    [Plugin] Components manager plugin
    156 Posts 15 Posters 71.6k Views 15 Watching
    • JQLJ
      JQL
      Hi Inteloide,
      1 - Component manager is now able to save without extension but it's still unable to find a reference that was saved that way.
      2 - I understood the concept of versions level but I'm unable to make the plugin save a new version by itself. It ask wether I'd like to save as new version level or not, but never saves a new version either I press yes or no.
      3 - Selecting from either list or model is now working perfectly, just like outliner.
      4 - There is a feature that is not working as I would expect too. If one refreshes the list by whatever reason it collapses (some commands also refresh it). You loose the context on the list you were on. Of course it's easy now to choose from model so this is just a minor question.
      Best regards. I hope this helps,
      JQL
      www.casca.pt
      Visit us on facebook!
      • OxerO
        Oxer
        On Mac when Sketchup runs it appears a Ruby Console Error:
        %(#FF0000)[Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb
        Permission denied - /Users/Oxer\BGSketchup_Composants.ini
        Error al cargar archivo BGSketchup_Composants.rb
        Permission denied - /Users/Oxer\BGSketchup_Composants.ini]
        The BGSketchup_Composants.ini file doesn't exist in that path, i have complete privilegies for Plugins folder.
        • OxerO
          Oxer
          I have added the spanish language to Localization.rb file.
          Spanish Language added
          • inteloideI
            inteloide
            Hello,
            As every day, just post an update, with following corrections :
            Corrected : When clicking on component in model, the information were not displayed.
            Corrected : Revision system now working
            Corrected : Bug when clicking on a group in the model (doesn't block user)
            Corrected : Attempt to solve Mac file issue
            Added : Spanish language, thanks to Oxer
            JQL, this solve points 2 and 3. For your point 1, note that Sketchup force the file to be a ".skp" when saving component...No way to solve this...
            About point 4 : it could be complex...I will try (I stack this with the filters for the list ;o)
            Oxer : thank yoiu for translation !
            About your issue on Mac, I make a correction that may solve your issue. I saw that the "/" and "" were different on your message. as windows reconize both, I force the string to be with "/". I guess it solve the problem...Please keep me informed !
            Note also that I release the first help file (at least !!!). Hope you will love it !!! πŸ˜‰
            bye !
            Humanity will do a huge step when the IT professionals will understand that computers are tools...
            • OxerO
              Oxer
              Thanks for the update but it appears the same message in Ruby Console:
              • inteloideI
                inteloide
                Hello Oxer,
                could you please post the complete error message ? To which line produce this bug ?
                thank you !
                  The answer is in the text πŸ˜’
                  /Users/Oxer****\****BGSketchup_Composants.ini
                  The backslash \ will only work as a file separator character on PCs, NOT MACs !
                  A / works on both platforms.
                  You should use File.join(directorypath, filename) to avoid this issue.
                  Also you can use .tr!("\\","/") to fix it.
                  [Conversely, on PC if you ever want to pass a path to say a "cmd" use .tr!("/","\\") as DOS always expects \ !]
                  On PC AND on MAC this will work:
                  /Users/Oxer****/****BGSketchup_Composants.ini
                  Change the code from:
                  file_name=BGSketchup_my_documents_dir()+"\\BGSketchup_Composants.ini"
                  to
                  file_name=Fiile.join(BGSketchup_my_documents_dir(), "BGSketchup_Composants.ini")
                  which avoids the \...
                  Incidentally don't set def methods with uppercase first letter:
                  BGSketchup_my_documents_dir() NO 😞
                  bgSketchup_my_documents_dir() YES πŸ˜„
                  Although a method named ' getTempFolder()' would be more logical*** ??
                  ***Writing this ini file to that user-location is also somewhat ill-advised ?
                  Why not put it into a 'Temp folder' - this varies between PC and MAC...
                  ENV['TEMP'] || ENV['TMPDIR']
                  if !(mac) ... return path.strip.gsub("\000","") else #On Mac return File.expand_path "~" end
                  could simply be:
                  return ENV['TEMP'] || ENV['TMPDIR']
                  On PC it gives:
                  C:\Users\UserName\AppData\Local\Temp
                  OR perhaps on PC [ruby:3kd2xg63]ENV['APPDATA'][/ruby:3kd2xg63] giving:
                  [ruby:3kd2xg63]C:\Users\UserName\AppData\Roaming[/ruby:3kd2xg63]
                  On MAC it's the user's hidden ..../T[emp] folder
                  Keeping it 'out of the way', and avoiding all of the '.so' rigmarole and odd locations for the .ini file...
