    1.5k Posts 471 Posters 3.3m Views 470 Watching
    • fredo6F Offline
      @rfriedr1 said:
      I've been using the Fredo tools for years.
      Unfortunately, after upgrading to a retina MacBook Pro, they are unusable - since the dialogs and fonts are tiny and unreadable. ๐Ÿ˜ž
      That's a known problem on Retina screens.
      I hope the SU team will provide a fix or workaround, since there is nothing that can be done at the moment from the Ruby API.
        rsgomes
        Always have a Bug Splat! ๐Ÿ˜ž
        Already reinstalled the pluguins (both LibFredo and RoundCorner) and have the same problem...
        I'm trying to roundcorner the top of a cilinder. It works with that geometry right?!
          Yes. It works with a cylinder. How big is the cylinder? How big is the roundover? How many segments in the radius? Do you have the Vray plugin installed? Or any of the other plugins known to cause problems?
          Please complete your profile with SU version and OS.
            rsgomes
            It's a 3 cm radius; 0.5 cm height; 0.2 cm roundover (roundover mean the area that the edge will curve, doesn't it?); 100 segments'circunference; I have Vray 1,6 installed.
            The plugin works, but at the same time I close the command I have that bug spalt. I've tried with rectangles too and have the same problem (200 x 60 x 2 cm).
            • BoxB Offline
              Disable Vray and try again.
              If you don't know how to do that, just navigate to the plugin folder (usually found at C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins) and rename the vray .rb to .rb! and it won't load.
                The Vray plugin is well known to cause other plugins to have problems.
                100segments on a radius that small could also be problematic. At least for testing use the default 24 sided circle and no more than 12 segments for the roundover.
                  muchyt
                  danKEEEEEEEEEEEEEEEEEEEEEEEEEEE
                    benbrenner
                    I've attached an image below. This sort of thing keeps happening to me when I attempt to use this plug in. It seems like I am just supposed to click the object i want to round out and then voila. But instead I only get this. This was just a simple cube. What am I doing wrong?
                    • mitcorbM Offline
                      mitcorb
                      Hi, Ben:
                      Pay attention to the offset distance and segment number. It appears your offset distance is greater than the width of the faces.
                        mcgaffin
                        I have installed the round corner plugin and I get this message.
                        "Module RoundCorner requires Sketchup version greater than 5.0.160. Current Version is 13.0.3689"
                        Does anyone know how to fix?
                          Where did you download Round Corner from? Did you also update Lib_Fredo6 at the same time? If not, do so.
                            That's a very old version error message - those errors are fixed in the newer versions.
                            Get the newest you can [PluginStore!] AND the needed Lib - all as Dave says ๐Ÿ˜’
                            • N Offline
                              nwarner33
                              Can anybody help me out rather urgently?? I have attached screen shots of the settings that I have used and the results I have gotten, as well as what I am trying to achieve. How do I get rid of those little wing pieces on the top that shouldn't be there??
                              Is this the best tool to use for the job or can someone recommend a better one? I have tried the soap skin tool which works for the top and bottom banners, however its very uneven on the 5.
                              Any advice would be super welcome. Thanks.
                              • jeff hammondJ Offline
                                it's hard to tell what the problem is without seeing the base geometry.. copy that 5 into it's own file then attach the .skp to your post.. you'll get an exact answer that way instead of a bunch of guesses.
                                  We need the SKP... but my guess is it is too small !
                                  Scale x 10 [or x100] and retry, scale back down on success... ๐Ÿ˜•
                                    I tried on a simple box with the 150mm offset and 50 sides and it worked fine. I'm guessing there was something strange with your geometry such as an internal face maybe.
                                      i think they aren't sharp corners prior to using roundCorner and he's using too big of a radius for the softened corners.. so there's guess #3 ๐Ÿ˜‰
                                        Subtle. I couldn't see those lines on my Mac but now that I'm home from work I can see them.
                                          really? mac at work - windows at home?
                                          that's opposite of the norm for people using both systems.
                                          (re: the topic- it's hard to tell if those are just some sort of layout lines down below or if they're also on the object which has been roundCorner_ed.. hence the request for the file)
                                            I use my MacBook Pro at work more than at home. I mostly use my PC at home but both have SU Pro so I can go back and forth between them.
                                            [/quote][/quote]
                                            Agreed.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 73
                                            • 74
                                            • 31 / 74
