    • Log Masuk
    Scheduled Pinned Kunci Moved Plugins
    1.5k Kiriman 473 Posters 3.4m Lihat 472 Watching
    Memuatkan lagi kiriman
    • Lama ke Baru
    • Baru ke Lama
    Balas
    Log masuk untuk balas
    Topik ini telah dipadam. Hanya pengguna dengan kuasa pengurusan boleh melihatnya.
    • A Luar talian
      AcesHigh
      @box said:
      Yeah, I take it back, just made a new one with a 5sided 2mm round and no problems. So there is something screwed up in your file.
      I will read a bit about quantum physics right now. Its certainly easier to understand than the inner workings of Sketchup 😆
      1 Reply Last reply Balas Petikan 0
      • R Luar talian
        rfriedr1
        I've been using the Fredo tools for years.
        Unfortunately, after upgrading to a retina MacBook Pro, they are unusable - since the dialogs and fonts are tiny and unreadable. 😞
        • fredo6F Luar talian
          That's a known problem on Retina screens.
          I hope the SU team will provide a fix or workaround, since there is nothing that can be done at the moment from the Ruby API.
          • R Luar talian
            rsgomes
            Always have a Bug Splat! 😞
            Already reinstalled the pluguins (both LibFredo and RoundCorner) and have the same problem...
            I'm trying to roundcorner the top of a cilinder. It works with that geometry right?!
            • Dave RD Luar talian
              Yes. It works with a cylinder. How big is the cylinder? How big is the roundover? How many segments in the radius? Do you have the Vray plugin installed? Or any of the other plugins known to cause problems?
              Please complete your profile with SU version and OS.
              • R Luar talian
                rsgomes
                It's a 3 cm radius; 0.5 cm height; 0.2 cm roundover (roundover mean the area that the edge will curve, doesn't it?); 100 segments'circunference; I have Vray 1,6 installed.
                The plugin works, but at the same time I close the command I have that bug spalt. I've tried with rectangles too and have the same problem (200 x 60 x 2 cm).
                • BoxB Luar talian
                  Disable Vray and try again.
                  If you don't know how to do that, just navigate to the plugin folder (usually found at C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins) and rename the vray .rb to .rb! and it won't load.
                    The Vray plugin is well known to cause other plugins to have problems.
                    100segments on a radius that small could also be problematic. At least for testing use the default 24 sided circle and no more than 12 segments for the roundover.
                    • M Luar talian
                      muchyt
                      danKEEEEEEEEEEEEEEEEEEEEEEEEEEE
                      • B Luar talian
                        benbrenner
                        I've attached an image below. This sort of thing keeps happening to me when I attempt to use this plug in. It seems like I am just supposed to click the object i want to round out and then voila. But instead I only get this. This was just a simple cube. What am I doing wrong?
                        • mitcorbM Luar talian
                          mitcorb
                          Hi, Ben:
                          Pay attention to the offset distance and segment number. It appears your offset distance is greater than the width of the faces.
                          • M Luar talian
                            mcgaffin
                            I have installed the round corner plugin and I get this message.
                            "Module RoundCorner requires Sketchup version greater than 5.0.160. Current Version is 13.0.3689"
                            Does anyone know how to fix?
                              Where did you download Round Corner from? Did you also update Lib_Fredo6 at the same time? If not, do so.
                              • TIGT Dalam talian
                                That's a very old version error message - those errors are fixed in the newer versions.
                                Get the newest you can [PluginStore!] AND the needed Lib - all as Dave says 😒
                                • N Luar talian
                                  nwarner33
                                  Can anybody help me out rather urgently?? I have attached screen shots of the settings that I have used and the results I have gotten, as well as what I am trying to achieve. How do I get rid of those little wing pieces on the top that shouldn't be there??
                                  Is this the best tool to use for the job or can someone recommend a better one? I have tried the soap skin tool which works for the top and bottom banners, however its very uneven on the 5.
                                  Any advice would be super welcome. Thanks.
                                  • jeff hammondJ Luar talian
                                    it's hard to tell what the problem is without seeing the base geometry.. copy that 5 into it's own file then attach the .skp to your post.. you'll get an exact answer that way instead of a bunch of guesses.
                                    • TIGT Dalam talian
                                      We need the SKP... but my guess is it is too small !
                                      Scale x 10 [or x100] and retry, scale back down on success... 😕
                                        I tried on a simple box with the 150mm offset and 50 sides and it worked fine. I'm guessing there was something strange with your geometry such as an internal face maybe.
                                          i think they aren't sharp corners prior to using roundCorner and he's using too big of a radius for the softened corners.. so there's guess #3 😉
                                            Subtle. I couldn't see those lines on my Mac but now that I'm home from work I can see them.
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 73 / 74