                  πŸ€“
                  • OxerO
                    Oxer
                    How TIG says, the answer is in the text, all red text is the Error Message.
                    Thanks TIG for the explanation, i don't know the ruby code. πŸ‘
                    • inteloideI
                      inteloide
                      Hello,
                      Thank you TIG for your help.
                      Your code is so much simple than mine...I changed to yours.
                      New version (1.9.4) solve only this error.
                      • inteloideI
                        inteloide
                        Version 1.9.5 :
                        Corrected : When saving all definitions, it asks now to save also file without link.
                        Optimzed : Now, for revision management, file with letter after revision level and accepted "toto rev 3 (super").skp"
                        Oxer, any feedback as a MAC user ?
                        I will officially post this version tomorrow if no bugs are found.
                        In parrallel I will look for JQL request but won't post new version (I think too much version make confusion...)
                        • OxerO
                          Oxer
                          Image 4
                          Image 5
                          • OxerO
                            Oxer
                            Now, there isn't Console Error when you open Sketchup, the settings window appears, the plugin generates the BGSketchup_Composants.ini file in Temporal folder, the translation works but the there are some problems:
                            1. The list is empty, when you push Update List button, nothing happens, no error in Ruby Console.
                            2. If you push Reload All Components button, it appears an error in Ruby Console, see the image 2.
                            3. If you push Save All Components button, it appears a first pop up window (image 3), i push Yes button and it appears a second empty pop up window (image 4), i push yes and it appears a Ruby Console Error (image 5).
                            Image 2
                            Image 3
                              That ' nil' error points to code at line #494 of the script Composants_Main.rb - which reads:
                              UI.messagebox @strNbEnregistementDefinitions+" ("+compteur_ok.to_s+"/"+compteur.to_s+")"
                              So presumably a part of it is actually ' nil' ?
                              @strNbEnregistementDefinitions is set elsewhere in the script Localization.rb.
                              This is set from a series of ' if/elsif' tests, BUT ill-advisedly there is no 'fall-back' ' else' when nothing matches the other tests - so then it can return ' nil', and thereby cause the error - because a ' nil' object can't be used as part of a text string!
                              Perhaps change the code to read...
                              @strNbEnregistementDefinitions='?' unless @strNbEnregistementDefinitions UI.messagebox(@strNbEnregistementDefinitions+" ("+compteur_ok.to_s+"/"+compteur.to_s+")")
                              OR have a proper ' else' fall-back in the Localization.rb tests section...
                              The other two methods used in compiling the remainder of the string should always safely return a string as they start off as 0 - giving '... (1/2)' etc...
                              • inteloideI
                                inteloide
                                This could be due to a missing tranlsation in string (a string not defined in one language). Therefore, I change the way of working on Localisation.rb :
                                1-I load all strings in English
                                2-I load the strings in the wanted language.
                                This means that if a string is not translated, the string will be defined with English value.
                                The key thing, for me, is to always have strings defined in English, at minimal.
                                • inteloideI
                                  inteloide
                                  @oxer said:
                                  1. If you push Reload All Components button, it appears an error in Ruby Console, see the image 2.
                                  Please try version 1.9.6 below, which should solve this issue.
                                  That's strange...maybe a javascript error...let's try with version 1.9.6, it may solve the issue.
                                  Version 1.9.6
                                  • OxerO
                                    Oxer
                                    Ok, i'll test it.
                                    • OxerO
                                      Oxer
                                      The list continues empty 😞
                                      I'll test the other functions
                                      • OxerO
                                        Oxer
                                        • Modify file's path -->works
                                        • Save selected component -->works
                                        • Save all components -->works
                                        • Save with new revision level -->works
                                        • Reload selected component -- > doesn't work, when you select the component it appears "Saved file is newer!" message but when i push Reload selected component button nothing happens, see the image below.
                                        • inteloideI
                                          inteloide
                                          Could be due to the browser I use which is IE.
                                          Please try to open attached file by placing it in plugins folder, in HTML subfolder. And tells me what happen.
                                          It's just a simplifyed list to see any error that your brownser may show.
                                          If you see something like a list, try to open directly the treeview.html file.
                                          Please report me any error...because without list...it's just not so useful... πŸ˜‰
                                          I maybe need an html/javascript specialist...
                                          The test file
                                          • OxerO
                                            Oxer
                                            I placed the test.html file in /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Html/ then I run Sketchup but when I call the plugin, the list is empty again. I have tried open tree.html in Safari browser and it appears a message:
                                            Safari can't open "sip:get_data@charger_tires" because OSX doesn't recognize the address of internet that begin with "skp:".
                                            When i open test.html in Safari the file shows like this:
                                            • 4 / 8
