    How can i make Sketchup Vray with Section Animation
    renderpluginsextensions
    13 Posts 8 Posters 7.8k Views 8 Watching
    • F Offline
      februeajah
      Like my title above, How can i make Sketchup Vray with Section Animation?
      If i render with section panel, vray can't read the section panel as a section.
      than, im student and want to give structure section animation. how can i do it?
      • KrisidiousK Offline
        Krisidious
        The work around I used was making multiple copies of areas and using layers and the slice tool to use true sections in animation.
        By: Kristoff Rand
        • F Offline
          februeajah
          Make around 480 sections cut for 20 seconds animation?
            Krisidious
            I'm not familiar with your project so I can't really say. But animation has long been a process. I think the new Thea does it though.
            By: Kristoff Rand
            • dkendigD Offline
              dkendig
              It's on our todo list, but it's not in the 2.0 version. There is a bit of work we need to do behind the scenes to get section cuts to work properly.
              Devin Kendig
              Developer
              • V Offline
                valerostudio
                You will not be able to animate a section like this in the current version. I would consider one of two things. Pick another engine that will do it (learning curve) or just do it through SketchUp without having it rendered through V-Ray (easiest option).
                • dkendigD Offline
                  dkendig
                  or wait for our 3.0 release where we will have it implemented πŸ˜‰
                  Devin Kendig
                  Developer
                  • jiminy-billy-bobJ Offline
                    jiminy-billy-bob
                    Do you have an ETA for v3.0?
                    Or even a range? 6-12 months? 2-3 years? 4-6years?
                    • dkendigD Offline
                      dkendig
                      nah, we just did planning for it last week, we are much too far away from that to say any rough dates. First there will be a service release, then we will be working on 3.0 I believe.
                      Devin Kendig
                      Developer
                      • F Offline
                        februeajah
                        can sketchup do this? http://www.youtube.com/watch?v=tQkDRXo7tLM
                          rspierenburg
                          For sure. Just about anything can be animated using Scenes. It would be a lot of work mind you, but it is definitely possible.
                            Playinq
                            Well, I guess there is still no work around there. Animations are still lackluster even with the newest version..
                              Maybe you should talk to the Chaos Group folks.
