Views 21 Watching
    • ashscottA
      ashscott
      yeah I like it too
      Just some stuff I do with Sketchup.
      • Dan RathbunD
        Dan Rathbun
        Yes we fixed these issues you reported, earlier:
        @jql said:
        When working on nested components, there are two things happening that I think could be revised.
        1 - The flag doesn't go off as I dig inside components nested inside other components. One has to turn them off manually.
        2 - The value showed does not reflect how many components really exist in the model if there are components inside other components.
        I'm not here much anymore.
        • JQLJ
          JQL
          Yes I've noticed that too! It's very handy. I also notice that if you have a group within a component, it says you're inside a group too. What more could one need from context management plugins... 😎
          www.casca.pt
          Visit us on facebook!
          • ashscottA
            ashscott
            Hi all, Dan made some quick modifications and upgraded the plugin to version 2.4.0
            Bug fixed so that multiple edit warnings do not appear on top of each other
            This allows better compatibility with the latest version of SU
            Also, I can't understand why this plugin isn't more popular, we (people I work with daily) use it on a daily basis and it has sped up our workflow immensely.....should I name it something more descriptive??
            • JQLJ
              JQL
              Yup, You have a name for this thread that is different from the plugin name and the the plugin's name isn't either descriptive or compelling.
              My suggestion:
              • ACHTUNG BABY Plugin!
              • DANGER! DANGER!
              • This city ain't big enought for both of us components!
              Or simply:
              • Editing Multiple Components Warning
              www.casca.pt
              • Dan RathbunD
                Dan Rathbun
                For some reason the PluginStore still has the old v2.2.1 ?
                Oh.. and only the first post should have the plugin package. (There is still a post above with an old version.)
                • ashscottA
                  ashscott
                  Hi all, a really cool update to the plugin -
                  Now, when you receive the notification you can double click the webdialog that appears and the camera view will zoom out to show all instances that you are currently editing. Double click again and it will zoom back to where you were.
                  Based on your suggestions.
                  Cool huh?
                  • ashscottA
                    ashscott
                    Every time I try to add the new plugin (V2.4.0) to the plugin store, there seems to be a timeout and nothing changes....
                      I have updated the entry to v2.4.0 for you...
                      Worked fine for me... πŸ˜•
                      I don't know what went wrong.
                      Can you fill in the other items in your plugin's page tabs - like release notes and overview...
                      Its link-name included a version-ref...
                      The very first RBZ uploaded should reflect the link-name desired - but after that it is used whatever the RBZ is then called...
                      It can be edited in the SCF data-base ,but the various files need adding back in...
                      It's fixed now anyway, as the files needed updating anyway... πŸ˜„
                      http://sketchucation.com/pluginstore?pln=CoastalConcepts_EditFlag
                      • ashscottA
                        ashscott
                        Thanks TIG - changes made
                        any recommendations on the plugin? Do you use it yourself?
                        • U
                          unearthed
                          Thanks for this Ash - A neat plugin - instant satisfaction πŸŽ‰ ! no loading, or switching on toolbars, it simply works .
                          I wouldn't mind paying something for this plugin - it sure will save some time (and time really is money) - with an (overly complex) file, I recently changed all my broadleaf to fluoro green, when I thought I made the one I was working on unique .
                          Growplan - People ∩ Plants ∩ Place
                          windows 7 64b, 4GB RAM, SU 8.0.16846
                          Gimp, QGIS, Vectorworks 12, Bricscad 11
                          • Dan RathbunD
                            Dan Rathbun
                            @Ash, thanks for renaming the topic thread.
                            It should make more sense to persons browsing the Plugins Forum list.
                            πŸ‘
                            • bazB
                              baz
                              I check the forum most days but somehow I missed this fantaboulous helper, I love it!!!
                              My worst disaster was when a client wanted small changes amounting to 8 versions, then decided to go back to the original which was, you guessed it, totally screwed. Had to redraw from scratch almost.
                              I would happily pay for this.
                              Thanks Ash and Dan.
                              • ashscottA
                                ashscott
                                Thanks Baz, we think its handy.
                                Seems every time I bump into a sketchup user they lament about this issue but haven't heard of the plugin and are quite excited when I show it to them.
                                I should try promote it harder I guess...
                                • bazB
                                  baz
                                  I found it purely by chance under 'Text/Labeling' in the Plugin Store widget inside SU. Not very intuitive because I didn't know I needed it til then, as I knew the problem was my error, Duh!
                                  I think you should sell it to Trimble, it should be part of the GUI just like the popups which warn of 'changing styles'/'you are about to intersect with hidden geometry'/'your model is crap, start again' etc..
                                  Actually, I made the last one up... but what an idea for a plugin!
                                  Rgds from the home of the Wallabies
                                  • ashscottA
                                    ashscott
                                    Convince Trimble to buy it and I'll send you a pet kiwi
                                    • bazB
                                      baz
                                      P'haps Chris Fulmer or TomTom will see this. Tho I have no idea whether Trim ever 'buy' plugins. I s'pect not.
                                      Its pissing down here in the shed, I can hardly hear myself think.
                                      • T
                                        TBoy
                                        @ashscott said:
                                        ..Bug fixed so that multiple edit warnings do not appear on top of each other..
                                        There are 2 overlapping warning windows in SU 2018. Anyone to confirm?
                                        • bazB
                                          baz
                                          @tboy said:
                                          There are 2 overlapping warning windows in SU 2018. Someone to confirm?
                                          Not with me...
                                          • C
                                            creativegood
                                            Worked with SU 2020. Seems not to work with SU 2021. Can anyone confirm?
                                            • 3 / 4
